Results 1 to 2 of 2
Thread: Oil Leak
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Default Oil Leak
    Im 99.99999% sure I have oil ****ing out of my oil pressure sender, where the sender goes into the block.. Does anyknow know how to get these bloody things out (5.0L - VP) I may need a bigger spanner/shifter (25mm) but I have tried multigrips but it seems to be soo bloody tight.. any ideas?
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    sounds like your trying to actually undo the sender using the body, there is a hexagon fitting underneath the main body (where it screws into the block) that you should be able to get a spanner on. from memory it's 13mm (or 1/2")
    me bad, the sender screw into the side of the oil pump, make sure the 4 bolts that hold the oil pump onto the block are also tight
    Body by Holden, Soul by Brock
    the Legend will live forever
  1. Oil leak
    By boojak87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-08-2007, 11:48 AM
  2. oil leak in 1 day old vt
    By rekless driver in forum General
    Last Post: 09-12-2006, 09:13 PM
  3. Oil leak on VS
    By julandi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-10-2005, 07:50 PM
  4. oil leak :(
    By VNPOWER in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2005, 12:15 PM
  5. Oil Leak
    By paullmichelle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2004, 10:15 PM
