Results 1 to 2 of 2
Thread: KYB / Kings standard height package?
    Cod
    Cod is offline
    VZ Executive
    Oct 2009
    Default KYB / Kings standard height package?
    Hi Greg what can you recommend to give my VZ exec sedan a sportier suspension package whilst maintaining stock vehicle height?
    I'm thinking a set of kyb's with kings, what package deal could you do on a set of those? I wouldn't need the shortend kyb shock absorbers, just the standard length. But i'd like both the shocks and springs to offer better performance (firmer ride and cornering abilities) or it's just a waste of money buying both together.
    In saying that, would it be beneficial to get a set of shocks leaving the stock springs, or a set of springs leaving the stock shock absorbers?
    Edit: Just found out this info, could you give me a price on the below items.
    KYB:
    HOLDEN COMMODORE VZ, SV6, SV8 & SS all with FE2 Sports Susp. Sedan
    Excel-G Twin Tube Gas Shock
    Front Left 339093, Right 339092
    Rear Left 344312, Right 344312
    Kings:
    COMMODORE VZ V6, SEDAN, FE2 HEIGHT
    Front KHFS-22
    Rear KHRL-125
    Also do you know what height the car will sit with the "FE2" marked kings/kyb?
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    To be honest unless you want to change the ride height, I would personally just stick with the stock springs, and go some KYB shocks. If you want to tighten the car up a bit, I'd do other things like front radius rod bushes ($179), and front sway bar ($265) before I didn't standard height springs.
    Anyways, KYB's as per above part numbers (which are correct!) are $139 each for the front, and $70 each for the rear, and both in stock. Low Kings will be slightly higher than the FE2 you have now, so as I said, I'd just keep the stock springs and do other items...
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. standard height
    By brohawk in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2010, 07:12 PM
  2. Standard ride height
    By revman1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-01-2008, 01:21 PM
  3. Vk standard ride height
    By blakestone01 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-12-2006, 06:09 AM
  4. Standard Ride Height?
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-04-2006, 01:26 PM
  5. vp standard ride height
    By tweakt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2005, 10:09 PM
