Results 1 to 24 of 24
Thread: Koni High Performance Shocks
    VZ AWD One Tonner
    Jul 2006
    Default Koni High Performance Shocks
    GSL RallySport stocks the complete range of Koni Shock Absorbers!
    KONI is recognised world-wide as a quality shock absorber specialist, focusing solely on high performing suspension-damping technology for cars, racing, specialty trucks, buses and trailers. KONI shock absorbers and ride systems are specifically designed for every application without any compromise to quality and durability. KONI utilise the best technology to fulfill the highest requirements for comfort, safety and vehicle (handling) performance.
    KONI shocks include these exceptional performance features:
    • Owner adjustable valving for wear compensation and owner ride quality choice.
    • Adjustable over low and high speed damping ranges for overall smooth handling.
    • 100% dynamometer tested for complete quality control.
    • Many are serviceable.
    For more information on which products are best suited to you application visit the Koni Website or Contact Us!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VS Executive V6 Auto
    Dec 2007
    Newcastle
    Hey mate,
    I've been after some Koni shocks for a while now and just noticed a small leak in one of my rear shocks so it's time to upgrade.
    My car is a VS V6 live rear axel
    At the momement my suspension is completly stock. I'm locking to lower it a bit and was considering Lovels sports lows but mainly I want my car to handle better so I need some very stiff shocks (Not too stiff I still need to be able to drive it every day).
    Just a few questions:
    1) What Koni shocks would you recomend.
    2) Will the Konis work well with Lovels springs.
    3) Can I put Shocks in now and lower the car later?
    4) How much would Konis and Lovells cost all round?
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    have you got any 8641-1297 inserts in stock?
    if so, can you do some measuring for me?
    body length
    compressed length
    extended length
    body diameter
    if you havent,all good. ill call koni from work tomorrow. just trying to nut something out while ive got free time.
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Quote Originally Posted by mcvk View Post
    Really depends on how much you want to spend. The Koni Special (Red) are a good quality shock and will probably do. They are internally adjustable (off the car). The Red's are $212 each for the fronts, and $138 each for the rears.
    The Yellows are the next step up in performance dampening, and are externally adjustable (on the car). These are $283 each for the fronts and $188 each for the rears.
    Yep absolutely, either Lovels or Kings will work fine. Especially with the luxury of adjustable shocks, you just match the shock to the springs.
    Definitely!
    Koni prices as above, depending on what which way you go, and Lovells are $130 per pair front or rear.
    Regards,
    Greg
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by hakhawk View Post
    Unfortunately not here now, even the Koni catalouge doesn't give dimensions... even the Gabriel one does!!!
    hakhawk's Avatar
    Jan 2005
    i know, its a pain in the bum!! i called chris at koni today, he gave me dimensions and a shorter shock to use. champs over there!!
    '06 VZ SV6
    Jan 2008
    mornington peninsula.
    VZ AWD One Tonner
    Jul 2006
    Not very, even inserts are easy enough. Either way you'll need to pull the front struts out to do it...
    vn calais, vs clubsport #137
    Jun 2005
    how much for a pair of koni reds for a live axle vn? still same pricing as above?
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Koni Reds to suit the rear of your VN in a shortened body sports shock are $158 each.
    Regards,
    Greg
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    how much for adjustable yellow's for front + rear to suit VN?
    how 'adjustable' are they? does the adjustment control the damp/rebound at once? are shocks available with individual controls for each? what is the range of adjustment?
    Cheers,
    Luke
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Sorry about the late reply. Front Koni Yellows to suit are $295 each, and the rears $202 each.
    The adjustment is a single combined bump/rebound, and it's sort of hard to say how 'adjustable' they are, suffice to say they're designed to be both a street tourer and track shock, so there should be a fair bit.
    Regards,
    Greg
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    Quote Originally Posted by gslrallysport View Post
    Hi mate,
    Regards,
    Greg
    similar price for a VK with very low rear suspension??
    (car has Superlow Kings to match 'low' coilover setup on front )
    ta
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    VZ AWD One Tonner
    Jul 2006
    Yep, exactly the same.
    Regards,
    Greg
  15. #15
    Jan 2007
    Do you still do the deals on koni shocks mate?
    if so i am looking for some koni reds to suit vp front?
    Also what about a set for vp rear irs red and yellow?
    thanks
  16. #16
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by vp_304 View Post
    thanks
    Hi mate,
    Front Koni reds to suit VP are $249 each.
    Rear IRS shocks are $175 each for Red or $270 each for Yellow Sport.
    Regards,
    Greg
  17. #17
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    Does koni have in-car adjustable shocks to suite VS sedan with IRS
    WTB:VR/S HSV 250km/h speedo cluster
  18. #18
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Koni doesn't do any in-car adjustment systems (like Tein), but they do have Koni Yellow Sports, which are on-car adjustable. Koni Yellows are $355 each for the front, and $275 each for the rear.
    Regards,
    Greg
  19. #19
    kidmavric's Avatar
    kidmavric is offline OVRKILL
    VR dumped on 20's
    Mar 2008
  20. #20
    VZ AWD One Tonner
    Jul 2006
    Not out of Koni, but we can do a 40mm Drummond Motor Sport (DMS) full coilover kit, including springs, freight and GST for $3508. Bump/rebound/height adjustable.
  21. #21
    kidmavric's Avatar
    VR dumped on 20's
    Mar 2008
  22. #22
    VZ AWD One Tonner
    Jul 2006
    Just the fronts would be $1939 including springs, freight and GST.
    Link -> Drummond Motor Sport - Not all shock absorbers are created equal
  23. #23
    VZ Calais
    Jun 2010
    Wollongong
    G'day,
    Could I get a quote for Koni Sport (yellow) and Kings SL's for a VZ Calais posted to Wollongong NSW 2500?
    Thanks very much!
  24. #24
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Front and rear Koni Yellow and front and rear Kings springs (any height) would be $1295 delivered.
    Regards,
    Greg
  1. Koni Adjustable shocks for IRS commodore
    By Degeko in forum Parts And Other Items For Sale
    Last Post: 21-04-2007, 01:31 PM
  2. Koni Adjustable Shocks - RRP And Thoughts?
    By CMI83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-10-2005, 10:13 AM
  3. a qustion on koni shocks
    By larsey_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-10-2005, 02:30 PM
