Page 9 of 11 FirstFirst ... 567891011 LastLast
Results 201 to 225 of 254
Like Tree2Likes
Thread: QFM Brake Pads
  1. #201
    D3CID3R's Avatar
    D3CID3R is offline Just Commodores NSW
    VY Commodore HBD
    Feb 2010
    South-West Sydney
    Just fitted the HPX's to the VY.. can really feel the difference.. Can finally have some piece of mind when i put my foot on the brake
    Quote Originally Posted by mischa View Post
    Me and Jack went down to the shops and got 3 tubs of vaso
  2. #202
    impulsive's Avatar
    impulsive is offline Alloytec Racing
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    Can i get a qoute for a 2005 VZ Alloytec Front & Rear and a 2005 2.4L Mitsubishi Lancer Front and Rear. Pads only?
    Life starts at 200km/h
  3. #203
    VZ AWD One Tonner
    Jul 2006
    PM Sent!!!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  4. #204
    impulsive's Avatar
    VZ Alloytec
    Aug 2007
    Brisbane, QLD
    For those that are interested in braking upgrades or require new pads etc, i urge you to contact Greg, he is very helpful and from what i have goathered with speaking to people about pads etc, his products and service are definately second to none. i will be buying brake pads very soon, just which ones...
  5. #205
    VZ Skaife Senator & VY SS UTE
    Jun 2004
  6. #206
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    The VZ 4 pot fronts, or 4 pot rears?
    Regards,
    Greg
  7. #207
    Jun 2004
  8. #208
    VZ AWD One Tonner
    Jul 2006
    I had to ask, as alot of people when they're asking for the 4 pots to suit VZ mean the rears when they have the 6 pot fronts.
    4 pot fronts in HPX are $119 for the set, and currently on a manufacturing back order, due 2-3 weeks.
    The rear 4 pot we don't do in HPX, but instead supply a European performance brand called Remsa (what we supply for Porsche road cars), and these to suit the rear are $95 for the set, and in stock.
    Regards,
    Greg
  9. #209
    Jun 2004
    are these rear pads less dusty then stock items i'm sick of cleaning the rims after every trip.
  10. #210
    VZ AWD One Tonner
    Jul 2006
    Definitely less dusty than OEM, even though they are a European pad. Thing to remember that OEM pads will always be very soft, and very dusty because OEM pads only have one purpose for existing in life, and that's to make absolutely no noise during a test drive what so ever, so zero k's on the clock, and no bed in.
  11. #211
    Jun 2004
    lol the oem pads are far from quiet in my experience. i know the AP brakes aren't as loud as the old harrops but get a bit of heat into them and they squeel like crazy never fade though.
    i think i'll be in contact shortly for a set of pads for all 4 corners the rotors are also getting low what do you recommend i'm a bit reluctant to do AP rotors again as these rotors are known for being soft and not havee a good wear life.
  12. #212
    VZ AWD One Tonner
    Jul 2006
    QFM HPX wins again against the competition!
    QFM HPX vs. Bendix Ultimate
    ...Ultimates are like a set of Ferodo generic pads!
    In My Opinion - I have tried both on my VX Commodore:
    I had Bendix Ultimates and I found them to be noisy, very very dusty and it liked to eat out my rotors, they pull-up was okayish but I found they didn't have enough "bite" for my liking.
    The QFM HPX Pads - I had them fitted to new rotors as the old ones were chewed out and could not be machined further. I purchased standard rotors after the pads had been bedded in wow.. simply wow! The pull up from them was so much better, and ABS kicked in much much quicker hardly any dust and alot less noisy.
    Still some squeaks here and there but all in all, a much better improvement over the Ultimates.
    Fordlaser.com :: View topic - Brake Pad Comparison - Bendix Ultimate Vs. QFM HPX
  13. #213
    VZ AWD One Tonner
    Jul 2006
    Rotors for the VE, we can either do:
    RDA Slotted
    Front $755 for the pair
    Rear $735 for the pair
    DBA Slotted
    5000 Series (2 piece) Fronts $665 per rotor (then replacement rotors after that are only $369 each)
    4000 Series Fronts $315 per rotor
    4000 Series Rear $245 per rotor
    On this rare occasion the DBA are cheaper, and the 4000 series slotted are a good buy. If you plan to keep the car for a while, might be worth going the 5000 series fronts, as the replacement rotor for the 2 piece rotor aren't much more than the 4000 series anyway. Any other questions just let me know!
    Regards,
    Greg
  14. #214
    Jun 2004
    sorry mate these are for the AP brakes fitted to a VZ senator not VE.
    the last run of VZ HSV got APracing brakes not Harrops or are all the parts the same?
  15. #215
    VZ AWD One Tonner
    Jul 2006
    Sorry mate, I'm on the wrong planet... You said that about 5 times...
    Try again. Price as follows:
    Front DBA 5000 Series Slotted $665 per rotor (replacement rotors $335 each)
    RDA, and single piece front and rear DBA rotors not available.
    Regards,
    Greg
  16. #216
    VZ AWD One Tonner
    Jul 2006
    QFM A1RM does the job in an Evo 3 Sprint car!
    Just giving these guys a good wrap, awesome service and support! Used the QFM pads on my EVO3. I have only used them for 15kms (after a quick bed in) at the Pittsworth Sprints, work great from cold, and better with slight warm up to the dummy grid. My only advise is with EVO3's with QFM's is you'll need to a bit lighter on the brake pedal as these grip up well!
    Qfm High Performance Brake Pads - Boostcruising
  17. #217
    VZ AWD One Tonner
    Jul 2006
    QFM HPX used in 2005 Subaru Forester XT
    Got my HPX's and RDA slotted rotors put in today I didn't quite realize how bad it was before!
    OzFoz.com • Login
  18. #218
    VZ AWD One Tonner
    Jul 2006
    QFM HPX Fitted to XT Forester!
    Agreed! I've just had the above combo installed yesterday [HPX pads and RDA Slotted Rotors] and the difference is unreal! Big thanks to Greg [from GSL RallySport] for the easy communication,good prices and quick postage!
    OzFoz.com • Login
  19. #219
    VZ AWD One Tonner
    Jul 2006
    The Brutal Truth About A1RM!
    I use A1RM on the track/street on a heavy arse underbraked car.
    ####ing brilliant, not sure how anyone drives a car without them, come into their own in the triple digit speed range.
    brake dust is a royal mofo, but that's life i guess. a stock euro car with tuv standard pads dust just as bad and they are oem and don't stop as good.
    i hear good things about ds2500 but at double or triple the price, forget that, the a1rm will last 3 track days for me.
    not even harsh on rotors like some people toss on about, the pads are rather soft imho.
    PerformanceForums - View Single Post - Aggressive street pad for VT caliper
  20. #220
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Just updating my purchase from Greg. I got standard rotors and QFM's HPX pads for the front of my car.
    First thing, Greg is a gentlemen. Second the pads are awesome. no need to slam the brakes hard for stopping power anymore. but if you really need some performance from your brakes and need to stop on a 50c coin. no problems at all. im so impressed with the stopping power i have changed my braking ways. i now pull up faster and release to a nice smooth easy stop. I have hardly felt a single fade from them. cold starts are fine also. small brake dust, but rotors and pads and new, and it's very minimal. So if your thinking about getting standard brakes pads - your trucking futs.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
  21. #221
    VZ AWD One Tonner
    Jul 2006
    Thanks mate! Appreciate the feedback!
  22. #222
    vy executive s2
    Jul 2008
    Quote Originally Posted by gslrallysport View Post
    Regards,
    Greg
    bough a pair of these for my fronts put them on over the weekend and they feel great and havent heard a peep yet (fingers crossed) really happy with the service and advice from these guys!! will be buying from them in the future.
    CAM'S VY PHREDDIFIED AND LEATHERED!
    http://forums.justcommodores.com.au/...w-leather.html
  23. #223
    1998 VT 5LT CALAIS
    Aug 2008
    Just bought some pads off GSL and i'm extremely happy with everything about the purchase. I'm not sure exactly who i spoke to, but got excellent customer service. I ordered late friday afternoon and received them lunch time in W.A today, very happy with the speed compared to other eastern states companies. After chucking in the front pads we had to have a quick test, so we put some kays on the car, bedded the pads in then did some brakeing! WOW the big black ve actually stops now! And very quickly aswell...
    The only downer was that the box had split and the pads were floating around the bag loose, but the bag didnt split so all good.. cheers GSL and I'll definately be buying off you again soon...
  24. #224
    VZ AWD One Tonner
    Jul 2006
    Thanks guys, appreciate the feedback!
  25. #225
    Jun 2004
    Regards,
    Greg
    Hi again i'm nearly ready to order but am a bit confused by your post for the VZ 4pot APs how much for a full set of discs front and back?
LinkBacks (?)
  1. 25-05-2012, 03:19 PM
  2. 16-05-2012, 01:26 PM
  3. 26-10-2011, 04:30 AM
  4. 06-07-2011, 12:13 PM
  5. 14-06-2011, 05:49 AM
  6. 06-06-2011, 07:42 AM
  7. 30-01-2011, 11:14 PM
  8. 11-01-2011, 11:39 PM
  9. 08-01-2011, 03:54 PM
  10. 07-01-2011, 05:26 PM
  11. 07-01-2011, 01:44 PM
  12. 06-01-2011, 05:18 PM
  13. 06-01-2011, 04:09 PM
  14. 06-01-2011, 03:44 PM
  15. 06-01-2011, 03:36 PM
  16. 30-12-2010, 11:28 AM
  17. 12-03-2010, 10:01 PM
  18. 01-03-2010, 11:42 AM
  19. 25-02-2010, 02:16 PM
  20. 22-02-2010, 05:42 PM
  21. 22-02-2010, 01:13 PM
  22. 22-02-2010, 01:11 PM
  23. 12-03-2009, 12:41 PM
  24. 28-02-2009, 09:33 PM
  25. 30-12-2008, 03:16 PM
  26. 06-12-2008, 04:34 PM
  27. 02-12-2008, 09:55 PM
  28. 26-11-2008, 01:28 PM
  29. 10-11-2008, 04:05 PM
  30. 09-11-2008, 07:00 PM
  31. 27-10-2008, 03:20 PM
  32. 27-10-2008, 02:30 PM
  33. 27-10-2008, 11:51 AM
  34. 27-10-2008, 10:09 AM
  1. Brake Pads
    By matt182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2007, 04:22 PM
  2. How many k's from brake pads?
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 07:47 PM
  3. Brake pads changes.
    By Krustyone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-07-2006, 11:02 AM
  4. Brake Pads
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2005, 08:53 AM
  5. Brake pads
    By nervesplit in forum General
    Last Post: 11-12-2004, 05:31 PM
