i was just wondering if i put say a set of pacemaker extractors on my car will it change the sound of my exhaust or will it all still sound the same?
It will sound the same. There might be slighttt difference but you really won't notice it. It will be a bit louder around the headers though, as in towards the front of the car/in cabin.
will get a deeper sound a bit louder more power also.
MY VY SV8 HBD http://forums.justcommodores.com.au/...y-sv8-hbd.html
in the car and at the front will change, in some cases sounds abit tinny.
tail pipe sound won't change.
your engine will run cooler and feel more free with a slight increase in power.
Nobody wants to play with me
so changing from the stock extractors which HSV puts on to Pacemakes will make a difference in power and everything?
they are more of a benifit I would assume if you are doing some internal engine work as well.
I had a catback exhaust on my VY SS, then put on extractors and hi-flow cats and it really opened the exhaust up. Sounded a lot less muffled and car went a whole heap harder. Different engine to you i know, but i think you will notice a difference from the extractors.
The change in sound generally comes from moving the position of the cat/s around - a longer length of post-cat exhaust will resonate lower than a short piece of the same diameter.
they allow your car to breathe better also.. hence EXTRACTOR.
dont worry, il start a ride thread soon.
I will agree with everyone to a point.
They do change the sound, sometimes you can notice it, sometimes you can't. Increasing the power is sort of correct, what they actually do is increase the torque and change the range of available torque.
The reason they are called extractors is because the tuned length ones actually have a scavenging effect on the exhaust gas that is inside the combustion chamber, hence the term extractor, they extract more gas from the heads.
on my vn it didnt make the car louder (apart from the whooshing sound around the extractor area) but id did make it sound meatier. At that point i had a vn s1,with genie extravtors, a thick 2.5 inch exhaust, powerchip and a pod.
Sound changes to some extent. I wouldnt say they dont make a diffence in sound. If people say this then their hearing aids need to be turned up a few notches.
