Results 1 to 22 of 22
Thread: Clutch Kit for Solid Flywheel
    VT 3.8 V6 EQUIPE
    Aug 2009
    Default Clutch Kit for Solid Flywheel
    Hey GSL RallySport,
    Im after some quotes for clutch kits to suit a solid flywheel on a VT Getrag V6..
    Thank you
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    If you need the flywheel, std kit is $1165, and heavy duty is $1275.
    If it's already got the flywheel, std kit is $729, and heavy duty is $859.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VX S pac
    Dec 2010
    bundaberg
    hi there im after a clutch kit aswell i was wondering wat brand you sell?
    Danny B
    VZ AWD One Tonner
    Jul 2006
    Hi Danny,
    Exedy is our preferred brand in clutch. Those prices as per the previous past are still current and applicable to your VX.
    Regards,
    Greg
    some_guy's Avatar
    some_guy is offline Donating Member
    VR SII Exec.
    Apr 2009
    brisvagus
    What are you prices for a VR v6 t5 h/d clutch?
    97 WRX AWD
    Tein Coilovers + EDFC Dampener Control - Whiteline heavy duty Rear sway bar - Whiteline Droplinks front and rear
    Turbosmart dual stage boost controller
    IHI VF34 Turbo - XForce 3inch TBE - Oversized TMIC - Unichip PiggyBack ECU
    PPG Straight cut 1st & 2nd, Slight helical 3rd & 4th and standard fifth - HD Clutch - custom braided clutch line
    02 wrx 4pot front calipers - DBA500 two peice slotted rotors - Steel braided Lines
    BP98 safe tune @ 171.8awkw
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by some_guy View Post
    Hi mate,
    $419 for the kit.
    Regards,
    Greg
    VS executive S1
    Feb 2011
    Default vs series 1 t5
    Hi I have a vs s1 t5, how much would a clutch/flywheel kit be? Standard or heavy duty.
    Thanks
    Luc
    VZ AWD One Tonner
    Jul 2006
    Hi Luc,
    Assuming V6, std clutch kit is $279, whilst a heavy duty is $419.
    Regards,
    Greg
    04 vz clubsport, 6L M6
    Oct 2008
    radelaide
    hey mate, chasing price for a vu s 2001 5.7l with 6 speed manual, heavy duty kit
    James
    04 z series clubby. 6 litre 6 speed manual
    Quote Originally Posted by Cúl-Báire View Post
    Stroke and Blow it for extra fun!..
    Quote Originally Posted by DM 55 WA
    thats only because instead of porn i look at pictures of your ute!
    VZ AWD One Tonner
    Jul 2006
    Hi James,
    A heavy duty clutch kit including single mass flywheel is $1095.
    Regards,
    Greg
    vz ss and vs statesman
    Mar 2009
    hi greg, Im chasing a price on a heavy duty clutch kit for a vz 5.7l. It has to be able to handle 450 hp at the wheels. Thanks
    Oct 2008
    radelaide
    Quote Originally Posted by gslrallysport View Post
    Hi James,
    Regards,
    Greg
    hey mate, been told the vu's run a dual mass flywheel, not to sure on the riliability of this comment so thought i show throw it out there and guage by the reaction which way is the better choice
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by NVMYVT View Post
    Hi mate,
    That's correct, the kit replaces the troublesome dual mass flywheel with an aftermarket single mass flywheel. Apart from slight NVH, there's very few reasons to keep the dual mass flywheel, except for a slight price difference maybe. The vast majority of people who do clutches on Commodores replace the dual mass with a single mass.
    Regards,
    Greg
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by trav_304 View Post
    Hi mate,
    Got two main option, either a straight heavy duty, $1095 including single mass flywheel, or if you're putting out a bit of power, a sports organic is $1395 including single mass flywheel.
    Regards,
    Greg
  15. #15
    Mar 2009
    Thanks, where would i be able to purchase one my post code is 4413. That is a exedy clutch correct. The sports organic.
  16. #16
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Yep, that's an Exedy Sports Organic. Shipping to you would be $15.
    Easiest way to order is credit card over the phone, 1300 884 836, or else PM me your details, full name, delivery address (preferably a work or business address!!), contact number and email and I can fire you through an invoice with direct deposit details.
    Regards,
    Greg
  17. #17
    VX Spac
    Jun 2009
    Hi greg,
    i got a vx v6, i'm just wondering how much would it cost me for a DMF w/ a heavy duty clutch kit or a HDF w/ a heavy duty clutch kit? and is it possible to replace it myself? Thanks mate!
  18. #18
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Exedy don't make a heavy duty clutch to suit the DMF. To get into a heavy duty clutch you need to go to a single mass flywheel kit which is $1279.
    If you're handy you'd be able to replace it, but it is a big job, and an expensive part to bugger up if you get it wrong.
    Regards,
    Greg
  19. #19
    VT SS 5.7
    Mar 2005
    Goulburn
    i had a Exedy HD clutch kit slaped in my vt 5.7 6spd today , $350 to have it fitted and $730 to buy the clutch kit and yes it was a solid FW not DMF
    Real cars don't power the front wheels, they lift them
  20. #20
    VZ AWD One Tonner
    Jul 2006
    Sounds about right, the V8 clutch kits are a fair bit cheaper.
  21. #21
    VX Spac
    Jun 2009
    Hi mate,
    Regards,
    Greg
    hi greg, so how much for a standard clutch kit and a dual mass flywheel for a vx v6? i checked in exedy site and i think the part number is GMK-6994 DMF for vx v6?
    Regards,
    erick
  22. #22
    VZ AWD One Tonner
    Jul 2006
    Hi Erick,
    GMK-6994 DMF is $1315.
    Regards,
    Greg
  1. Dual Mass to Solid Flywheel Conversion, Who Can Help?
    By social in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-05-2011, 09:34 AM
  2. What are the torque specifications for VX V6 Solid Flywheel Bolts?
    Last Post: 23-01-2010, 04:29 PM
  3. VS V6 Ute 99 Manual - DMF to solid flywheel?
    By shasam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-01-2010, 11:16 AM
  4. [NSW] Exedy HD Clutch kit V6 Getrag Solid flywheel
    By Swordsy in forum Parts And Other Items For Sale
    Last Post: 14-09-2009, 04:17 PM
