+ Reply to Thread
Results 1 to 3 of 3
Thread: DMS High Performance Shocks and Coilovers
    VZ AWD One Tonner
    Jul 2006
    Default DMS High Performance Shocks and Coilovers
    GSL RallySport Stocks the complete range of Drummond Motor Sport Street and Competition Shock Absorbers and Coilovers!
    DMS Gold 40mm Shock Absorber
    Due to strong demand DMS introduced in 2003 the DMS Gold, 40mm performance street range of shock absorbers. This is a bump/rebound adjustable shock with a wide, useable range of adjustment giving users 30 settings allowing for all applications, from comfortable touring to club motor sport.
    DMS Gold 40mm adjustable shock absorber is made for a wide range of vehicles, including Subaru Impreza, Mitsubishi Lancer, Mirage, VW and many others. Check the DMS website catalogue or with GSL RallySport for shocks for your car.
    DMS Gold 40mm shock absorbers have high flow piston ports giving this shock superior control allowing more precise tuning.
    Product Description:
    - DMS blue shell case. Made of chrome-moly high strength steel. Fitted with adjustable anodised aluminium spring seat and lock nut. The DMS 40mm strut body is fitted with double lipped seals at the top, special low friction bushes and a seal below bottom bush to eliminate stiction. DMS uses specially formulated grease which gives durability and longevity to the 40mm GOLD suspension.
    - Adjustable camber available on mounting brackets.
    - 40mm shock absorber insert with high flow competition design piston with 30 defined adjustable bump and rebound settings. DMS only uses special formulated racing shock absorber fluid in this street performance product.
    DMS 50mm Adjustable Shock Absorber
    DMS first designed and manufactured the 50mm suspension system in 1990. Testing and tuning has continued and now has produced DMS's most successful product - the two-way adjustable damping shock absorber. This adjustable shock absorber has been used in production car motor sports.
    This DMS high performance 50mm shock absorber has one of the largest pistons available in a shock absorber in the world. This gives superior control, more precise tuning due to larger displacement and pressure areas and precise adjustment on bump and rebound independently.
    The larger the piston area the lower the internal operating pressures and temperatures. This provides higher damping capabilities which are necessary in severe rally or race competition. Compared to conventional shock absorbers the DMS Giant 50mm has over 200% improved accuracy and control.
    - DMS blue shell case. Made of chrome-moly high strength steel. Threaded and Fitted with screw- adjustable anodised aluminium spring seat and lock nut.
    - Competition specification mounting brackets with adjustable camber system fitted to the bracket.
    - 50mm shock absorber system with high flow competition design piston with defined adjustable bump and rebound settings. DMS only uses special formulated racing shock absorber fluid.
    DMS also has available high end gravel competition giant 60mm struts and 3/5/6 way adjustable.
    For more information on which products are best suited to you application visit the DMS Website or Contact Us!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    VZ AWD One Tonner
    Jul 2006
    Have run a tarmac S15 with DMS suspension, and LWR (Les Walkden Rallying) exculsively use DMS suspension, you will find that they are always at the front of the field in Tarmac and on dirt.
    I don't think you can go wrong with DMS, your next step from them is really the $25k+ Pro Flex and Reiger shocks which are probably more than most ppls cars are worth.
    Nissansilvia.com -> DMS High Performance Shocks and Coilovers! - Hardtuned.net
    VZ AWD One Tonner
    Jul 2006
    DMS is proper high quality stuff. Its a good step up from bilsteins.
    Japanese ohlins are actually pretty ordinary and very different to the european made ohlins. Aragosta's are very good but they are just euro bilsteins with a different name and in a gold colour. DMS is a step above both of these.
+ Reply to Thread
  1. Koni High Performance Shocks
    By gslrallysport in forum GSL RallySport
    Last Post: 23-08-2010, 04:32 PM
  2. EBC High Performance Brake Pads
    Last Post: 05-09-2007, 02:23 PM
  3. Where to buy High Performance VK ECU's...?
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-01-2007, 02:10 PM
