Results 1 to 5 of 5
Thread: Strut assembly
    vs acclaim series 11 v6
    Mar 2010
    sydney
    Default Strut assembly
    Hi GSL.
    I have been given a set of GM standard springs for a commodore vs v6.
    I put them in with a set of Monroe GT gas shocks but now the ride is too harsh.
    What shocks do you recommend to maintain the ride comfort?
    The springs look the same thickness but when I measure the coil ends one end is thinner than the other.
    Which side goes up and which direction should the pointer on the spring seat point to maintain the spring alignment.
    I threw all the old parts out as they were worn but now I'm thinking the old shocks were oil shocks and give the impression they are worn.
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    First problem is that the GM springs which would be STD, the spring rate will not be as strong as Kings. Second is that GT Gas are a very budget shock, so don't tend to control the oscillations of the spring very well, and as such the car doesn't tend to ride very well.
    Would recommend BOGE shocks , which to suit are $125 each for the front, and $59 each for the rear.
    Springs should be the same thickness at each end, the coils closer at one end should be fitted to the top.
    Any other questions just let me know!
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    Mar 2010
    sydney
    Thanks Greg,
    Would a set of standard height king springs give a smoother ride even if they are stronger?
    I'm not too fussed about handling, I just need a decent ride cause my back is stuffed.
    Also does it matter which way the pointer on the bearing plate should face?
    Some people say outwards others say toward the engine.
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    When matched with the proper shock, a slightly higher rate spring can yield a better ride as the spring is less likely to crash out.
    To be completely honest, I've got no idea what you're talking about with the pointer... is it on the strut top itself, or on the bearing?
    Regards,
    Greg
    ve sv6
    Aug 2010
    Quote Originally Posted by pomiedore vs View Post
    Thanks Greg,
    the w shaped pointer on the top spring seat goes towards the outside of the car on vr-vz.
  1. Strut mount bushes & Strut replacement question
    By gontix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2010, 11:47 PM
  2. can anybody make sense of this strut assembly sheet 4 me ?
    By sawychri06 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-07-2010, 06:24 PM
  3. VY hub assembly
    By plazma in forum VY Holden Commodore (2002 - 2004)
    Last Post: 31-08-2009, 05:08 PM
  4. correct strut assembly
    By DannyboyDS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-07-2008, 07:59 PM
  5. s/c cai assembly
    By AKII1R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-10-2005, 05:25 PM
