Hey guys: quick few questions for you, an perhaps a sale for you also
Car in question: VT SS, DBA 4000 series slotted rotors.
I'm interested in changing to the DBA 5000 series, (2 piece, slotted and drilled). My reason is that im trying to reduce unsprung vehicle weight. I am not after any more braking performance. I AMA aware of the downsides of running a cross drilled rotor for lifespan.
What I want to know is the weight of the rotors, both my current 4000's and the drilled and slotted 5000. If the loss is significant, can you also forward pricing? All in OEM sizing please, as I run a 15" wheel.
Cheers!!
I can help you with the weights:
The DBA 4000 slotteds: approximately 9.7 KG.
The DBA 5000 cross drilleds: approximately 7.7 KG.
Yep, correct, there's about 2kg per rotor difference!
As part of our current '10 days of DBA Madness Sale' we've got a package deal with front 5000 Series Cross Drilled, and 4000 Series Rear Cross Drilled, for $769 delivered! Which is ridiculously cheap!!
For all the packages and details see here:
10 Days of DBA Madness! The clearance list you'll be forwarding to your friends!!!
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Are rears available also as a multi piece light weight assembly? If not, whats the lightest rear rotor you can supply?
Sorry for being slow getting back to you. I think id pass on the rears, as I have near new 4000's. If you could PM me a price on the 5000 fronts only, and freight to 4810, we can close this thread! cheers mate
Hi mate,
Front 5000 Series we can do for $282.98 per rotor, plus $25 shipping. So all up $590.96 delivered.
Easiest way to order is credit card over the phone, 1300 884 836, or else swing me your details, full name, delivery address (preferably a work or business address!!), contact number and email and I can fire you through an invoice with direct deposit details.
Regards,
Greg
