Results 1 to 9 of 9
Thread: Modification plates and approval?
    Stressball's Avatar
    Stressball is offline Rolling on 4 again :D
    Mitsubishi Triton
    Oct 2005
    SE QLD
    Question Modification plates and approval?
    Hi all,
    I'm wondering what sort of modifications to a car would require a modification plate and approval to be carried out. I know things such as modifications to safety equipment, seat belts etc would need to be approved and have a plate fitted.. But when it comes to engine modification, what sort of things require a mod plate?
    The reason I ask is because I am under the impression that current QLD P plate laws DO allow engine modifcation, as long as the power output does not exceed 200kW, and the mods do not require approval and a mod plate. I'm not certain that this is the case, I will be looking into it further. That being said, I'd like to know what engine modifications can be done without getting approval.
    I'm currently driving a '96 VSII Berlina, and I'd like to know what sort of minor engine/performance mods could be done to it without needing a mod plate. Even if I do find out that all mods are illegal regardless, I'd still be interested in finding the requirements for a plate.
    Thanks in advance.
    Enter the Model/Class of your Commodore. i.e. VL C
    Sep 2008
    im pretty sore you can download a ebook thingie that tells you all u need to know from the main roads/qld transport website.
    Stressball's Avatar
    Mitsubishi Triton
    Oct 2005
    SE QLD
    Sep 2008
    part 1: modifications
    Motor vehicles
    Please note:
    The contents of this publication are a guide only and
    cannot be used as a reference to a point of law. For a
    detailed explanation, refer to the Transport Operations
    (Road Use Management - Vehicle Standards and Safety)
    Regulation 1999.
    For further information or additional copies of this
    brochure please contact your nearest Queensland Transport
    Customer Service Centre or phone: (07) 3253 4851 .
    all about
    QT 3166 June 2004 PBT-0671
    Queensland Transport, All about modifications to motor vehicles, 2008
    Contents
    Introduction 2
    Section 1 3
    Minor modifications
    Section 2 23
    Complex modifications
    Section 3 27
    Specific modifications
    Section 4 28
    Motorbike modifications
    all about
    modifications to
    motor vehicles
    2 3
    Introduction
    This booklet provides guidelines for
    vehicle owners or vehicle modifiers
    wishing to modify vehicles with a
    gross vehicle mass of not more than
    4.5 tonnes from the manufacturer’s
    original specifications. Following the
    guidelines in this booklet will ensure
    that your vehicle meets all applicable
    Queensland regulations and its safety
    levels are maintained.
    Modifications can be
    approved in three
    ways:
    Minor modifications
    Many minor modifications can be carried
    out with the approval granted by this
    booklet. Details of these modifications are
    outlined in Section 1.
    Sep 2008
    part 2: Complex modifications such as engine,
    gearbox and rear axle, steering and brake
    replacements require approval from an
    Approved Person. Details of these
    modifications and the Approved Person
    Scheme are outlined in Section 2.
    Some owners require approval for
    modifications which may be outside the
    scope of the Approved Person Scheme.
    Details of how to obtain approval for these
    modifications are outlined in Section 3.
    Section 1
    Minor
    modifications
    Replacement engines
    Replacement engines that are offered by the
    manufacturer as an optional engine for that model of
    vehicle may be fitted. For such conversions, all
    components, including suspension and brakes, must be
    identical to those of a vehicle originally produced with
    the optional engine.
    Exhaust systems
    Exhaust systems must comply with Queensland
    legislation which includes the following conditions:
    • Exhaust headers (extractors) may be fitted to any
    motor vehicle, provided:
    they do not foul any part of the steering,
    suspension, brake or fuel systems
    all fittings for emission control equipment
    (E.G.R. valve, oxygen sensor, pipes and so on)
    are incorporated to ensure the vehicle maintains
    compliance with Australian Design Rules for
    vehicle emissions
    exhaust systems must continue to comply with
    relevant legislation or Australian Design Rules for
    vehicle noise.
    • The exhaust outlet must extend at least 40mm beyond
    the furthermost outboard or rearmost joint of the floor
    pan that is not continuously welded or permanently
    sealed which could permit direct access of exhaust
    gases to the passenger compartment, but not beyond
    the perimeter of the vehicle when viewed in plan.
    • The exhaust outlet, if to the side of the vehicle, must
    discharge to the right hand side of
    the vehicle and downwards at an
    angle to the horizontal of not less
    than 15 degrees and not more than
    45 degrees.
    • The exhaust outlet, if to the rear of
    the vehicle, must discharge at not
    more than 10 degrees above or 45
    degrees below the horizontal.
    • All exhaust and muffler systems
    must be free of any leaks or
    mechanical faults and should
    be adequately supported.
    4 5
    Fuel systems
    Powerchips, multiple and/or replacement carburettors
    may be fitted to any motor vehicle provided the vehicle
    continues to comply with the emission requirements of
    the Australian Design Rules applicable at the time of the
    vehicle’s manufacture. Air cleaners must be fitted.
    The fitting of nitrous oxide injection equipment is
    not permitted.
    The fuel tank inlet and cap must be located on the
    outside of the vehicle unless originally fitted inside
    by the manufacturer.
    Lowering or raising of vehicles
    The road clearance of a fully laden vehicle must not be
    less than 100mm measured at any part of the vehicle
    other than the wheel rim or brake backing plates.
    (This does not apply where a lesser clearance has been
    specified by the manufacturer.)
    When lowering or raising a vehicle body (front or rear),
    the following additional restrictions are based on the
    manufacturer's dimensions for the standard unmodified
    vehicle while unladen:
    • The ride height measured between the rubber bump
    stop and the corresponding metal stop may be reduced
    by no more than one third.
    • The rebound travel measured between the rubber
    rebound stop and the corresponding metal stop
    (or the extension of the shock absorber for vehicles
    without a rebound stop) may be reduced by no
    6 7
    • Coil springs are to remain in locating seats on full
    suspension droop without forcibly being removed.
    In addition, the normal relationship between the front
    and rear suspension heights must not be unduly affected.
    Replacement springs (shorter or taller) must have the
    same or greater load capacity as the original springs.
    Suspension coil springs must not be shortened by cutting
    or heating. Leaf spring suspensions must not be raised
    by the use of extended shackles, adjustable metal plates
    or by placing the leaf springs to the opposite side of the
    axle. If lowering blocks are used, they must be either
    steel or aluminium.
    Airbag or air pressurised shock absorber helper springs
    may be fitted in addition to the original suspension.
    However, replacing some or all of the suspension system
    with an air or hydraulic suspension requires specific
    approval.
    Welding, chrome plating,
    heating or bending of
    axles,.suspension and
    steering components
    The welding, chrome plating, heating or bending of
    axles, suspension or steering components, as a method
    of repair or alteration, is not permitted.
    Permanently locking a differential by welding or other
    means is not permitted and has a dangerous effect on
    the handling of a vehicle.
    Sway bars, torque rods and
    traction rods
    Auxiliary suspension control devices may be fitted
    provided they are properly engineered and secured and
    do not affect minimum ground clearance.
    Glazing
    (windscreen and windows)
    No material or other object is to be located on the
    windscreen or windows which will interfere with the
    driver’s vision. Tinted windscreens are permitted subject
    to the screen having an optical transmission of not less
    than 75 per cent for a motor vehicle built after 1971 and
    70 per cent for any other vehicle.
    Transparent material used in a windscreen, window or
    interior partition of a motor vehicle manufactured after
    June 1953, must have the characteristics required by any
    of the following standards:
    • Australian Standard AS 2080-1977, AS 2080-1983 or
    AS 2080-1995
    • Economic Commission for Europe R-43/00
    • British Standards Institution BS AU178-1980
    • Japanese Industrial Standard JIS R 3211-1979,
    JIS R 3211-1985 or JIS R 3211-1992
    • American National Standard ANSI Z26.1-1980
    • New Zealand NZ 5443-1987.
    Tinting of vehicle windows
    Vehicles with non-tinted glass
    Automotive tinting material which has a light
    transmittance factor of not less than 35 per cent (T35)
    may be used on any non-tinted side or rear window.
    8 9
    Vehicle with factory-tinted
    glass
    Most new vehicles are fitted with tinted window glass.
    This tint is very light and glass may at first appear to be
    clear. To check, hold a piece of white paper on the
    opposite side of the glass. If it has a slight grey, green or
    brown colour when viewed through the glass, the glass
    is tinted.
    Special grades of film may be applied to factory tinted
    windows. When these films are applied to tinted glass,
    the combination of tints must still allow 35 per cent
    light transmittance.
    Windscreens
    Tinting may be fitted to the upper portion of a
    windscreen of a motor vehicle. The tinting must not
    extend lower than a horizontal line connecting the
    uppermost points of the arcs swept by the vehicle
    manufacturer’s original wiper blades or the upper
    10 per cent of the windscreen, whichever is the lesser.
    The tinting may be of any shade but must not have
    a reflectance of more than 10 per cent.
    General requirements
    for window tinting
    Film which has a reflectance of more that 10 per cent
    must not be used on any windscreen or window.
    Steering wheels
    Altering a steering wheel might affect a vehicle's
    compliance with the Australian Design Rules (ADRs)
    applicable to occupant impact protection.
    Steering wheels fitted to vehicles manufactured to
    comply with ADR 10/.. may only be replaced by a
    steering wheel which has been tested to comply with
    ADR10/... Where these ADRs apply, the vehicle's steering
    column and steering wheel are designed to minimise
    injury to the driver in the event of a crash.
    Vehicles that are required to comply with ADR 69/.. or
    ADR 73/.. or where originally fitted with a driver airbag
    must not be fitted with a replacement steering wheel
    without an airbag, unless it is supplied by the vehicle
    manufacturer as an option for that model.
    The diameter of any replacement wheel may be up to
    25mm smaller than the original wheel but must not
    be less than 350mm.
    Lighting systems
    All additional lighting systems are to be fitted strictly in
    accordance with Queensland legislation. Some additional
    requirements are explained below.
    Additional pairs of headlights, showing a beam of white
    light only, may be fitted and must not affect the driver’s
    view. The headlights must be mounted symmetrically.
    Additional high beam headlights must extinguish
    automatically when low beam is selected.
    A pair of fog lights, showing a beam of white or yellow
    light, may be fitted to the front of a motor vehicle with
    the centres no higher than the top of the dipped beam
    headlight. The lights must be mounted symmetrically not
    less than 600mm apart.
    Fog lights must be capable of being switched on and off
    independently of any headlights but must only be able
    to be switched on when the parking lights are on. Fog
    lights must not be used except in fog or mist or under
    other atmospheric conditions which restrict visibility.
    Blue lights are not allowed on any vehicles except
    emergency vehicles (for example police, fire and rescue,
    and ambulance). Red lights and reflectors must face to
    the rear. White lights and reflectors must face forward.
    Yellow lights are not permitted except for clearance
    lights on goods vehicles and buses, and indicators and
    fog lights on all vehicles.
    With the exception of indicators, flashing lights are not
    permitted on any vehicle, except special vehicles for use
    in hazardous situations (for example tow trucks) and
    emergency vehicles (for example police).
    10 11
    Some modern ‘blue’ halogen bulbs provide superior
    illumination to traditional bulbs. These bulbs contain less
    red/yellow and more blue frequencies of light to achieve
    a whiter appearance. Replacement head light bulbs must
    carry equivalent markings to the original bulb
    (e.g. an ‘E’ mark, H4, ADR 51/.. or ECE 37/..).
    Vehicle accessories
    and equipment
    It is the owner’s responsibility to ensure all accessories
    and equipment attached to a motor vehicle are designed
    and fitted in a manner which reduces the risk of injury
    to pedestrians and other road users making contact with
    the vehicle when the vehicle is parked or in motion.
    Driving lights/brackets must not protrude forward from
    the front face of any bumper or above the top of any
    bull bar.
    Not approved
    Fishing rod holders can only be fitted providing they
    comply with the following conditions:
    • The fitting allows the driver a view of the road and
    of traffic to the front and sides of the vehicle.
    • They must only be attached to the left side of
    the vehicle.
    • They must be designed to carry no more than four
    fishing rods.
    • Rods, hooks and sinkers must be properly secured
    Sep 2008
    part 3: • Vehicle lighting must not be obstructed by rods
    or holders.
    • Rod holders must be either removed when they are
    not in use or retracted behind the profile of the
    bull bar.
    Bicycle/wheelchair/roof racks
    Tow bar mounted bicycle and wheelchair carrying racks
    must be removed when not in use, unless specifically
    approved to remain attached. The bicycle or wheelchair
    and the carrying rack must not obscure any compulsory
    lighting or the number plate.
    Note: To address this problem, an Accessory Number
    Plate may be attached to bicycle carriers or other
    carrying devices. No other copy of the vehicle number
    plate is acceptable. Details are available at Queensland
    Transport Customer Service Centres.
    Roof racks must not protrude more than 50mm beyond
    the drip mould.
    Not approved
    Ladder racks/external roll
    bars and roll cages
    Vertical upright supports may be positioned forward
    of the windscreen ‘A’ pillar if their diameter does not
    exceed 50mm. Supports that are in a position to reflect
    the vehicle's lights back to the driver must be a matt
    black, non-reflective finish.
    12 13
    Ideally, no lights should be obscured by the fitting of
    any vertical support. If any light is obscured, an
    additional light must be fitted or the original relocated in
    accordance with the relevant legislation or Australian
    Design Rules.
    Supports, braces and brackets must not have any sharp
    edges or protrusions and must not interfere with a
    person's normal access to the vehicle. They should not
    project more than 150mm from each side of the vehicle
    or make the vehicle more than 2.5m wide.
    Any attachments or modifications to the vehicle's chassis
    must be in accordance with the vehicle manufacturer's
    recommendations.
    Requirements for internal roll bars and roll cages are
    covered in Section 2.
    Long range radio antennas
    Forward mounting should only be undertaken when it is
    impossible or impractical to install the antenna to the
    rear of the vehicle.
    The installation must be attached as low as is practical
    to ensure the large diameter section of the antenna
    projects above the bonnet line for the minimum distance.
    Only one long range antenna (large diameter base) may
    be fitted to the front of a vehicle and must be fitted to
    the left side. The maximum diameter permitted is 75mm.
    All sharp edges or protrusions which could cause injury
    to anyone making contact with the device must be
    removed or rounded.
    Visual display screens
    DVD screens, television receivers, visual display units
    and so on may be installed in a motor vehicle. No part of
    the image on the screen may be visible to the driver
    from the normal driving position unless the screen
    cannot be operated when the vehicle is moving or it is a
    driver’s aid (e.g. in-car navigation). As well, it must not:
    • obscure the driver’s view of the road
    • impede the movement of anyone in the vehicle
    • interfere with occupant restraint systems like head
    restraints, seat belts and airbags
    • increase the likelihood of injury to anyone in
    the vehicle or
    • be fitted if any part of the image on the screen is likely
    to distract another driver.
    Accessory gauges
    Any additional internal or external gauges must:
    • not interfere with the field of view of the driver
    • not produce glare to the driver
    • not have the possibility of an oil pressure line, or
    similar, breaking with pressurised fluids spraying
    onto the windscreen
    • be fitted in such a way to reduce the risk of injury to
    the vehicle occupants or pedestrians.
    14 15
    Bonnet scoops
    Bonnet scoops/projections may be fitted to a vehicle
    provided the driver’s vision is not restricted under
    normal operating conditions with the driver’s seat
    located at its lowest and rearmost position.
    Bonnet-mounted scoops/projections must meet the
    following requirements:
    • When a 165mm diameter sphere is placed on the
    bonnet in front of the scoop (or bonnet projection)
    and rolled backwards until it touches the scoop, no
    forward point of the scoop or point of contact between
    the sphere and the scoop must lie above a horizontal
    plane passing through the centre of the sphere.
    • It shall be possible to see either the surface of the
    road 11m in front of the driver’s eye or all of the front
    edge of the original body when looking across the top
    of the bonnet scoop. For the purposes of this
    requirement, the driver’s ‘eye’ position can be taken
    as being a point 730mm above and 270mm forward
    of the junction of the seat cushion and seat back with
    the seat in its lowest and rearmost position.
    • The edges at the front of a scoop/projection shall be
    rounded with a minimum of 10mm radius.
    • All other edges and corners shall have a radius of not
    less than 5mm and be designed to reduce the risk of
    bodily injury to any person to a minimum.
    • The scoop/projection must not have reflective surfaces.
    • Any holes in the bonnet must not substantially reduce
    the strength or impact resistance of the bonnet.
    • Air cleaners or carburettors must not protrude
    beyond the original bonnet profile unless the bonnet
    scoop/projection is manufactured from equivalent
    gauge mild steel, compared with that of the original
    bonnet.
    • Air cleaners and/or carburettors must be covered by
    the bonnet scoop.
    Side skirts, flares and spoilers
    Side skirts, front and rear spoilers may be fitted provided
    road clearance and air flow for brake cooling is not
    adversely affected.
    They must not be fitted so that it is likely to increase
    the risk of bodily injury to any person. All material is
    to be of a suitable thickness and be free from sharp
    edges or corners.
    Rear spoilers must be within the body shape/outline of
    the mounting surface (for example boot outline).
    Minimum thickness of end plates is 4mm and they must
    be free of sharp edges or corners.
    Bull bars
    Bull bars must be designed and fitted so that the safety
    of the vehicle is not adversely affected. They must be
    firmly and securely mounted and supported, and must
    not constitute a danger to other road users. Bull bars
    must not obstruct the vision of the driver and should not
    project further from the front of the vehicle than is
    necessary for its attachment. Bull bars should not add a
    significant load to the front suspension.
    Bull bars must be free of sharp protrusions and all
    exposed sections of the bull bar and fittings must be
    radiused and deburred. Forward and side members
    should be designed to reduce the risk of injury to any
    person who may come into contact with the bull bar.
    Bull bars must not obscure the driver's view or any light.
    In particular, the visibility of indicator lights at all
    viewing angles must not be reduced, and if so, additional
    lights must be fitted or the original relocated in
    Design Rules. Surfaces of the bar that could reflect light
    from the vehicle's headlights must be matt black.
    Vehicles fitted with an airbag or manufactured to comply
    with ADR 69 - Full Frontal Impact Occupant Protection
    or both ADR 69 and ADR 73 – Offset
    Frontal Impact Protection, can only be fitted with a bull
    bar which:
    • has been certified by the vehicle manufacturer as
    suitable for that vehicle or
    • has been demonstrated by the bull bar manufacturer
    to not adversely affect compliance with the ADRs or
    interfere with the critical airbag timing mechanism,
    as the case may be.
    Bull bars that comply with AS 4876.1-2002 provide a
    higher level of pedestrian protection.
    16 STANDARD TYRE LOW PROFILE TYRE 17
    Alternative rims and tyres
    Many vehicle owners like to replace the vehicle’s original
    rims and tyres with alternatives of different width,
    diameter and profile.
    The following sub-sections outline the legal requirements
    for replacement rims and tyres fitted to a passenger car
    or derivative, or an off-road passenger car (but not light
    commercial), which will ensure your vehicle continues to
    comply with Queensland legislation while allowing for
    your individual preferences.
    Low profile tyres
    It is common practice for manufacturers to fit low
    profile tyres to high performance motor vehicles as
    standard equipment.
    Low profile tyres (e.g. 50 series), replacing standard
    profile tyres (e.g. 70 series or above), are normally fitted
    in combination with rims of larger than standard
    diameter to maintain the correct overall diameter of
    the wheel.
    A diagram of this concept appears below.
    18 19
    The rim diameter may be varied from the standard size
    but the overall diameter of the tyre must not vary by
    more than +15mm or -26mm.
    These limits have been set for a number of reasons.
    Varying the overall diameter of tyres affects ground
    clearance, centre of gravity, brake effectiveness, steering
    geometry, performance and speedometer accuracy.
    Generally, to meet these limits, 60 series tyres are fitted
    to rims with a diameter 26mm larger than standard and
    50 series tyres are fitted to rims with a diameter 50mm
    larger than standard.
    General conditions for
    alternative rims and tyres
    The rims and tyres must not protrude beyond the
    bodywork of the vehicle, including flares, when viewed
    from above with the wheels facing straight ahead. If the
    vehicle was originally constructed with a portion of the
    wheel protruding, the wheels must not protrude further
    than originally constructed.
    The tyre to rim fitting and the tyre to rim combination
    must be in accordance with the Tyre and Rim Standards
    Manual published by the Tyre and Rim Association of
    Australia. Reputable tyre retailers should have this
    information and be able to advise on the correct
    combinations.
    All rims fitted to an axle must be of the same diameter,
    width and offset. They must not have a circumferential
    weld other than that which attaches the outer rim to
    the centre. All rims must have stud hole pitch circle
    diameters suitable to the hub. Wheel nut tapers must
    be appropriate to the wheel and must engage the thread
    of the wheel studs for at least the same length as the
    nuts provided by the vehicle manufacturer.
    Slotted and elongated stud holes are not permitted.
    The fitting of spacers or adaptors between wheels and
    hubs, additional to those provided by the vehicle
    manufacturer, is not permitted. The tyre and rim must
    not foul wheel arches or suspension components under
    any conditions. Steering limit stops must not be adjusted
    to reduce the turning circle in order to allow the fitting
    of the alternative rims and tyres.
    The tyres must have a tread depth of at least 1.5mm on
    every part of the tyre that touches the road and not have
    any apparent defect that is likely to make the vehicle to
    which they are fitted unsafe. It is not permitted to fit
    tyres that have been treated by recutting or regrooving
    unless the tyre has been marked by the original
    manufacturer as ‘suitable for recutting or regrooving’.
    Tyres
    The maximum tyre width for a car or car derivative must
    not be more than 1.3 times the vehicle manufacturer’s
    widest optional tyre.
    However, for an off-road passenger vehicle fitted with
    front and rear beam axles, the maximum tyre width
    must not be more than 1.5 times the vehicle
    manufacturer’s widest optional tyre.
    The nominal width of the narrowest tyre fitted to a
    vehicle must not be less than 70 per cent of the nominal
    width of the largest tyre fitted and never less than the
    vehicle manufacturer’s narrowest optional tyre as
    indicated on the manufacturer’s tyre placard.
    Sep 2008
    part 4 i think: 20 21
    Speed and load ratings
    The speed rating of all tyres must be:
    • a speed of at least:
    for an off-road passenger vehicle – 140km/h
    for another car (sedan, station wagon etc.)
    up to nine adult seating positions or a car
    derivative – 180km/h
    for another motor vehicle – 120km/h
    • the vehicle’s top speed, if lower.
    Load ratings of tyres must be at least equal to those
    specified by the manufacturer on the tyre placard fitted
    to vehicles made after 1972. For other vehicles, the load
    rating of a tyre must be capable of carrying the part of
    the vehicle’s gross mass carried by the tyre.
    Tyre construction
    Tyre tread compounds, patterns, ply ratings and
    performance characteristics vary. Tyre construction
    (e.g. radial) and size must be the same on the same
    axle. Although it is recommended that the tyres are
    identical (e.g. same brand and tread pattern), this is
    not mandatory.
    Vehicle track
    Track is measured at ground level from the centre of the
    tyre on one side to the centre of the corresponding tyre
    on the opposite side of the vehicle. Front and rear track
    differs on many vehicles.
    The wheel track must not be reduced to less than the
    standard track specified by the vehicle manufacturer
    for the particular model of vehicle.
    The track of a car or car derivative may be increased
    by up to 26mm beyond the maximum specified by
    the vehicle manufacturer for the particular model of
    vehicle. Off-road passenger vehicles fitted with front
    and rear beam axles, may have an increase in track
    up to 50mm beyond the maximum specified by
    of vehicle.
    Wheel marking
    Vehicles built on or after 1 July 1985 must be fitted with
    original wheels or replacement wheels which
    are indelibly marked in accordance with approved
    standards.
    These standards include:
    • Standards Australia
    • Wheel Industries Association (Australia)
    • Technischer Uberwachungen Verein
    • Japanese Industrial Standards.
    Markings must include diameter, width, offset and the
    manufacturer’s trade mark or logo and be located so
    that they are readily visible when the wheel is correctly
    installed on the vehicle.
    Composite wheels
    The use of composite wheels (two or three-piece) is
    permitted. They must be manufactured and marked in
    accordance with the standards described above if fitted
    to vehicles manufactured on or after 1 July 1985.
    Front
    Track
    Rear
    Track
    22 23
    Repairs to tubeless tyres
    Permanent repairs can only be made when the tyre is
    removed from the rim. The tyre must be examined to
    ensure it is structurally sound. The damaged area must
    be prepared on the inside for a patch or mushroom
    headed plug to be fitted and vulcanised into position.
    Any repairs to a tyre must be sealed to prevent moisture
    or contaminants from entering the tyre casing or
    structure.
    Caution: Plug repairs can only be made in the tread area
    of the tyre and not in sidewalls or where the tread and
    sidewall meet.
    Punctures in tubeless tyres must not be repaired from the
    outside or without removing the tyre from the rim as
    this method is prone to failure.
    Vehicle owners with doubts on tyre repairs should
    contact a reputable tyre dealer for proper repairs.
    Section 2
    Complex
    modifications
    More complex modifications than those types already
    listed in Section1must have approval. Such modifications
    include replacement non-standard engines, gearboxes and
    left to right hand steering conversions.
    A simplified method for
    obtaining approvals
    While there are some modifications which still require
    approval from Queensland Transport, most approvals can
    be obtained through the Approved Person Scheme which
    operates throughout Queensland. This scheme allows
    quick and convenient evaluations and approvals.
    What can Approved
    Persons approve?
    Many modifications can be approved by Approved
    Persons, and include:
    • Engine Substitution
    • Turbocharger and Supercharger Installation
    • Transmission Substitution
    • Rear Axle Replacement
    • Differential Substitution
    • Brake System Substitution
    • Convertible and Cabriolet Conversion
    • Passenger Vehicle Extended Wheelbase Conversion
    • Individual and Low Volume Vehicles
    • Panel Van to Utility Conversion
    • Roll Bar and Roll Cage Installation
    24 25
    • Street Rod Certification
    • Seating Capacity Alteration and Seat Belt Installation
    • Child Restraint Anchorage Installation
    • Motorbike Seating Capacity Alteration
    • Fuel Tank Alteration
    • Australian Design Rule (ADR) Compliance
    • Pre 1972 Imported Vehicle Safety Compliance
    • Personally Imported Vehicle Compliance
    • Steering Conversion
    • Beaming and Torsional Testing
    The minimum standards for all of these modifications
    are contained in the Code of Practice – Light Motor
    Vehicle Modifications.
    What is the Code of Practice?
    The Code of Practice is a detailed manual which
    prescribes the standards for vehicle modifications.
    Check this Code for the standards relating to the
    modifications you are thinking about.
    All Approved Persons have the Code of Practice. Copies
    of the Code of Practice are also available through
    GoPrint retail outlets.
    How do Approved Persons
    approve modifications?
    They inspect the modified vehicle to ensure it complies
    with the Code of Practice. The Approved Person will give
    you a Certificate of Modification and fit a modification
    plate to the vehicle if the changes meet the required
    standards.
    How much do approvals cost?
    A fee will normally be charged by Approved Persons for
    any vehicle inspection and approval. This fee is not set
    by Queensland Transport. Approved Persons set their
    own fees, which may vary depending on the
    modifications and the time involved in the inspection.
    Who are Approved Persons
    and where do I find one?
    Approved Persons are employed by private industry and
    authorised by Queensland Transport to approve vehicle
    modifications.
    Automotive businesses throughout Queensland, including
    most service stations which issue Safety Certificates,
    have Approved Persons. The names and addresses of
    Approved Persons are available at Queensland Transport
    Do Approved Persons have to
    modify my car?
    No. You can still do the modifications yourself or
    have them done for you. However, it is strongly
    suggested that an Approved Person is consulted prior
    to commencement of any modification to find out the
    relevant standards for approval.
    The scheme allows Approved Persons to approve
    modifications done by others provided the modifications
    meet the standards set by the Code of Practice.
    26 27
    Why do I need proof of a
    modification?
    Driving a vehicle with non-approved modifications is
    illegal. A non-approved modified vehicle can be put off
    the road immediately by Police or Queensland Transport
    Inspectors. Drivers may also find that they are not
    covered by insurance.
    The Approved Person Scheme provides a quick and easy
    way to have most modifications approved and reduces
    the chance of a costly traffic fine or having your vehicle
    ordered off the road.
    Before you start
    Before you modify your vehicle, contact an Approved
    Person and make sure the modifications can be
    approved. Don’t risk disappointment by spending a lot of
    valuable time and money altering your vehicle only to
    find it cannot be approved and driven on the road.
    Section 3
    Specific
    modifications
    Modifications which are not covered by this booklet or
    the Approved Persons Scheme, or modifications which
    involve substantial structural changes to the body or
    chassis of a vehicle, require a written submission. A fee
    is payable for the evaluation of plans. Send submissions
    prior to commencing any modifications or alterations to:
    Policy Advice
    PO Box 673
    Fortitude Valley, Qld 4006.
    Applicants should supply as much detail as possible.
    Incomplete submissions, insufficient details or poor
    drawings will delay processing of submissions. As a
    guide, submissions should contain:
    • a completed ‘Motor Vehicle Modification Application’
    (Form No. F1854 available at Queensland Transport
    Customer Service Centres) and
    • drafted plans for any modifications or alterations
    involving structural changes. Plans, on A3 size
    drafting paper, should include dimensions, plan,
    elevation, end elevation and sections (where
    necessary), material description, and welding and
    machining details.
    A word of caution
    Modifying a vehicle for use on a road without obtaining
    prior approval, or permitting the use of a modified vehicle
    without approval, is a breach of Queensland legislation.
    If you modify a vehicle without the necessary approval,
    you could void your vehicle insurance and may be liable
    for prosecution.
    The permissible modifications outlined in this brochure
    have been developed in consultation with the vehicle
    manufacturers and industry.
    28 29
    Engine replacements
    Many manufacturers produce a series of models with the
    same basic frame fitted with engines of differing
    capacity. No approval is required if the smaller capacity
    engine is replaced by a larger capacity engine from the
    same series provided the brakes and suspension from the
    larger capacity motorbike are fitted and no modification
    is required to the frame.
    The fitting of any other alternative replacement engine,
    superchargers or turbochargers will require individual
    approval in accordance with Section 3.
    Steering gear and handle bars
    The handle bars of a motorbike must extend at least
    250mm, but not over 450mm, on each side of the
    longitudinal axis of the motorbike. This measurement
    does not include mirrors and lights.
    The lowest part of the hand grip on the handle bars
    must not be higher than 380mm above the attachment
    point of the handle bars to the motorbike. Hand grips on
    the handle bars must be fitted symmetrically.
    If the motorbike has the head stem as the steering pivot
    point, the horizontal distance from the midpoint between
    the head stem bearings to the centre of the front wheel
    must not be over 550mm.
    Offset triple clamps are often fitted to provide the
    motorbike with ‘a raked out’ appearance without the
    need to modify the frame. These are acceptable provided
    the trail measurement is not less than 75mm.
    Section 4
    Motorbike
    modifications
    Frame and suspension
    alterations
    Motorbike design is a complex task. Before modifications
    are made to a motorbike’s frame or suspension, you
    should be aware that structural changes to the frame,
    steering head, front forks, suspension, brakes or wheels
    may load vital components well beyond the limits for
    which they were originally designed. This may increase
    the probability of failure and may be a danger to the
    rider and other road users.
    Motorbikes with properly designed custom frames,
    extended forks, hard tail conversions and structural
    modifications are acceptable, but require specific
    approval as explained in Section 3. A report will be
    required from a Registered Professional Engineer
    detailing the changes and certifying that the motorbike
    is safe.
    30 31
    Seat reduction
    Compulsory Third Party (CTP) insurance premiums on
    motorbikes are determined by the seating capacity of the
    motorbike. Conversion of a motorbike from a
    two-seater to a single-seater, or vice versa, can be
    certified by an Approved Person as detailed in Section 2.
    For two-seats to single-seat conversion the maximum
    length of the upholstered section of the seat must be
    500mm or less, and the pillion foot pegs must be
    removed with any associated brackets and threaded
    holes drilled out. You are not permitted to use a
    removable cowl or other structure fitted over the seat
    to reduce the length of the seat. You should seek advice
    from an Approved Person before performing a seat
    reduction modification.
    Wheels and tyres
    On all wheels (including any side-car wheel), the tyre
    size must be suitable for the rim. Each tyre and rim must
    be strong enough to support the machine when it is fully
    loaded. Most major motorbike tyre specialists can tell
    you the right tyre and rim for your motorbike and the
    appropriate tyre speed rating.
    Chain guards
    If the motorbike has a chain drive, the driver and any
    passenger must be protected from the front sprocket
    and at least the upper part of the chain by the frame
    or equipment of the motorbike, or by a chain guard.
    A chain guard must cover the chain to a point at least
    300mm to the rear of the rearmost foot rest or above the
    centre of the rear drive sprocket.
    Motorbikes must be fitted with footrests for the rider,
    and for any passenger for whom a seating position is
    provided.
    Exhausts
    Motorbikes manufactured from 1 July 1975 are subject
    to ADR requirements for noise.
    Any replacement exhaust system must be as near as
    practicable to the original component specification
    and/or comply with ADR noise requirements.
    If you modify or replace an exhaust system on a
    pre-1975 motorbike, you must remember that the
    law prohibits all motor vehicles from causing excessive
    noise due to the condition or construction of the vehicle,
    or the manner in which it is operated.
    Motorbikes manufactured from 1 July 1988 have all
    components of the silencing system marked with the
    name or trade name of the manufacturer.
    These motorbikes carry information of the Stationary
    Noise Test in the following format:
    STATIONARY NOISE TEST INFORMATION
    Tested at............. dB(A) at........... r/min
    Silencing System: (manufacturer’s name)
    Identification: (trade description)
    Any replacement part of the silencing system must show
    the trademark or the name of the original manufacturer
    of the system.
    Mudguards
    Mudguards must be fitted to all wheels (including the
    sidecar wheel). Each mudguard must be at least as wide,
    over its entire length, as its respective tyre.
    A front mudguard must cover the rearward section of
    the wheel through the area between two lines, one
    vertical and the other horizontal, both drawn through
    the centre of the wheel. If suitable protection is afforded
    by the frame or construction of the motorbike, the front
    guard need only cover the unprotected area.
    The mudguard provided for the rear wheel and for the
    wheel of any sidecar must extend not less than from a
    point vertically above the foremost part of the wheel
    rearward to a point not higher than the intersection of
    the arc of the wheel guard with a line through the centre
    of the wheel at 45 degrees to a horizontal plane through
    Indicators
    Indicators are required on all motorbikes manufactured
    after 30 June 1975.
    Sidecars
    Sidecars must be fitted to the left hand side of a
    motorbike. This does not apply to a motorbike and
    sidecar combination greater than 30 years of age.
    When a sidecar or side-box is attached to a motorbike
    manufactured after February 1976, a mechanical parking
    brake must be fitted.
    The maximum width of the combination, including any
    load and equipment, must not exceed 1.85m.
    Motortrikes
    Motortrikes that are constructed by removing the rear
    swing arm and substituting a suitable after market or
    self-constructed rear axle assembly and body work are
    considered to be a modified motorbike, if the motorbike is
    substantially unmodified forward of the swing arm pivot.
    The vehicle does not need to be updated to comply
    with current ADRs apart from those required as part
    of the trike conversion. For example, if the motorbike
    was not required to operate on unleaded fuel when
    manufactured, then it would not be required to be
    converted to run on unleaded fuel as part of the
    trike modification.
    The kit or owner designed and/or constructed assembly
    must be examined by an Approved Person with code
    LO1 to ensure it is suitable for the motorbike.
    You should contact an Approved Person as detailed in
    Section 2 about obtaining approval for this modification.
    32 33
    hope this helps mate
    Sep 2008
    Quote Originally Posted by XhArD View Post
    Thanks fuzzy, I didn't see it but I'll take another look
    no worrys mate ...... it took me like 1hour to find it
    Stressball's Avatar
    Mitsubishi Triton
    Oct 2005
    SE QLD
    Thanks muchly for that, I found it 2 minutes after you first suggested it, had a look through.. As far as I can gather from that, the only thing I can see fairly clearly is that extractors can be replaced. Performance-wise there's not a lot else in there.. The whole section on Engines, requiring a plate, isn't very specific. For example, things like say, a new K&N panel filter. Not exactly an engine part.. But doesn't fit anywhere else.
    If anybody is able to clear this up further that'd be great
  1. New Plates soon.. Reverting temporarily to AA plates
    By Holden_ve in forum VT - VX - VU - WH - V2
    Last Post: 03-08-2006, 01:14 AM
  2. VK EFI 6 - modification
    By kurtbarker in forum Straight 6 Development And Modification
    Last Post: 20-09-2005, 02:30 PM
Tags for this Thread
