Page 1 of 11 12345 ... LastLast
Results 1 to 25 of 254
Like Tree2Likes
Thread: QFM Brake Pads
    VZ AWD One Tonner
    Jul 2006
    Default QFM Brake Pads
    GSL RallySport stocks the complete range of QFM High Performance Brake Pads
    Queensland Friction Materials is a QLD based disc brake pads manufacturing business which was established in 1989.
    The emphasis at QFM as been to develop high quality disc brake pads at highly competitive prices.
    A wide range of friction material formulations are available to suit general motor vehicle, industrial and racing applications.
    The ongoing research and development of existing and new friction material is performed at the QFM Nerang facilities. New friction materials are being continually developed and tested as part of the QFM commitment to quality and performance.
    Key Features
    - Long life with virtually no rotor wear
    - Low susceptibility to noise
    - No heavy black dusting of wheels
    - Excellent pedal feel and cold stopping
    SPECIFICATIONS
    Formulation - Cold Friction - High Friction - Temperature (C)
    Super X - 0.43 - 0.41 - 0-450
    HP-X - 0.41 - 0.42 - 0-550
    A1RM - 0.40 - 0.48 - 0-780
    Comp9 - 0.42 - 0.44 - 0-800
    Comp15 - 0.43 - 0.45 - 0-800
    QFM can also re-line existing backing plates or old pads! If you have a 'hard-to-get-decent-decent-material' pad, let QFM put one of their high performing compounds onto your pads!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VX SS M6
    Jun 2005
    ill take a set for when mine need changing. i need vs rears vt pads front. hpx
    VZ AWD One Tonner
    Jul 2006
    Too easy. Just PM me your details, name, delivery address (preferably business or work) and email and I can fire you through an invoice with direct deposit details, or else credit card over the phone is fine also.
    Regards,
    Greg
    VX SS M6
    Jun 2005
    VZ AWD One Tonner
    Jul 2006
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    I spoke to you about the Lucas Pads you have on special. Are they the D-TEcs ?
    I currently have QFM, absolutely love em, easily best pad i have used, such a fien light dust, cleans of so easily, not like that tar that Ferodo Excel used to make....only problem is i need to change all my rotors, but my pads still have heaps of meat left on them. I believe i should not use old pads on new rotors. The price you had for the other pads is very attractive if i need to change em all over again. What are you charging for front and rear rotors sent to Melbourne ???
    VZ Berlina
    Sep 2008
    Quote Originally Posted by vxcalais_01 View Post
    I would replace the rotors and just scuff up the current pads. Rubbing the pad surface in a circular motion on concrete removes all of the glazing and any high spots created by grooves in the old rotor. This will help to take the pad back to a similar surface to what they had out of the box and will allow you to bed them in with the new rotors.
    VZ AWD One Tonner
    Jul 2006
    Yep, as Sammy said, using used QFM's on new rotors won't be a dramas, just scuff them up, and give them a good bed in time without flogging them to avoid any hot spots. The Lucas were just the normal high performance ones, not the low dust D-Tecs.
    Cheers,
    Greg
    VZ AWD One Tonner
    Jul 2006
    Another QFM A1RM fanatic on cruisingbrisbane.com:
    I have these on my evo.
    F*cking great.
    Had EBC green stuff pads on at first.. could not brake very well when they were cold.
    Put on the QFM Race Pads; f*ck yes.
    Jul 2006
    Thanks for that guys, i will give em a nice scrape on the driveway, no problems of grit getting in ?
    VZ AWD One Tonner
    Jul 2006
    Not if it's smooth concrete, but you'll soon see.
    VY S L67
    Nov 2007
    I am still waiting for some last brake components for my car to test the A1rm's, but i put a set of HPX front and SUPER X on the rear of my GF's twin turbo soarer and **** ME! The car stops so well! this was installed with RDA slotted rotors purchased from GSL.
    Great service, great products, recommend to anyone, and will be buying anything else i need from here.
    Thanks again Greg!
    VZ AWD One Tonner
    Jul 2006
    No dramas at all bud!
    BOY1236 is offline Crazy dude in a V8
    VE SS (4-speed auto)
    Dec 2007
    Saudi Arabia
  15. #15
    WAGON MAN's Avatar
    WAGON MAN is offline Gas Sleeper
    VX S2 Berlina Wagon with Phreddied bits.
    Jun 2006
    North Coast , NSW
    Quote Originally Posted by BOY1236 View Post
    do you have any for the VE SS ?
    Quote Originally Posted by gslrallysport View Post
    Yep, surely do. Both HPX and A1RM on the shelf to suit the VE.
    Same pricing as above:
    - HPX $79 + $39.50 + $12.50 shipping = Front and Rear $131 to your door!
    - A1RM $119 + $59.50 + $12.50 shipping = Front and Rear $191 to your door!
    Regards,
    Greg
    Greg,
    You do realize BOY123
    Location is Saudi Arabia!
    I like my roo well done
  16. #16
    Jul 2006
  17. #17
    VZ AWD One Tonner
    Jul 2006
    ah... school boy error!
    Add an additional $65 for either the A1RM or HPX deals...
  18. #18
    VT Berlina & mazda 2 DE
    Jul 2006
    Hopefully you get a few calls about these for different models....keep us all informed of any feedback- its all good to see. I have been onto the Mazda boys about using this here compound....
  19. #19
    VZ AWD One Tonner
    Jul 2006
    I've thrown a stack of feedback all in the one place on a new forum we've come on board with:
    [Edit] Ok, links don't work cause its another commodore site... i'll post them all up here later...
    I'll keep them updated, and when I get time I'll start a similar thing over here. Or even on my website so there' one page to update, not 20...
    We've got just over $20k worth of QFM performance stuff on the shelf now, everything from the Commodores, to 323 Astina's to Skylines, to Valiants!
  20. #20
    Jul 2006
    How about bikes? Are the QFM's still better than the average bike pad, and still $75 odd (from memory) to get the compound thrown on a set of backing plates???Or am I better off looking for sintered pads.....
  21. #21
    VZ AWD One Tonner
    Jul 2006
    You know I've never been asked that, and now that's twice in 2 days! The short answer is QFM doesn't do bike stuff, and although they could re-line old pads, it would be a wild stab in the dark as to what compound would work. Bike pads seem to have a really high friction co-ef (like in the 0.60 range), so one would guess the A1RM, but then how it'd go cold would be a guess etc...
  22. #22
    Jul 2006
  23. #23
    VZ AWD One Tonner
    Jul 2006
    Feedback from a 300ZX at Winton on A1RM Street/Track Pads!
    I hit the A1RM pads HARD at Winton. ( i also replaced the fluid with Penrite SIN synthetic)
    These pads are really good. I had zero brake fade on the stock calipers. I actually wasnt expecting much.
    They remained tight and still usable even after the hardest laps.
    Cant recommend them enough.
    I need a set of stock A1RM rears for the race car now.
    The Australian 300zx Owners Association - View Single Post - QFM High Performance Street and Track Pads!
  24. #24
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Do you do these pads for the HSV AP Racing 4 piston brake calipers? I upgraded to the AP Racing brake kit a few weeks ago and am using the stock pads (Ferodo or something)... could you recommend a better pad?
  25. #25
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Unfortunately QFM doesn't do those pads. If you can source backing plates from old or unwanted pads then we can definitely get them made. Was it just the front AP's you've got?
    Regards,
    Greg
LinkBacks (?)
  1. 16-05-2012, 01:26 PM
  2. 26-10-2011, 04:30 AM
  3. 06-07-2011, 12:13 PM
  4. 14-06-2011, 05:49 AM
  5. 06-06-2011, 07:42 AM
  6. 30-01-2011, 11:14 PM
  7. 11-01-2011, 11:39 PM
  8. 08-01-2011, 03:54 PM
  9. 07-01-2011, 05:26 PM
  10. 07-01-2011, 01:44 PM
  11. 06-01-2011, 05:18 PM
  12. 06-01-2011, 04:09 PM
  13. 06-01-2011, 03:44 PM
  14. 06-01-2011, 03:36 PM
  15. 30-12-2010, 11:28 AM
  16. 12-03-2010, 10:01 PM
  17. 01-03-2010, 11:42 AM
  18. 25-02-2010, 02:16 PM
  19. 22-02-2010, 05:42 PM
  20. 22-02-2010, 01:13 PM
  21. 22-02-2010, 01:11 PM
  22. 12-03-2009, 12:41 PM
  23. 28-02-2009, 09:33 PM
  24. 30-12-2008, 03:16 PM
  25. 06-12-2008, 04:34 PM
  26. 02-12-2008, 09:55 PM
  27. 26-11-2008, 01:28 PM
  28. 10-11-2008, 04:05 PM
  29. 09-11-2008, 07:00 PM
  30. 27-10-2008, 03:20 PM
  31. 27-10-2008, 02:30 PM
  32. 27-10-2008, 11:51 AM
  33. 27-10-2008, 10:09 AM
  1. Brake Pads
    By matt182 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2007, 04:22 PM
  2. How many k's from brake pads?
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2006, 07:47 PM
  3. Brake pads changes.
    By Krustyone in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-07-2006, 11:02 AM
  4. Brake Pads
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-10-2005, 08:53 AM
  5. Brake pads
    By nervesplit in forum General
    Last Post: 11-12-2004, 05:31 PM
