Results 1 to 10 of 10
Thread: New rims throwing out my speedo?
    MEANVY's Avatar
    MEANVY is offline Donating Member
    VY Omega
    Aug 2008
    Darwin, NT
    Default New rims throwing out my speedo?
    Afternoon guys,
    Well, with my tax back i finally get my sexy new rims. i havn't decided yet but i'm thinking about either 18 or 19 inch SS or GTS rims, to keep it all holden. My current ones are 16 or so i think, whatever stockies were with the VY
    Taking on board what people have been saying, the bigger the wheels, the less rotations they do and therefore this impacts on the speedo readings, correct?
    So my question is will going from 16s to 18/19s effect my car badly? and if so how do i get this sorted out? with a programmer or something?
    Judging by other peoples experiences with rims, it throws it out maybe 5ks or so? I'm just being a worry wart....
    any help will be appreciated!!
    Cheers guys & Gals
    There's plenty of room for all of God's creatures...right next to the potatos
    Mitch's Ex-police VY Commo
    Quote Originally Posted by VT SERIES II View Post
    if a stripper said it , it MUST be true!!!!
    .....I still think its dirty .....
    2010 Voodoo Sv6
    Sep 2008
    If you don't go above 19s you should be able to fit them with lower profile tyres which won't change the overall diameter of the wheel, will not affect speedo that way...
    Quote Originally Posted by Cousin Slow Poke View Post
    Stick a gerbil in your pants!
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    As long as you use legal tyres in terms of overall diameter (within 15mm of standard) you shouldn't see the speedo out by any more than 2km/h when travelling at 100km/h. Most of the time less.
    Bigger wheels means smaller profile tyres which keeps the same overall rolling diameter so no big change in rotation.
    Philthy's Avatar
    Philthy is offline That dent guy
    VS Berlina, XC AMS Project
    Aug 2005
    STOCK
    15” 205/65/15
    Diameter: 647.5mm
    Circumference: 2034.2mm
    Revs/Km: 492.0
    When your Speedo reads 100Km/h, you are actually travelling at 100Km/h
    Stock ride height
    REPLACEMENT WHEELS
    16” 225/55/16
    Diameter: 653.9mm
    Circumference: 2054.3mm
    Revs/Km: 487.0
    When your Speedo reads 100Km/h, you are actually travelling at 101Km/h
    3.2mm higher then stock ride height
    17” 235/45/17
    Diameter: 643.3mm
    Circumference: 2021.0mm
    Revs/Km: 495.0
    When your Speedo reads 100Km/h, you are actually travelling at 99.4Km/h
    2.1mm lower then stock ride height
    18” 235/40/18
    Diameter: 645.2mm
    Circumference: 2027.0mm
    Revs/Km: 493.0
    When your Speedo reads 100Km/h, you are actually travelling at 99.6Km/h
    1.15mm lower then stock ride height
    19” 235/35/19
    Diameter: 647.1mm
    Circumference: 2032.9mm
    Revs/Km: 492.0
    When your Speedo reads 100Km/h, you are actually travelling at 99.9Km/h
    0.2mm lower then stock ride height
    20” 225/35/20
    Diameter: 665.5mm
    Circumference: 2090.7mm
    Revs/Km: 478.0
    When your Speedo reads 100Km/h, you are actually travelling at 102.8Km/h
    9mm higher then stock ride height
    Stolen from another forum so I won't take the credit for it. These are based on stock wheels being 205/65/15, but compare the 16" to 18" & 19" and you will have a rough guide.
    EDIT: Standard VY exec were 15" weren't they?
    1991_Vn2nV's Avatar
    Mar 2006
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Tyre Size Calculator -> Tire size calculator
    drop your standard size in (whats on ur car) and then drop on the sizes your thinking about, and it will tell you how much ur out, awesome little utility, bookmark!
    Quote Originally Posted by 1991_Vn2nV View Post
    ^ Why is the 20" wheel a 35 profile? 35 profile is legally suitable for a 19" rim, not a 20".
    i dont know exactly, but I think its becoz the 20s are 225/35 and the 19s are 235/35
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by ephect View Post
    That difference in width accounts for a 3.5mm reduction in the size of the tyre wall. Not nearly enough to cover the extra inch of the rim size.
    Its an illegal wheel and tyre combination. 225/30 R20 is the appropriate size.
    LowVp's Avatar
    LowVp is offline VP nut
    VP Ute 3.8T M5
    Aug 2005
    Ipswich, Qld
    because the tyre profile is a percentage of the tread width, notice that the 20" is on 225 where as the 19 is on 235
    MEANVY's Avatar
    VY Omega
    Aug 2008
    Darwin, NT
    Quote Originally Posted by Philthy View Post
    Crap, i've never even bothered to check before. Yeah they are! is there any problem going up to 18s or 19s from 15s? or as long as i make sure the wheels are sorted i wont have a problem?
    I remember someone saying you can only legally go up two sizes from your originals, ie i could only go to 17s on the commodore, is this true?
    VS II V6 Berlina
    Nov 2005
    once you've got rims and tyres on pay a visit to holden dealer and ask them to reprogram the PPK's in the instrument cluster to rectify the speedo. they should have a list of different tyre sizes and correct PPK's to suit to get speedo right.
    All cars from VT on with bigger wheels should have this done.
  1. Anyone throwing out a motor?
    By shaggerz in forum The Pub
    Last Post: 20-09-2006, 12:41 PM
  2. Throttle body throwing
    By VNV6VENGEANCE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2006, 11:03 AM
  3. Changing rims without affecting speedo
    By White_Knight in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-08-2006, 03:14 AM
  4. VN throwing fan belt
    By rhiann in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-07-2006, 02:15 AM
  5. Replies: 37
    Last Post: 13-01-2006, 01:25 PM
