+ Reply to Thread
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 51 to 75 of 86
Thread: VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
  1. #51
    VT SS S2 A4
    Aug 2005
    Hi Greg, I have sent you a PM in regards to this item
    Brendon
  2. #52
    VZ AWD One Tonner
    Jul 2006
    QFM A1RM again outperforming expectations on the track!
    GSL,
    The pads arrived and were fitted up just in time for a recent club track day at Wakefield Park.
    To be honest, I was absolutely amazed at their performance. They work well from cold and have so far not made any noise. When warmed up (one or two corners at the most), their bite was unbelievable (on my MX5).
    It felt like I had the car standing on its nose braking into Turns 2 and 10 at Wakefield!
    Their performance allowed me to brake much later than I have previously and I actually had to mentally refrain from hitting the brakes early.
    And the best thing, they make minimal dust!
    Regards,
    Tony
    No link available, sent via email.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  3. #53
    AirStrike's Avatar
    AirStrike is offline Site Administrator AirStrike W427 AirStrike W427 AirStrike W427 AirStrike W427
    2009 G6ET
    Jul 2003
  4. #54
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    The VE V8 rotors are 322mm x 30mm.
    Regards,
    Greg
  5. #55
    VZ AWD One Tonner
    Jul 2006
    Sam, sorry no chance unfortunately.
  6. #56
    VK
    Jun 2010
    The VB-VR conversion hubs use 12mm studs, as all Commodore's till the VE. Now the VE uses 14mm studs. So with this conversion you are mixing 12mm studs with 14mm hole discs. Unless the disc come drilled with 12mm holes, there is rocking on the studs, correct?
  7. #57
    VZ AWD One Tonner
    Jul 2006
    The rotors used in the conversion kits are not standard VE rotors, they are specially machined and have 12mm studs.
  8. #58
    Tom_1569's Avatar
    Tom_1569 is offline Ecotech Power Tom_1569 Senator Tom_1569 Senator Tom_1569 Senator
    VS Ute - Daily, VT - Spare, 80 Series - W/E Bus
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by gslrallysport View Post
    Just out of curisoty.
    When it comes time for me to replace my rotors, what options are available, am I able to get other brands in 322mm, or am i limited to RDA?
    Quote Originally Posted by alien View Post
    I have been hit by oil badly once while in Army uniform on a massive roundabout that doesn't exist anymore. Spun 180 degrees to face oncoming traffic.
  9. #59
    VZ AWD One Tonner
    Jul 2006
    Would be RDA only, who are keeping replacement rotors on the shelf, I am awaiting pricing, but it shouldn't hurt too much...
  10. #60
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Cool, let me know roughly on a price of 322mm slotted and dimpled, so I know how much Im up for come crunch time.
  11. #61
    VZ AWD One Tonner
    Jul 2006
    QFM HPX fitted to Mitsubishi Legnum VR4!
    Awesome pads, No dust no noise. Worked far better then my previous set of Bendix Pads. Recommend to anyone whether you drive an import or not!
    Qfm High Performance Brake Pads - Boostcruising.com
  12. #62
    mischa's Avatar
    mischa is offline Mmmmm, 4 bolts.... mischa Calais
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Can somone tell me if the stone gaurd/plate thing that sits behind the stock rotors will go back on after i put the VE rotots on?
    The Daily VN T5V6
    355 VN GRP A REP
  13. #63
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by mischa View Post
    On a VS, with the conversion it needs to be hacked at a fair bit, but definitly leave it on, just cut it to fit the brakes.
  14. #64
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Quote Originally Posted by Tom_1569 View Post
    Hey Greg, how'd you go with those prices?
  15. #65
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    I thought i might have to, just cut the lip off from around the edge?
    The Daily VN T5V6
    355 VN GRP A REP
  16. #66
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    I cant remember if I cut the lip or not.
    But where the caliper bolts, you need to cut the top and bottom so it fits, it will make sense once you do it. Just have an angle grinder or a dremel or something handy when you go to do it.
  17. #67
    VZ AWD One Tonner
    Jul 2006
    Sorry mate,
    Slotted are $249 for the pair, Gold Passivated Slotted and Dimpled are $365 for the pair.
    Regards,
    Greg
  18. #68
    Tom_1569's Avatar
    Nov 2006
    Gippsland - VIC
    Sorry mate,
    Regards,
    Greg
    Cheers mate. Are the slotted and dimpled available without the "gold passivated", like the stanadards ones in the kit?
  19. #69
    vs 5.0l
    Feb 2007
    Ok I'm trying to put VE HSV (AP racing 4 piston) Calipers and 365/350mm discs on a HQ.
    Any advice, Icant find anyone that has tried this.
    I'm only posting here because they are commodore brakes.
    Was hoping you guys could give me some info
  20. #70
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Unfortunately custom brake setups aren't something we deal in.
    Best of luck finding someone who can help.
    Regards,
    Greg
  21. #71
    VK
    Jun 2010
    Greg, I have a VK commodore with F90 Simmons 16" wheels, what Brakes and pads would you recommend for Track days?
  22. #72
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Were you wanting to upgrade your front calipers, or just pads and rotors?
    Ideally I'd go the 298mm VE upgrade kit as per the first post, $895, then get QFM A1RM pads all round ($238 for the vehicle set) and some rear slotted rotors, $149 for the pair. And that will do a bloody good job on the track for the weight of the car!
    Regards,
    Greg
  23. #73
    vt executive
    Dec 2010
    penrith
    i have been given a set of standard vx r8 slotted and drilled rotors never used
    and i would like to put them on my vt...can anyone recomend what kind of
    calipers would i need to put them on my car ?
    "I didn't cum on you pete......I swear !"
  24. #74
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Which size rotors are they? Are they the 330 or 343mm fronts?
    Regards,
    Greg
  25. #75
    VZ AWD One Tonner
    Jul 2006
    *** Updated with Current Pricing ***
+ Reply to Thread
  1. vt twin piston brakes
    By MattyVRss in forum V8 Development and Modification
    Last Post: 04-06-2009, 10:20 AM
  2. [QLD] Vy twin piston calipers... Cheeep!!!
    By sedate looking in forum Parts And Other Items For Sale
    Last Post: 28-01-2009, 08:03 PM
  3. Twin Piston Brake Calipers
    By Archers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-07-2008, 05:36 PM
  4. fs- melb - twin piston red VT -PBR brakes
    By CHEETR in forum Parts And Other Items For Sale
    Last Post: 09-04-2007, 07:48 PM
  5. Vr/vs Brake Up To Vx Twin Piston
    By micheledip in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2003, 02:02 PM
