Results 1 to 4 of 4
Thread: Stage 2 vs Stage 3 shiftkit
    VN Calais 5L
    Dec 2005
    Default Stage 2 vs Stage 3 shiftkit
    Just a quick inquiry.
    Running a stage 2 shiftkit compared to a fully manualised stage 3 shiftkit would the stage 2 shiftkit be quicker off the marks then a stage 3, i would assume so.
    Being that stage 3 you have to go through the gears.
    Anyone got a stage 2 or stage 3 who can validate or debunk the inquiry?
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    i would think that the stage 2 would be quicker as with stage 3 you have to go threw the gears, but stage to wouldnt be much quicker...
    i got a stage 2 shift kit in my car and the gear chnge from 1st to 2nd is pretty firm
    betts's Avatar
    betts is offline Double banger
    Built toyota surpa
    Nov 2005
    Just around the corner
    I don't think there would be any difference at all, as long as you knew exactly when to shift when using a stage 3.
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    Alot of the time the auto can shift ebfore its meant to, like in my car, so the only way to get peak performace is to manually change gears. I do this at the drags, only have a stage 1 shift kit. I say, if your serious then you will shift it manually if it has a stage 0,1,2,3 kit in it. Its okay to shift up gears but not too good going down gears. Its about weather you want to drive a clutchless manual arround town or be a lazy jew.
  1. stage 2 shiftkit brizzy???
    By 17UCK! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-09-2008, 09:46 PM
  2. stage 3 cam
    By Archers in forum V6 Development And Modification
    Last Post: 08-04-2008, 11:29 PM
  3. Stage 3 cam anything to look out for?
    By mws in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 07:55 AM
  4. stage 2 shift kit?
    By Sabby in forum VL Holden Commodore (1986 - 1988)
    Last Post: 02-01-2007, 12:13 PM
  5. vn stage 3 shift kit
    By VN-88 in forum Parts And Other Items For Sale
    Last Post: 07-05-2006, 10:24 PM
