Hi guys i installed some noltec turn buckle adjustment castor rods to my vr not long ago and to my shock the front castor rod to cross member bushes have almost completely perished the bushes have literally crumbled to pieces also the rrear bushes are starting to split, has anyone else had similar issues? I believe whiteline took over noltec please correct me if i'm wrong but im hesitant to replace the bushes with what may be the same product i was thinking of using super pro this time around but it got me thinking maybe having the adjustable rods there has contributed to the issue should i just throw standrad rods back in?
Cheers Dan
Were these actually Noltec blue bushes? If so it's probably because they're about eleventy billion years old, and have gone all brittle. Or they weren't greased properly during the installation.
Super Pro or Whiteline Plus are the pick of the bunch (both we do), with Nolathane not quite as good.
The adjustable won't have made any difference.
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
Thanks for your reply Greg, they were noltec blue i bought them second hand and installed them ages ago but have only done very little km's on the car, but ohwell. I emailed you about prices on the whiteline gear is it ok if i grab prices on the super pro?
SPF0240K
SPF0756K
SPF0842K
or just the kit KIT152K if it works out cheaper.
Cheers dan
Hi Dan,
Those 3 kits are $49, $59 and $49 respectively. Basically the same price as buying the kit.
Regards,
Greg
Sorry to hijack the thread, but where did you get the castor rods from? I can only find one set for almost $500, a little out of my price range. Would be for a 6cyl vp
Sent from my GT-I9100T using Tapatalk
Hi mate,
The Whiteline kit is $409:
Regards,
Greg
