Results 1 to 2 of 2
Thread: vz ss suspension
    dijm8's Avatar
    dijm8 is offline What You Looking At
    VZ SS LS3
    Jun 2006
    Default vz ss suspension
    hey mate,
    looking at replacing struts,shocks,springs(fe2), bushes, sway bars...everything under the car pretty much, whats your best products and best price buddy
    cars running a fair bit of power, so i want everything tight, i do alot of hill runs so want handling to be spot on, no body-roll etc
    let me know what you can do for me
    you can pm me if you want
    Thanks
    Daniel
    Edit: budget..well no more then 5k
    VZ AWD One Tonner
    Jul 2006
    Hi Daniel,
    Apologies about the late reply! If your budget is $5 and performance is your main aim, I would run with this:
    - 40mm DMS Coilovers $3508 per car set including springs, freight and GST.
    - Front Adjustable Sway Bar $275
    - Rear Adjustable Sway Bar $245
    - Front Strut Brace $175
    - New Front Strut Tops $59 per side including new SKF bearing
    Which would leave enough money from the $5k for a few polyurethane busk kits and installation.
    Any questions at all just let me know!
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. Sedan Suspension to wagon suspension
    By BADNWS in forum VE Holden Commodore (2006 - ?)
    Last Post: 07-05-2011, 05:01 PM
  2. VB Suspension
    By RazzaCaine in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-12-2010, 01:26 PM
  3. Std Suspension
    By gary2608 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 26-01-2010, 02:44 PM
  4. Suspension
    By bush_basha in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-04-2006, 07:42 PM
  5. suspension
    By crag in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2005, 06:28 PM
