+ Reply to Thread
Results 1 to 13 of 13
Thread: Comfort "sports" shock
    danja's Avatar
    danja is offline Swerves for gay koalas danja W427 danja W427 danja W427
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Default Comfort "sports" shock
    Hi Greg,
    I have a VZ SS, just ticked over 80,000kms, and I suspect the shocks are the same ones it rolled out the factory with.
    They are due for a change, and I'm at a crossroad, deciding wether I just put another set of FE2 in there, or go aftermarket in search of something better.
    I'm after something which maintains (or hopefully even improves) on the ride comfort of the FE2, offers better than OEM handling, and hopefully doesn't break the bank.
    I realise I might be asking the impossible with those 3 criteria, but figure it's worth a shot.
    I've come from a car with Billies, stiffer springs, swaybars etc all round, so I know what I can get with money to throw around, but that's not what I'm after this time. I really just want something a little better than FE2, without going so far as to have to make compromises to comfort. If that costs an arm and a leg then I'll just be going FE2 again.
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Apologies about the late reply. If you're just after a slightly-better-than-OEM replacement shock, it's hard to go past either KYB or Boge.
    Prices as follows:
    KYB Front $159 each
    KYB Rear $67 each
    Boge Front $140 each
    Boge Rear $69 each
    I'd personally go the KYB, but the Boge have a lifetime warranty and are quite a good shock.
    Shipping to you would be $22.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    danja's Avatar
    Jan 2006
    Quote Originally Posted by gslrallysport View Post
    Hi mate,
    Prices as follows:
    KYB Front $159 each
    KYB Rear $67 each
    Boge Rear $69 each
    Regards,
    Greg
    Cheers Greg, no need for apologies.
    I am just after slightly-better-than-OEM, my biggest condition is not sacrificing ride comfort.
    Which model are those KYBs you quoted?
    VZ AWD One Tonner
    Jul 2006
    Excel G, there isn't any other model of KYB for the Commodore (except for some AGX).
    If ride comfort is the biggest concern, maybe go with the Boge...
    Junny's Avatar
    Junny is offline purrrrrr Junny Executive
    VUII Maloo + shitty painted vp
    Hangman Champion!
    Jan 2009
    sorry for intruding. but how much would a set be for a vy ute?
    and can i get comfy ones for them? i carry stuff on the back once every now and then.
    Hit the star under this post if it was any help to you =D
    danja's Avatar
    Jan 2006
    Cheers Greg, hadn't heard of Boge till you mentioned them. I'll do my homework and get back to you
    @Junny, maybe airbags would be good for your situation?
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Junny View Post
    Hey mate,
    Sorry about the late reply! Is your ute a normal ute, or one toner?
    Cheers,
    Greg
    VT 2
    Nov 2008
    Boge's are what I run in my VT.
    They're Czech made, and are used by huge european OEM's - specifically Audi and Mercedes Benz.
    In My VT with low springs (not super lows) and a full set of bushes and etc, on 17" wheels, I find the ride... stiff. Not harsh, and great on the smotther highways, but rougher roads transmit cabin noise, and can be a bit noisy. It's probably not entirely the shocks fault, but they certainly feel pointed at the stiffer end of the market.
    I find the handling with them is nothing short of awesome. I grip like all get out, predictability is high, and there is no residual 'nervousness' on the edge. I can hang the tail out with confidence, and even sideways in the wet i feel positively in control. Again, this is not all the shocks doing.
    As with most VT's, they bite back when you pick up grip after being sidewise. I haven't done a camber control kit in the rear, and I think that's part of the reason, but they will snap back on you.
    I have no problems recopmmending the brand - they have been faultless.
    danja's Avatar
    Jan 2006
    Thanks for the info Tsunamix, I think I might bite the bullet and go for a set. They'll be running with FE2 springs, which are probably a little softer than yours.
    I'll shoot you a PM Greg when I'm ready to put an order in.
    VZ AWD One Tonner
    Jul 2006
    No dramas at all. Speak to you then!
    VT 2
    Nov 2008
    94 VR Statesman
    Aug 2006
    Hi there mate after a superlow look with real nice comfort in a Statesman would i be better off going with Superlows and BOGE or is there a coilover option i might be able to go down (car will be drag racing occasionally aswell) just throwing some ideas around lemme know!
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Sorry about the late reply! I'd still go KYB because they have dedicated shortened shocks to suit. Boge do as well, but they're more suited to low, not super low. For springs and shocks to suit would be $675 for the kit. May also need a 4 pt camber kit, and a Whiteline one of these is $175.
    With regards to coilovers, what's your budget?
    Regards,
    Greg
+ Reply to Thread
  1. Pedders Sports Ryder vs Comfort Gas
    By occtec in forum VE Holden Commodore (2006 - ?)
    Last Post: 29-05-2009, 06:20 PM
  2. Replies: 13
    Last Post: 26-03-2009, 05:34 PM
  3. ""need help"" own a stocko 3800 vp and wanting to really give it some horsepower
    By boourns in forum V6 Development And Modification
    Last Post: 19-07-2008, 05:59 PM
  4. WTB: VR - VS? IRS Cat-Back Exhaust in SA. Prefer Stock not "Sports"
    By VHSLX3300 in forum Swap / Wanted to Buy / Trade
    Last Post: 21-01-2007, 07:26 PM
  5. "sports Suspension"
    By WeeMan in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2004, 09:26 PM
