i just a written off ve ss wanna transfer everything into my vs has it been done how had is it to do
easy to do, hard to get it legal
BAD COP!! NO DONUT!!
should be ok, just check with vic roads or equivalent depending on which state your in and check if ok as you already have a v8 from factory or if you need an engineers due to it being a larger compacity v8, should be ok as your car is v8 from factory, but just check incase, only major thing you'll need from the sounds of it is a custom tail shaft depending due to transmission-diff length, but sounds like a good project and one very quick car, a nice cam in the ve motor before it goes in with the right exhaust would have it rocking
good luck with it.
As above, what state?
How did you write it off?
sounds like he bought a written of ve.
