Results 1 to 12 of 12
Thread: Auto to Manual - been asked a too many times i know but............
    '01 VU Ute, Manual 5.7
    Nov 2008
    Default Auto to Manual - been asked a too many times i know but............
    hey, can anyone give me a list of parts i would need if i was going to do this conversion. also a link to a step by step guide on how to do it would help. weighing up whether or not to do it.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    A simple search will reveal a lot
    Morton's white VQ Statesman
    The complete Vn-Vr Manual Conversion Guide.
    However I think the relevant clutch bits for the VT may be hydraulic, which complicates things a little
    Does anybody know if it's possible to rig up a T5 on the backside of a VT 304? I'm assuming there would be differences in the pedal positions on the firewall, although I could be wrong.
    The 1972 HQ Kingswood
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by Morton View Post
    dont see why not, 304 is the same VN-VT so yeah...
    Pedal positions is based on the pedal box so assuming you can find a VT manual pedal box, good luck, then you should be fine.
    VT did use a hydrolic clutch setup, so, assuming you can find all the bits, it is possible.
    aZk.
    Haydz's Avatar
    Haydz is online now 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    Morton's Avatar
    May 2006
    I would assume that the VT pedal cluster wouldn't be designed to work with a cable setup. It would have something similar to the brake booster setup on the engine side of the firewall.
    Nov 2008
    so the VT uses a hydrulic clutch and previous models use a cable. can i use any type of T5 gearbox say from a VN-VS or do i need a vt model gearbox?
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    Morton's Avatar
    May 2006
    Quote Originally Posted by .Holdon. View Post
    I'm not sure if a T5 would even match up, but I don't see any reason why it shouldn't. All I know is that VT manuals were either the Getrag 5sp or T56 6sp. I'm not sure which trans was mated to the 5.7 though. Pretty sure you'd find the T56 on the LS1, and the Getrag on the S1 VT with the 304.
    You're probably best off grabbing all the manual bits from a similar series VT V8
    VS Ute
    Jul 2009
    i wanna put a t5 gear box in my 95 vs is i was to het one out of a vr to do a conversion what would i have to change to make it suit? sorry f this is irrelevnt but i have looked everywhere and i cant find a straight answer
    VR, VX, VN Commodore's
    Dec 2008
    Quote Originally Posted by azkwazere View Post
    aZk.
    you mean by vn - vt where the box bolts up? cos im sure the VT 5Ltr's are roller motors
    EDIT ' sorry, didnt read your post properly'
    Dont Take Life Too Seriously, You Never Get Out Alive Anyways.
    2002 Series II VX SS - 6spd - 5.7L - Black - Red Leather <3
    Nackerz's Avatar
    Nackerz is offline Rollin
    2 n/a vl's 1 twin turbo vl vn ss vy sv8
    Jul 2009
    i have a right up on the vl tho its from calaisturbo but have a look in the vl section that might help a little bit
    Nackerz's Avatar
    Jul 2009
    Thread for people that keep asking about auto to manual conversion
    thats the vl one but could give you some idea on how to
  1. auto to manual
    By mickla in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2008, 02:38 PM
  2. Auto to manual???
    By kimmys~vs~calais~sII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 07:46 PM
  3. Been asked a million times, so i'm gonna ask it again..
    By GROWLZ in forum LSx Development and Modification
    Last Post: 05-11-2006, 12:16 PM
  4. best manual shift times in auto ?
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-03-2006, 04:47 AM
