Results 1 to 6 of 6
Thread: Installing Foglights VZ Adventra
    VP Executive & VZ Adventra V6
    Sep 2006
    Default Installing Foglights VZ Adventra
    Hi All,
    Hope someone can give me some advice, I am going to be installing some fogl ights into my Adventra and just wondered if anyone know's how to remove the factory plastic covers that Holden put in instead of the fog lights. I don't want to start bashing around in case there is a trick to it. I attached a picture to show you what I mean. Any advice would be great.
    Pete
    Attached Images Attached Images
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    You could probably push the covers out from inside the front bar, there will be some clips that keep it in place.
    Unless the covers are part of the front bar! you'll be outta luck.
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Sep 2006
    Quote Originally Posted by PaulSV6 View Post
    Thanks Paul, I can move the covers around, so I know they arn't part of the actual front bar (thank goodness). I will keep trying to figure it out. If I do I will post it on here in case anyone else tries to do it.
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    from memory when i did the VX they push out from the rear, they do just clip in
    Search for VX or VY or VZ fog lights, its all the same setup.
    You also ned the new healight switch with pullout fog light switch and the relay
    The SX6 doesnt look right without them, dad wasnt going to order his with them until I pointed out how ugly they look, their designed to have them so why not have em even if you never use them
    Sep 2006
    Quote Originally Posted by Torquative View Post
    Thanks heaps Torquative, I will take your advice. If I get them out without destroying my whole front bar I might put together a quick "How to" I have been wanting to do one for ages, but everyone seems more knowledgable than me LOL
    Sep 2006
    Thanks for everyone's help. I have now installed my foglights and new headlight switch into the VZ Adventra. A lot easier than I expected, all the wiring was there, all I needed to do was install the actual fog lights, insert a relay into the relay compartment, and put in a new headlight switch that allowed for fog lights. Everything works, even the little dash light that says you have your fog lights on.
  1. VZ Adventra SX6/CX6
    By Torquative in forum General
    Last Post: 04-02-2011, 05:23 PM
  2. What was so bad about the Adventra?
    By Scooter79 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-02-2011, 01:45 AM
  3. Gen 111 Adventra
    By MORT in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-12-2008, 11:17 AM
  4. Adventra
    By Stretchomatic in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-06-2005, 10:12 PM
  5. VZ Adventra
    By chris87 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-09-2004, 10:49 PM
