Results 1 to 10 of 10
Thread: VT v6 handling mods + prices.
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Default VT v6 handling mods + prices.
    Hi there what can be done to a VT commodore to improve handling significantly for hill climbs and possible track days.
    A small list of minor priced to major priced upgrades would be great if possible.
    Cheers Glenn.
    VZ AWD One Tonner
    Jul 2006
    Hi Glenn,
    What's your budget? It's hard to just list up a range of parts because you really need to grab parts which are going to compliment each other. Let me know what you'd be looking to spend, and I'll price up some options to suit. As well as all the other ones as well.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Budget will eventually be up to around 5-7Grand but don't get me wrong that will be over months not one big hit I wish it was so first parts I would be looking at a price for would be adjustable swaybars + a strut brace.
    VZ AWD One Tonner
    Jul 2006
    Ok sweet. Gimme a hour or two (bit busy here at the moment) and I'll fire up some options. With that in mind I can probably quote up some more suitable options for what you're looking for anyways.
    Regards,
    Greg
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Thanks mate what payment methods and warranty do you have you can PM me if you want.
    Cheers Glenn.
    VZ AWD One Tonner
    Jul 2006
    Payment is either credit card over the phone (Visa, Mastercard, Amex etc...) or direct deposit. Warranty is manufacturers only, but depending on the situation we'd warranted a bit ourselves. I apologise, but I probably won't get a chance to get to this today. Although it's only 3.40pm here, it's 4.40pm in most other parts of Aus which is where price and avails come from...
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    VZ AWD One Tonner
    Jul 2006
    Sorry mate, this week has been hectic as we're preparing to move location...
    I apologise, I'll try to get it to it today but we're closing up early to prepare for the move over the weekend...
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Don't worry about replying mate I will source these items through someone else I'm still thinking about your brake upgrade though.
    VZ AWD One Tonner
    Jul 2006
    Hi Glenn,
    Apologies again about the stuff around! I had the list done mid last week, but this move has been alot more work than any of us imagined and I've barely had time to check email yet alone forums... It's just cleared up now (although there are boxes of stuff on the floor everywhere still) so I'll post up now anyway for the benefit of anyone else who may ask the same question.
    Springs/Shocks
    - Kings / KYB Package Deal $675 (KYB / Kings Commodore Lowering Packages!)
    - DMS 40mm Coilovers $3508
    - DMS 50mm Coilovers $4630
    Whiteline Braces and Sway Bars
    - Front Strut Brace $185
    - Front 30mm Heavy Duty Sway Bar $185
    - Front 30mm Heavy Duty Adjustable Sway Bar $259
    - Front Spherical Swaybar link kit $245
    - Rear 18mm Heavy Duty Sway Bar $165
    - Rear 18mm Heavy Duty Adjustable Sway Bar $229
    - Rear 20mm Extra Heavy Duty Sway Bar $185
    Whiteline Bushes and Misc
    Front
    F Control arm - lower Series 2 on - Threaded ball joint WA130A $309
    F Control arm - lower Series 1 only - Spigot ball joint WA120A $309
    F Control arm - lower inner W51233 $39
    F Engine mount V8 - VT Series II (Gen III LS1) W92930 $245
    F Radius rod - caster kit W82047 $179
    F Radius rod - rear W52906 Heavy Duty $52
    F Radius rod - rear W81099 $33
    F Strut - mount W41771 Without bearing $86
    F Strut - mount W41772 With bearing $135
    F Strut - mount offset W42565 Camber adjustment - with spring platform $370
    F Strut - mount offset W42565S Camber adjustment - Coil overs only $315
    F Sway bar - link W21999A $18.50
    F Sway bar -link assembly W23000A Heavy Duty ‘Z’ link design $50
    Rear
    R Control arm W61483 39
    R Control arm - camber/toe kit W61309 $86
    R Crossmember - outer mount W92350 $162
    R Diff. - mount insert W92615 Rear of differential $24
    R Shock absorber - upper W31467 Sedan models $22
  1. wrecking vs parts list and prices in vic (will post) all prices flexable
    By tunsa in forum Parts And Other Items For Sale
    Last Post: 01-02-2008, 01:57 PM
  2. Best handling for a VN
    By 4PLAYN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-09-2006, 10:45 PM
  3. Handling
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-06-2006, 06:01 PM
  4. Handling
    By newo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-11-2005, 01:49 PM
  5. handling mods for VN?
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2005, 12:16 PM
