Hi guys,
Was hoping for a rough quote for some parts, the vehicle is a VR Series 2 V8 Ute.
Parts as follows:
5823 - Bush x2
5843 - Bush x2
5107 - Trailing arm assembly
5108 - trailing arm assembly
P1690 - Front Z bar bush x 2
It the above part numbers make no sense:
Front lower control arm bushes
Radius rod bushes
trailing arm lower bushes
panhard rod bushes
z bar bushes
Postage would be to 4053 Brisbane.
Thanks in advance
(I have also just replaced sway bar link pin and bushes, strut top mounts, bumpstops and bushes in the shocks and struts. Excluding the above list and what I have already replaced, how many other bushes in the front and rear should be replaced? I may as well get them all done in one hit)
Hi mate,
Apologies about the late reply! Anything urgent always best to call!
Front lower control arm bushes - $55 for the kit
Radius rod bushes - $45 for the front kit, $33 for the rear kit.
trailing arm lower bushes - $219 for the pair (complete replacement arms), or just the bushes, $65 for the front kit, and $75 for the rear kit.
panhard rod bushes - $24 for the kit
z bar bushes - Z bar is just another name for radius rod, as quoted above.
Shipping to Brisbane $8, or else pickup from Acacia Ridge is fine.
The only bushes that I can think of would be the upper trailing arms. Which are $179 for a complete replacement pair of arms, or $89 for just the bushes.(I have also just replaced sway bar link pin and bushes, strut top mounts, bumpstops and bushes in the shocks and struts. Excluding the above list and what I have already replaced, how many other bushes in the front and rear should be replaced? I may as well get them all done in one hit)
All parts quoted are Whiteline!
Any other questions just let me know!
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
