Results 1 to 8 of 8
Thread: Exedy clutch parts
    Mar 2008
    Default Exedy clutch parts
    Hi Greg
    Im doing an engine conversion and need to get an holden vt series 1 5.0 litre flywheel and a toyota clutch plate
    can you order them seperate , the exedy part numbers are below
    pressure plate FMC9037HD 267mm is from kit GMK-7131HD
    the clutch plate is exedy part number is TYD145U 260mm x 21T spline from kit number TYK-7678HD
    thankyou very much
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Clutch cover is $259, and the disc is $269.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Vs ute series 3
    Jul 2010
    Hi Greg,
    I've got a VS Series 3 and the clutch is slipping!!
    What do you recommend for a replacement and cost incl delivery to Silverwater NSW?
    Thanks,
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    V6 or V8?
    Regards,
    Greg
    Mar 2008
    Hi Greg
    clutch cover thats what i meant
    thanks for getting back to me, sorry for the late reply,
    once i confirm the parts i need 100% and im ready to go ahead with it i will send you a pm
    thanks again
    Vs ute series 3
    Jul 2010
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by deanos70 View Post
    Hi Greg
    thanks again
    No dramas at all, speak to you then!
    Regards,
    Greg
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Samp85 View Post
    Hey mate,
    It's a V6.
    Thanks
    No dramas, got a couple of options. You can replace exaclty what you've got with a new dual mass flywheel style clutch, $475. OR, and as most people do, is piss the DMF off, and replace it with a full single mass flywheel kit and clutch. To do that you're looking at $1210 for a standard kit, and $1329 for a heavy duty kit.
    Might be worth checking though to see if the car already has a single mass flywheel, and alot of people replaced them, and the clutch on it's own is a fair bit cheaper.
  1. Exedy Cluth plate, which way?
    By goanna_38 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-10-2009, 05:14 PM
  2. [NSW] Exedy HD Clutch kit V6 Getrag Solid flywheel
    By Swordsy in forum Parts And Other Items For Sale
    Last Post: 14-09-2009, 04:17 PM
  3. New Exedy HD clutch and rigid flywheel installed
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2007, 07:15 AM
  4. Exedy HD Clutch and Flywheel kit
    Last Post: 31-01-2007, 03:45 PM
  5. Exedy sports tuff
    By dpac in forum V8 Development and Modification
    Last Post: 05-07-2005, 10:34 PM
