Results 1 to 6 of 6
Thread: Rotors VE
    SSV Redline Ute (Voodoo)
    Apr 2011
    Liverpool
    Default Rotors VE
    Greg
    Are the 5000 series available for the redline edition VE front and rear.
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    For the front sure are, $536.25 each for slotted, or $577.50 each for cross drilled.
    Rear aren't available in 5000 series due to the handbrake mechanism, but in 4000 series are $198 each for slotted or $231 each for cross drilled.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Apr 2011
    Liverpool
    Post
    Thanks for that. I will order when the rotors have more wear. The pads I got from you squeal like mad is this normal or is it just when they are new.Ii have done round 400ks on them now.
    Do the 5000 & 4000 look the same as i was looking at the blue for the front. so would it look odd to have 5000 on the front and 4000 on the rear.
    Thanks for your time
    Apr 2011
    Liverpool
    Is there a better rear caliper available like a project mu. I hate the look of the standard rear caliper.
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by wayneforrest View Post
    Ah, the bain of opposed piston calipers... Give them a bit more than 400k's and if need be swaps the pads left to right, and go through a bed in again. Or as I said before, the absolute best things to stop it is those reuseable Project Mu shims which are $65 for the set.
    Yeah it would look odd... if you wanted blue rears to match the fronts, you'd have to paint them yourself unfortunately.
    VZ AWD One Tonner
    Jul 2006
    Unfortunately not... all their kits are to suit Jap cars.
  1. RDA disc rotors vs DBA rotors
    By Aus78Formula in forum General
    Last Post: 22-11-2011, 09:05 PM
  2. rotors
    By go fast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2011, 09:52 PM
  3. [QLD] (FS) DBA GOLD Slotted/Drilled Front Rotors & Rear Standard Rotors
    By markc3012 in forum Parts And Other Items For Sale
    Last Post: 26-09-2009, 10:44 AM
  4. WTB: QLD rotors
    By Rubber_Burnin_Gal in forum Swap / Wanted to Buy / Trade
    Last Post: 08-08-2008, 08:10 PM
  5. Replies: 20
    Last Post: 15-01-2008, 01:42 PM
