Results 1 to 8 of 8
Thread: Suspension package options for a VE2 SS ute
    Blockab's Avatar
    Blockab is offline SYC 055
    2011 VE S2 SS UTE 6M
    Feb 2011
    Penrith NSW Australia
    Default Suspension package options for a VE2 SS ute
    Hi Greg,
    Just after a few options in suspension packages prices and components for a VE2 SS Ute.
    The car will be used as a daily drive, i want it to sit about half an inch above the tyres (245/45R18) all round and be able to retain a good ride and be able to perform good aswell. Also i will be fitting in the near future 20x8.5 fronts and 20x9.5 rears will this affect it at all.
    Any help would be greatly appreciated,
    BlockaB
    VZ AWD One Tonner
    Jul 2006
    Hi,
    The entry level package I would recommend would be our KYB and Kings combo, which is $750 for the complete vehicle kit.
    Otherwise if you're willing to spend some decent money to get a quality setup that will handle lower heights whilst still riding and handling great, I'd go Bilstein and Kings. The kit price on Bilstein and Kings is $1588 for both front and rear.
    The Bilstein B8 are a full monotube shock (versus twin tube for budget shocks like KYB, Boge, Koni etc.) and handle high levels of lowering very well. The fronts are also an inverted style of shock, more commonly found on high end setups like DMS, Ohlins etc.
    With regards to height, basically need to know what your current hub to guard measurement is, and how much lower you'd like to go, or what measurement you'd like to end up with. Prices are all the same regardless.
    Easiest way to order is credit card over the phone, 1300 884 836, or else swing me your details, full name, delivery address (preferably a work or business address!!), contact number and email and I can fire you through an invoice with direct deposit details.
    Any other questions just let me know!
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Blockab's Avatar
    Feb 2011
    Thank you Greg,
    Would you recommend doing anything in the swaybars and bushes at all.
    VZ AWD One Tonner
    Jul 2006
    Yeah, depending on what you're using the car for, but again, depends how much you're looking to spend. Whiteline Adjustable sway bars to suit are $295 for the front, and $275 for the rear.
    On a 2011 vehicle, there probably isn't a lot of point doing a heap of bushes unless you were doing competition work, or had money to burn.
    Blockab's Avatar
    Feb 2011
    Thanks Greg, i use it as my daily drive but what i would like to do is minimise the body roll etc, and to pretty much handle like its on coilovers without the ride that coilovers have if that makes sense lol.
    VZ AWD One Tonner
    Jul 2006
    It does yep, I'd probably just start with a front sway bar, not worry about the rear.
    Blockab's Avatar
    Feb 2011
    okay thanks Greg for your helpful advice will speak to you soon in regards to purchasing
    VZ AWD One Tonner
    Jul 2006
    No dramas at all, speak to you then!
  1. VT Commodore Suspension Upgrade Options.
    By Cúl-Báire in forum GSL RallySport
    Last Post: 22-12-2010, 01:43 PM
  2. [NSW] FS: VR-VS Complete Suspension Package
    By 2Com in forum Parts And Other Items For Sale
    Last Post: 30-06-2010, 07:22 PM
  3. VE Suspension options
    By Calais57 in forum VE Holden Commodore (2006 - ?)
    Last Post: 27-05-2009, 10:12 PM
  4. FE2 suspension package
    By tigervh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2009, 07:02 PM
  5. Options for SV6 FE2 suspension
    By BullittSV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-03-2009, 08:59 PM
