Results 1 to 3 of 3
Thread: Auto to Manual speedo solution
    muttley383's Avatar
    muttley383 is offline Donating Member
    VR 383
    Sep 2007
    Default Auto to Manual speedo solution
    Hi,
    some may be interested in this device I have recently fitted to get the speedo working after a manual transmission conversion from an auto.
    I used a product called speedohealerV4 on a VR commodore. I had to get the manufacturer to customise the unit to have a hall effect 3 wire input and a 2 wire magnetic output. This unit allows you to retain your auto PCM and still have the speedo working. Ie: set the unit for approx 950% and use the output of the device to feed the PCM as normal and in turn the PCM drives the speedo.
    The unit is the size of a match box and has an adjustment range from -99.9% to 9999.9%.
    The unit cost me 96.00 Euro delivered from Hungary but they do have Australian sales agents, although the custom units would not be stocked.
    Info can be found at/www.healtech-electronics.com/
    Attached Images Attached Images
    muttley383
    Marcho is offline Marcho"s R.I.D.E
    VR Accliam S2
    Jan 2009
    Armidale N.S.W
    NA 3.8 VS Ute
    Sep 2009
    No fixed address, Auckland, NZ
    Ok so I emailed them and received this reply;
    "Cost is 84 EUR + 8 EUR shipping.
    You can place an order on this page:
    HealTech Electronics Ltd.
    Select the "SH-V4-2W Kit"
    and during the checkout, mention in the Notes:
    "3 wire Hall effect input/2 wire magnetic output"
    YeeHaaa take that Auto ECU !!
    T5 into my VS with Auto ECU here I come!
    "Life's a dare, push yourself, F#@k it you might like it. Live on the edge. It could all stop tomorrow"
    - Jimmy Barnes twitter March 2011
    3.8T Wagon
  1. VR Manual Conversion - How to Get you speedo working again using the auto harness
    By mal62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-05-2010, 03:35 PM
  2. Speedo stopped working on Manual 3.8 VN
    By bjj in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-04-2009, 06:52 PM
  3. VN manual now with a VR Series II motor w/auto loom but a manual. Crank'n issues
    By Illuminatis in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2009, 07:03 PM
  4. v6 auto conversion. speedo?
    By Panama in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-02-2009, 09:26 PM
  5. Need some help!!!! abt speedo sensor on Vr (auto to manual conversion)
    By holdenrocks in forum Electrical Wiring / Questions
    Last Post: 29-03-2008, 08:20 AM
