I have a vx commodore 2000 i have changed the radiator, thermostate, water pump, isolator, the temp gauge rises to hot for around 15 secounds then back down to normal temp it happens a couple of time in a day.
need some feed back on this issue people
sounds like a possible air lock.. did you bleed the system properly?
yes once when replacing the radiator and once again when changing the thermostate.
I see this over and over again, being a mechanic and hearing stories about people having over heating problems and replacing everything and finding no solution. First i would check the connection between the temp gauge and the sender on the engine. Then i would check that your thermo fan is working and comes in at the correct time. Also if you wanted to get a temperature probe and check what the temp actually is. These easy checks will save you lots of $$$$$$.
