+ Reply to Thread
Results 1 to 4 of 4
Thread: EBC High Performance Brake Pads
    VZ AWD One Tonner
    Jul 2006
    Default EBC High Performance Brake Pads
    GSL RallySport stocks the complete range of EBC High Performance Brake Pads
    EBC Brakes, Europe's leading Independent friction Material manufacturer brings you an exciting range of premium quality Aramid Fibre based Brake Pads. Ranging from the Non Asbestos Organic (NAO) Ultimax pad formulated to the World’s highest standard ECE Reg 90, through to the triple award wining Greenstuff Roadsport upgrade pads (also ECE Reg 90 approved), and the 6000 series Heavy Duty 4x4 pad, to the revolutionary New Redstuff Ceramic.
    For Track use EBC gives you the latest in the Yellow stuff 1793 compound and the endurance Bluestuff.
    All EBC pads and rotors are ECE Reg90 compliant and/or ABE certified to comply with European Legislation.
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    minux's Avatar
    minux is offline Infidel Bear minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    What sort of price would i be looking at for greenstuffs for all 4 corners to suit 343mm fronts 315 mm rears?
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Firstly, I have to admit I'm stumped! Not specifically knowing the car, the best I can figure the pads out to be DB1355 and DB1356... Either way none of the HSV pads were available in Green Stuff, but if you were after something in that performance range then Lucas would be the go, and they were all available, just need to know which ones they are for sure.
    Cheers,
    Greg
    minux's Avatar
    Feb 2005
    I'll shoot you through exact part number later on at some point Should help a little more then
+ Reply to Thread
  1. QFM HPX VT-VZ Police Spec Performance Brake Pads
    By gslrallysport in forum GSL RallySport
    Last Post: 18-08-2011, 11:34 AM
  2. brake pads
    By wayvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 04:57 PM
  3. vt brake pads
    By xu1au in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2006, 12:41 AM
  4. Brake Pads
    By BagEmUp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2004, 01:18 PM
