Results 1 to 5 of 5
Thread: VE SV6 lowering
    astroham is offline PHATV6
    SIDI sv6
    Jan 2010
    Penrith
    Default VE SV6 lowering
    hi i already have my car on SSSL kings and munroe shocks ... i have been debating what i should do to improve handling ... it wallows too much in the corner and i am not happy with the dampening of the munroes ... i have a budget of around 3000 and was debating if i should go coilovers or a better shock setup ... i am not happy with the height at the front so if i go for new shocks i will need to buy a set of sp4 for the front ... please as i have a budget of 3000 include whatever you think will benefit me ... i am already considering sway bars so fire away and if it comes to more than 3 i can have a look ... but any suggestion/package would be excelent
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    If you're looking at coilovers then the cheapest one which we would recommend over a Bilstein and King package is DMS 40mm, which would be $3508 for the car set including springs, freight and GST. That's high end piece of kits, and MILES better than the range of cheaper $1.5-2.5k coilovers on the market... for that sort of money you'd be FAR better off getting a Bilstein B8 and Kings, either new or keeping what you've got. Bilstein B8 are $350 each for the front, and $309 each for the rear. Kings to suit are $125 per pair front or rear. Also with the Bilstein rears you've got a couple of different height positions you can run them at, so a small amount of adjustable in that respect.
    Other bits and pieces we can do:
    Front Strut Brace $229
    Front Adjustable Sway Bar $295
    Rear Adjustable Sway Bar $275
    That would be the main items, if you wanted to do bushes etc., or any other items just let me know.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    SIDI sv6
    Jan 2010
    Penrith
    first question is, Do you do sp4 in the king springs?
    second question is, Ihat brand are the sway bars?
    Third question is How much could you do front and rear B8's, Front and rear sway bars, Front strut brace, Rear subframe bushes and front castor bushes for?
    do you do installs and if so where are you located
    SIDI sv6
    Jan 2010
    Penrith
    and also include a set of dba 4000 series slotted rotors for the front and remsa pads front and rear please
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by astroham View Post
    Yep, $189 per pair.
    Whiteline.
    We'd do that at a package price of $2295 delivered, which basically works out as being the subframe bushes for free.
    If you added a front and rear set of DBA 4000 Slotted and Front and rear Remsa pads, the total as a package deal would be $2909 delivered.
    Not as yet, this may change when we move to our new warehouse in November.
    Any other questions just let me know!
    Regards,
    Greg
  1. lowering front without lowering rear.
    By pillzor in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2011, 09:46 PM
  2. lowering
    By sickhg in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-12-2007, 12:40 PM
  3. Please Help, Lowering a VX S....
    By kaishiz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-04-2007, 12:25 PM
  4. Lowering
    By watson01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 04:51 PM
  5. Lowering-should I/shouldn't I?
    By jyothi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-02-2007, 05:18 AM
