hi everyone i have had some crud get in to my engine and i think that it is either blocking a port in the intake manifold, or keeping one of the valves open, what can i do to remove it ( preferably with out removing anything )
What do you think is in your engine, and where do you think it is?
A flush is normally refering to flushing the cooling system, but if its in your intake manifold or heads then a cooling system flush will do nothing. Depending on what it is, and where it is I dare say your going to have to pull shit off to get to it. Oh and how did it get in there?
define "crud".
for all values of "crud" where "crud" equals "bolt", disassemble engine and remove
for all values of "crud" where "crud" equals "my hat", rev hard and hope it goes away
for all values of "crud" where "crud" equals "iPod", just leave it, it's for the best.
The 1972 HQ Kingswood
crud = junk, rubbish, crap, etc, etc
story = my engine crapped itself
there is also an engine oil flush treatment using mineral oils to brake down the "crud" in the oil galleries, sump and oil pump.
buy it at most places there are a few different brands.
add it to your current oil idle the engine for about 10-15 minutes dump your oil and remove the filter, replace with fresh oil and a new filter.
do not drive the vehicle or high rev the engine with the flush in.
Nobody wants to play with me
and 3 Dangerous non ABS VN's
