ive bought and installed a whiteline adjustable panhard on my vs commodore and was shocked when the bush that goes on the axle side the hole in the bush was just a little bit bigger than the pin it goes on so its not a snug fit, would this be a bad thing cause if it i still have the nolathane bushes off my old bar that fitted perfect so would it be possible to cut out the whiteline bushes and put in the nolathane ones?
Hi mate,
Provided the nolathane bush fits both the axle and the bar, then there's no reason you cant. Without seeing pics is hard to say anything else.
Regards,
Greg
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
i just bought a whiteline adj panhard bar and it fits perfectly. I have a VS Ute.
Maybe call them and ask them about it
--APOC--
yeah ive sent them an email they've told me to measure the internal diameter of the bush and also the external diameter of the factory pin which ill do it on the weekend and then ill see what they rekon.
