Results 1 to 24 of 24
Thread: Lesson Learned! Dont Make The Same Mistake I Did! Read Please!
    social's Avatar
    social is offline Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    Exclamation Lesson Learned! Dont Make The Same Mistake I Did! Read Please!
    ok, i learned my hard lesson about Red Oil lights.
    Simply if you get a little red oil light come on in your vn, i thought it ment that low on oil, so 30kms later i decided to top it up. TOO LATE! DAMAGE WAS DONE! Bad noises started coming from the engine. Determining it Absolutely Scrwed.
    THE REASON THE LIGHT COMES ON IS BECUASE THERE IS NO OIL PRESSURE. If you drive a vehicle wid no oil pressure more than 500metres you might aswell say goodbye to it, the damage wil be done.
    Im currently now looking for a replacement engine for my car, *waves fist* simple ignorance cost me a new engine + installation. Its gunna suck.
    So last point, if its a red light. STOP EVERYTHING! Dont just guess, get your manual out and follow its instructions.
    Thanks for reading.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Vn_Manual08 View Post
    Thanks for reading.
    Bit of bad luck there mate.
    Hint when you get the engine replaced - the timming cover on your old engine if not corroded would be worth a few bob.
    New timming covers for a S1 VN are around $400.
    and 3 Dangerous non ABS VN's
    vs calais eco
    Sep 2006
    Disney land!
    Just did a trip to gympie, but before i left did the usual check of everything and turned out my oil was not even registering on the dipstick!! My oil light however was not showing but it still pays to check ect 2ltrs later and she was right as rain and ran alot smoother quiter
    social's Avatar
    Nov 2008
    South Aus
    88GreenVN,
    where exactly is the timing cover on my engine and why is worth a bit?
    88GreenVN's Avatar
    Jun 2006
    88GreenVN,
    Behind the water pump and they all corrode if people dont run coolant.
    social's Avatar
    Nov 2008
    South Aus
    i just had a look, mine looks all in order and not rusting or nything thanks for the tip
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    hard luck. may your pain save someone elses engine i always check my oil level on a regular basis and it never gets lower then half way between the "full" and "add" marks.
    if red oil light comes on, idle engine and pull over as fast as possible then switch engine off. don't shut down the engine untill you ahve pulled over otherwise you wil loose your power assisted steering which could be dangerous.
    Body by Holden, Soul by Brock
    the Legend will live forever
    HSV +6
    Mar 2006
    Mornington Peninsula
    VT
    Apr 2005
    QLD
    If you see the red light, you've got about ten seconds.
    There was a problem with the Gen 3's when they first came out with oil control issues, there are stories going round about cars losing oil pressure and drivers being to slow to react and lunching engines. Even the C4B's weren't immune.
    Long story short, if you lose oil pressure, you're relying on a thin film of oil to keep metal off of metal, this doesn't last long with no oil being pushed through the galleries.
    Hard Luck mate, lesson learned.
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    MMMM funny. My mate vp had that light on for like a week... the car still got that engine in it. Maybe different issue.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by AttaBoy View Post
    Can be just a broken wire on the oil pressure switch as was the case with the 89 geen sedan.
    Stuck the wire back in and the lights gone out. We were lucky I think
    TUF UTE's Avatar
    TUF UTE is offline Dave
    05 VZ SENATOR
    Nov 2008
    adelaide
    if u get stuck ill fit a motor for u AND a oil pressure gauge just to be safe
    SIR LS1
    the two ton go kart
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
  15. #15
    social's Avatar
    Nov 2008
    South Aus
    hi Norti,
    I may be fairly interested, just came on forums, from wat car model we talking and wats some details mate?
    PS: Dave, just curious to know mate but are you a hero or am i just imagining things!?! :| Once i got my hands on a enigne i would so very much appreciate a hand
  16. #16
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    This is why anyone who appreciates their car has an Oil pressure gauge fitted
    Bad luck on the engine
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
  17. #17
    social's Avatar
    Nov 2008
    South Aus
    i appreciated my engine I just...err...il blame the fact im 17 and have a little letter in my window that is well known as a P...
    but all in all i shuda read my manual...pity for thinking i know my cars lol
  18. #18
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    oil gauges can go in others cars except excels lol and yeah im a hero * flexes biceps * lol
    SIR LS1
    the two ton go kart
  19. #19
    FG XR6T Ute manual
    May 2007
    Brissy
    Quote Originally Posted by VT-565 View Post
    Amazingly i drove dads old au 5ltr around 20 - 30 minutes with little to no oil in it. turns out the oil pressure sender died somehow making the oil guage just freeze and being on the highway with the stereo up didnt help matters. wasnt till i got off the highway that i heard the horrific noises. checked the dipstick no oil. The next day dad replaced the sender and refilled it with oil and it runs fine
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
  20. #20
    NORTI's Avatar
    May 2004
    hi Norti,
    From a VP, so series II motor, have replied to PM.
  21. #21
    VT
    Apr 2005
    QLD
    Quote Originally Posted by f1tzy View Post
    Just because there is no oil on the dipstick, doesn't mean there is no oil in it. Not all dipsticks go right to the bottom of the sump lol
    I've heard of some old diesel engines getting away with this, but I think in your case, there might have still been oil at the pickup, hence the engine running for half an hour and living still lol
  22. #22
    TUF UTE's Avatar
    05 VZ SENATOR
    Nov 2008
    adelaide
    hey guys he needs a series 1 engine as he has series 1 flywheel and manual in his car, and the series 1 cooling setup
    SIR LS1
    the two ton go kart
  23. #23
    VP Calais '93
    Mar 2006
    SA- NE BURBS
  24. #24
    social's Avatar
    Nov 2008
    South Aus
    *waves fist* well no1 likes that light nyways....
  1. Lesson to be learned from typing the wrong email address:
    By leon archer in forum Jokes/Humour
    Last Post: 28-04-2007, 09:39 PM
  2. Lesson learned: Driver's Airbag
    By SPack in forum VY Holden Commodore (2002 - 2004)
    Last Post: 13-02-2006, 02:10 PM
  3. Warning if you dont read your a fool
    By WILD VR CLUBBY in forum General
    Last Post: 14-11-2005, 03:32 PM
  4. lesson learned
    By Patrio7 in forum General Discussion
    Last Post: 25-10-2005, 04:34 PM
  5. A lesson to be learned....
    By rattattack1313 in forum Jokes/Humour
    Last Post: 29-07-2005, 05:10 PM
