Results 1 to 2 of 2
Thread: VY new brakes
    VY Series II V6 Sedan
    Jan 2011
    Australia
    Default VY new brakes
    Hi my V6 VY needs new brakes, probably all around.
    Its just a standard 6er but is quite sluggish with the brakes. Would you recommend going slotted up front? Or all round?
    Im after some prices for RDA front slotted and RDA standard rear (if that is what you would recommend) and the bendix full contact pads (front and rear) DB1344?
    Are these the pads you would recommend too?
    Also shipping costs for total, to Perth.
    Thanks!
    Current Ride: VY Series II 3.8L Sedan
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Seth_23 View Post
    Hi mate,
    Generally we recommend going the same upgrade all round so that everything is balanced. There's very few applications were you can get away with lesser parts in the rear, namely a very light FWD.
    RDA Slotted rotors to suit are $165 for the front pair, and $149 for the rear pair. RDA Standard rotors are $40 each for the front, and $35 each for the rear.
    Alternatively DBA street series slotted are $99 per rotor front or rear.
    Not even if they were the last pads on earth... The only full contact pads available from Bendix are the Ultimate and above, which are hideously overpriced...
    I'd go QFM HPX, which are a full contact pad roughly equivalent to a Bendix Ultimate in terms of performance, but low dust and rotor wear. $79 per set front or rear.
    $25 for both front and rear pads and rotors.
    Easiest way to order is credit card over the phone, 1300 884 836, or else swing me your details, full name, delivery address (preferably a work or business address!!), contact number and email and I can fire you through an invoice with direct deposit details.
    Any other questions just let me know1
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. Difference between VT HSV 296mm brakes and normal VT 296mm brakes
    By CHEETR in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2011, 11:23 AM
  2. ve brakes and cross8 brakes
    By slow vs in forum GSL RallySport
    Last Post: 26-09-2011, 10:53 PM
  3. C4 Corvette Brakes VS GTS Brakes
    By gibbonsVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-07-2011, 08:58 AM
  4. [VIC] vt sloted brakes-vy calipers, vr frnt/back stock brakes & calipers, vy braker booster
    By YILDI2 in forum Parts And Other Items For Sale
    Last Post: 23-03-2011, 02:12 PM
  5. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
