as the title states my vu ute is in drastic need of a lift in her rer end,
not sure what hight the previous owner put in, (im thinking sssl or something like that), but it bottoms out under hard gear changes let alone bumps in the road
heres how it sits now, but i would like the arse to sit about the same hieght as the front
they are 19" rims by the way, and the tyres are well up into the guards
please could you suggest the size springs and most likely shocks to suit my ute and if you need any measurements like eyebrow hieght or so on please let me know,
also looking at a brake upgrade, how much am i looking at for slotted and dimpled rotors?
and decent pads
thank you for your time
James
Hi James,
Yep, if you could give us the hub (centre of wheel) to guard measurement of the height you're chasing for the rear we can roughly work off that.
Slotted and dimpled rotors to suit are $315 for the front pair, and $299 for the rear pair.also looking at a brake upgrade, how much am i looking at for slotted and dimpled rotors?
Remsa pads, good for 650 degrees (or 100 degrees better than Bendix Ultimate or QFM HPX) whilst retaining low dust and rotor wear. $89 for the front and $79 for the back, and come standard as a full face police spec front pad.and decent pads
Any other questions just let me know!
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
