Results 1 to 15 of 15
Thread: LS2 T56-M12 Clutch
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Default LS2 T56-M12 Clutch
    Hey,
    Just after your recommendations and prices for a replacement clutch kit.
    I have a 2005 Clubsport R8 with the T56-M12.
    The car is putting out around 335rwkw so I'm after something I can put in and not have to worry about for a while.
    Thanks,
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Jesterarts View Post
    Hey,
    Thanks,
    Hi mate,
    I'd go an Exedy Heavy Duty Single Mass Flywheel kit, which is $1049 for the kit. Or else you could go the cushion button, which is a significant step up, whilst still being streetable, but a fair bit more expensive, $1279 including flywheel. To be honest the standard HD should do the job.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Thanks for the reply.
    I'll probably be in touch when the current clutch dies.
    Cheers,
    Grennan's Avatar
    Grennan is offline Slayer of Stupid Threads
    Manual VX SS SII
    Mar 2007
    Glen Waverley, Victoria
    The Xtreme clutches are pretty good. Not cheap though, although you wont find a decent clutch kit for the 6 speed for under a grand (...in Australia).
    - Black Manual VX SS Series II -
    Stealth Mode Activated
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I was recommended an NPC single plate setup for my LS1, thoughts? $1500 supply only from a couple of shops up here.
    Jester, from what I've been told NPC clutches are the go for any LS engine, do not suffer from the Tex shudder or any other stupid issues. Just slightly heavier than stock, but no big deal - you expect that anyway Might be worth looking into.
    WTB: mulberry VN interior parts
    vz ss
    Sep 2011
    Hey mate im also upgrading my clutch and ive been told good things about NPC clutches, i drive in alot of traffic does any one know what there like compared to the standard ones?
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    vz ss
    Sep 2011
    Quote Originally Posted by savage1987 View Post
    I can probably let you know in a month or two
    Im actually getting my NPC clutch fitted next monday so i guess ill have to let you know haha
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    which one? Mine is the single plate coppermix organic. let me know how you go!!
    vz ss
    Sep 2011
    Hey mate got my clutch fitted today! wow feels so much better and is as easy to engaged gears, very street-able
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Awesome. Good to know!!
    Glad I didn't go with some sort of horrible button clutch
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Just a follow up question to this thread. How much for a concentric slave and throwout bearing for the LS2?
    Thanks.
    VZ AWD One Tonner
    Jul 2006
    What clutch is in the car now? OEM, or an aftermarket SMF etc?
    Jesterarts's Avatar
    Nov 2005
    Mornington, VIC
    Quote Originally Posted by gslrallysport View Post
    Currently OEM but it will be replaced in the near(ish) future with a aftermarket twin place that is compatible with the OEM CSC. Flywheel is solid.
  15. #15
    VZ AWD One Tonner
    Jul 2006
    Can do mate, $229.
  1. clutch is making a loud pop sound when i push the clutch in
    By giffo2010 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2011, 04:37 PM
  2. vx ss clutch ??
    By Sir VxSs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-11-2010, 11:45 AM
  3. vr clutch?
    By Braydenreid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-11-2010, 11:26 AM
  4. [WA] VT-Z LS1 clutch master+slave cyl+reservoir + VX clutch pedal **SOLD**
    By savage1987 in forum Parts And Other Items For Sale
    Last Post: 23-05-2010, 11:22 PM
  5. v8 clutch kit
    By griffindore in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-07-2006, 11:40 PM
