Hello,
I have a vz calais aloytec 6cyl , Now ive been searching around on what would be the best for airflow ( pod filter , ss inductions etc) , Ive decided ill have a go at the two hole mod ,
I have read and read different forums and theres a few things I don't quite understand , Does the VZ models already come with a MCAI? , and I also want to see has anyone else done this to there vz 6cyl if so how has it turned out , ive only really found 8cyl's that have had it done and liked it
thanks in advance
jsd
take a look in the vz tech section, and take a look at my ride thread, I have pics of the process.
you need to buy the mcai from holden, costs about $20
I don't know all that much but I called holden and enquired and said these exact words "Monaro Cold Air Intake" he said something like they are just a stadard something or a rathe andthere is no "Monaro Cold Air Intake" something like that!
Bottom box $39
Scoop - $22
which am I after? or both for that matter
You can do what I did, take your box out and modify that or buy a new VZ air box, modify that and swap it in when its done, its up to you!
As for the MCAI shroud, look at the VZ forum there are a few threads on the two hole mod the part number is in there. Give Holden that part number.
take a look at my custom intake. a few other members are happily running the same setup.
AIR INTAKE MOD COMPLETE - Better than 2-hole mod?
