Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree1Likes
Thread: king spring height
    VZ SV6
    Jul 2010
    Default king spring height
    hey mate i am considering buying some new king springs.
    i got a vz sv6 and jus wondering by how much mm's would king spring ssl's with monro gt shocks lower my car.
    and also are they legal?
    cheers
    kcpwns's Avatar
    kcpwns is offline Kicker - Livin' Loud :)
    VY V6 Equipe
    Jan 2010
    Shepparton
    i think ssl's are 70mm..anyone correct me I am wrong?
    i know the superlows are 50mm..
    dunno bout the shocks sorry
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Wont be legal, but then nothing is lol.
    You'll get away with superlows though.
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Quote Originally Posted by soop View Post
    well the thing is..go illegal and be super sexy looking, but have no insurance...
    or have it bare minimum and if you crash the car its all covered
    VZ SV6
    Jul 2010
    Nov 2008
    Smithton, Tasmania.
    Quote Originally Posted by kcpwns View Post
    meh, you just put it back to standard before accessor see it
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    hahaha soop thats funny as...sadly i didnt think of that...
    kngsv6 i recon the king spring superlows look sick and im pretty sure they are legal
    but if ya went lower i think you lose ride handling aswell as prolly not being legal
    correct me if im wrong anyone...
    but at the end of the day its all personal choice,
    hope we helped
    VZ SV6
    Jul 2010
    yeah i want superlows but the thing is i found a set of ssl dirt cheap so yeh.
    mite just wait around if i can find some cheap super lows
    JustDylan is offline Banned
    VN Berlina
    May 2010
    If you get superlows youll always want it that tiny bit lower, go ssl. theyre a compromise between looks and practicality
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by kngsv6 View Post
    cheers
    SSL on an SV6 would be *roughly* 335/325mm front/rear hub to guard respectively, and would be below legal height.
    Which GT were you looking at running, GT Sport or GT Gas?
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VZ SV6
    Jul 2010
    doesnt specify which gt's they are. would it make a difference which one it is?
    VZ AWD One Tonner
    Jul 2006
    GT Gas aren't worth putting on a ride on mower. GT Sport are the equivalent something like KYB, but generally more expensive. Although we do Monroe, for us it's VERY hard to justify a customer spending more on GT Sport when there's better products like Boge and KYB available for less.
    vr1uz-fe is offline Banned
    vr berlina
    Aug 2010
    australia
    hope we helped
    how would you lose handiling when a lowerd spring is stiffer and they drop your roll center
    vr berlina
    Aug 2010
    australia
    Quote Originally Posted by gslrallysport View Post
    what's so good about boge and kyb
  15. #15
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by vr1uz-fe View Post
    Why do you beleive that a stiffer spring is going to make the car handle better?
  16. #16
    vr berlina
    Aug 2010
    australia
    no but it will decrease body roll even though the sway bars are meant to do this but a lower spring will increase handiling but they can play around with the geometry but holdens are pretty good with a mild drop
  17. #17
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    sorry mate im referring to my experience and by handling im saying smoothness of the overall ride...
    my bad should have clarified**
  18. #18
    VZ SV6
    Jul 2010
    hmm. cheers guys. im gona stick with superlows as I dont want to void my insurance and such.
    would you need shocks if your goin super low all roung?
  19. #19
    Nov 2008
    Smithton, Tasmania.
    Handling characteristics are dictated by the Spring AND damp rate.
    SSSL in a VR with Monroe shorten shocks wont handle better. Might not be worse but certainly not better.
    (It will destroy your spine though)
  20. #20
    VZ AWD One Tonner
    Jul 2006
    Why do you think decreasing body roll will automatically increase handling? I don't mean to sound trivial, but I don't think you understand what you don't understand... if that makes sense. Sort of like not knowing what you don't know.
    It depends how you determine handling. If it means driving like a go kart and having your teeth rattled out then fine. But if it means the ability to go around a corner, road, or stage, as quickly as possible, then stiffer springs and less body roll certainly does NOT automatically equal better handling. Great example is look at WRC cars, which make any given piece of real world (not race track) road like like a set of rails, and you'd be surprised just how soft they run the springs. Watch the weight transfer under brakes...
    Also handling, is very personal, and a softer, higher grip/less response setup, might suit some more than a stiffer, less grip/higher response setup. In 2008 when I won the QLD Hyundai Max Attack Challenge, I ran 160lbs front, and 120lbs rear springs with NO sway bars at all, and was untouchable as most of the field was running 200lbs front, and 160lbs rear, with at least 1, of both sway bars still in the car. That suited me as I like the softer setup, which results in more available grip. Trade off is less response, but that suits me fine, as I'm confident enough to back it into a corner once, and know it was the right line. Others may not be so confident, so may like a car with less available grip (stiffer setup) but more options to adjust the car mid corner.
    Now because I had very high quality shocks in the car (DMS) that have good separation of high and low speed bump control, body roll wasn't an issue, as the low speed bump was still stiff enough to keep the car in check. That's not a luxury you get on a cheap street shock, but it's also not the moral of the story...
  21. #21
    kcpwns's Avatar
    VY V6 Equipe
    Jan 2010
    Shepparton
    Thanks for clearing that up mate
    always good to learn something new lol
  22. #22
    vh sle,vb sl,vt wagon
    Oct 2010
    vic
    if ur looking at keeping it legal hieght and dnt want any action frm the cops then go with lows in the frnt and sedan superlows for the back,dnt go h/d coz they will be stiff and are higher then standard sl springs!!!
  23. #23
    VT Berlina
    Oct 2010
    Looking at lowering my car by only about a 1" and still want to run in on the monroe shocks i have currently i am considering FE2's but i wouldd like to know if superlow/sportlows wuill drop it about that and keep it a nice ride?
  24. #24
    car
    Aug 2010
  25. #25
    VT Berlina
    Oct 2010
    im considering the Lovell sports, cause they lower it 25-40mm and can be placed on the existing shocks
  1. Spring height measurements
    By Stan003 in forum General Discussion
    Last Post: 16-03-2010, 08:37 PM
  2. [QLD] VT-VY King Spring SSL. F & R
    By SuperSixty6 in forum Parts And Other Items For Sale
    Last Post: 05-10-2009, 10:27 AM
  3. Replies: 3
    Last Post: 05-09-2009, 11:41 AM
  4. FE2 Spring height
    By broderikb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2006, 03:22 PM
  5. vb - vk spring height??
    By veeque92 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-12-2005, 01:28 PM
