Results 1 to 8 of 8
Thread: any problems with kyb struts?
    03 VY V6 S2
    Oct 2005
    Default any problems with kyb struts?
    Hi, i bought some kyb excel-g front struts a couple of years ago they've only done about 10000k, and one of them has developed a "knocking" sound when going over bumps. Im absolutely sure its the strut because pretty much everything else has been pulled apart and retourqed with new bushes.
    so im wondering whether youve seen this problem before? because i need to replace it and i don't know whether to just buy 1 replacement kyb or replace both struts with a different brand...
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by unregistered View Post
    When were the strut tops and bearings replaced last? Are the struts fitted with bump stops?
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    03 VY V6 S2
    Oct 2005
    Replaced oem with superpro strut tops and new bearings. Have got the oem bump stops in place.
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    I had a similar problem. I had brand new KYB Excel G's and brand new SuperPro strut top bushings and bearings, and I developed a knocking noise. I got two replacement struts under warranty and the noise disappeared.
    WTB: VR/VS S/SS Lower front bumper lip/spoiler
    VZ AWD One Tonner
    Jul 2006
    Interesting.. I'll ask the question tomorrow!
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    Any idea on what part of the shock was causing the knock? Watches thread, i may be in the same boat
    VZ AWD One Tonner
    Jul 2006
    Ok spoken to KYB, and they said 99.99% of the time a knocking noise is heard with VR-VZ Commodores, it's the front sway bar links. They said they're actually yet to see a genuine claim of a shock knocking that wasn't links or strut tops.
    Check that your sway bar bushes are still in good order, and also that the washers are the right way around... which is the opposite way to what most people believe it is... is, the washers should look like this on the bush: )0(, not (0).
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Interesting. I had new SuperPro swaybar link pins and bushes on the front, installed correctly, re-installed and double checked, and new strut tops, reinstalled and double checked. Ended up taking it to a suspension specialist and with the shocks out of the car and in a clamp we could feel the knock in the top of the strut when pulling hard on it with our hands. My shocks were replaced under warranty.
  1. vn struts to vb
    By leigh 7005 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 03-10-2009, 10:55 PM
  2. What struts do you use??
    By undar8ed1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-01-2009, 07:36 PM
  3. Do VT struts fit a VS?
    By martinarmstrong in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 06:17 PM
  4. Gas struts
    By fatboy2869 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-01-2006, 12:41 PM
  5. VR/VS Struts into a VN
    By mechanic22 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-10-2005, 09:29 PM
