hey mate, i've bought from you before a full car set of RDA slotted rotors and qfm hpx pads to go with them..my sisters car may be up for brakes soon and i was wondering if i could get the normal slotted RDA rotors front and rear, and a set of front and rear qfm pads, hp most probably because she's just a daily driver...so if RDA and QFM make those products could you please give me a quote on them...its an 07 astra cd 4 door hatch
also, i was wondering how much it would cost me for an extreme heavy duty clutch kit for my vz v6 ute (base model)...and a solid flywheel..including all bearings and slave cylinders etc, anything i'd need convert from a genuine set up to extreme heavy duty clutch and solid flywheel.
cheers mate
Bored or just wanna talk about cars? Add me on facebook and we can talk
http://www.facebook.com/#!/profile.php?id=1002697869
Hi mate,
RDA rotors to suit are $40 per rotor front or rear. QFM HPX pads are $79 per set. All on the shelf, shipping $12 so all up $330 for front and rear pads and rotors.
Exedy heavy duty single mass flywheel kit is $1695.also, i was wondering how much it would cost me for an extreme heavy duty clutch kit for my vz v6 ute (base model)...and a solid flywheel..including all bearings and slave cylinders etc, anything i'd need convert from a genuine set up to extreme heavy duty clutch and solid flywheel.
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
