G'day,
I'm after a pair of rear shocks to suit live rear axle VS sedan.
Can you get them to suit a 60mm drop and keep the rear springs captive? (sick of springs falling forward)
How much are they and what is the postage to the Newcastle area (2318)?
Hey Mate,
Very interested, in super lows all round for a VS Senator, with camber kit.
We're up in Townsville btw.
The KYB shocks, are they the black ones? Can I upgrade to a slightly better shock at all?
Also, Im toying with keeping the self leveling, so am I just able to get the front struts n no rear shocks or r they a package?
Thanks for your time, will be calling in a few months.
G'day,
Hi mate,
Yep, just the excel g shocks, but can definately package up AGX's, Koni's or Bilstein if you'd like.
Na just tell us what you're after and we can package something up.Also, Im toying with keeping the self leveling, so am I just able to get the front struts n no rear shocks or r they a package?
- GSL RallySport - Ph: 1300 884 836 -
Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
- QFM Performance Brake Pads -
Also specialising in
- DMS High Performance Shock Absorbers - Monit Rally Computers -
VY V6 sedan - lowest springs you have and need camber kit too! How much for everything and delivered to Metro Melbourne??
Cheers mate, will PM you this week to sort it out!
Thanks,
Zep
Hey mate, will be looking at getting springs and shocks all round and also a camber kit, probably in a couple of weeks. Am looking at doing it myself, just wondering with the camber kit, does that need to be proffesionally set up? Im already having troubles with the camber on my rear tyres which im assuming is camber as they are 235/45/18 and apparantely bigger tyres and the IRS dont mix.
Also just wondering wether or not you guys deal with strut braces and swaybars?
http://forums.justcommodores.com.au/...ad.php?t=57371-My ride, check it out and leave your comments
no VU?? =[
Brux's S Pack V6 VU
MODS:
- 20" Jet League F-22's all round
- Lovells springs in rear, Kings in front
- Advance extractors
- Custom full mandrel bent 2.5" exhaust from cat
- Altezza head and tail lights
- BILLET Products short shifter
- NGK Iridium plugs
- K&N pod
- VIBE Black Air 6 Speakers
- VIBE Black Air 12 Amp
- VIBE Slick A4 Amp
- Clarion DVD Screen
Hi mate,
The camber kits are press in bushes that need to be adjusted, its more of a professional thing as you can't really drive the car till it gets a wheel alignment.
Yeah mate, absolutely, what were you chasing?Also just wondering wether or not you guys deal with strut braces and swaybars?
Regards,
Greg
Ah right, its just that ive been told by the local shop in town that they cant put them in unless you give them the numbers for adjustment or something like that(im pretty new to this kind of thing).
With the strut braces and sway bars, im open to suggestions, as this is the first time ive done the suspension on a car.
Ah, tha doesn't sound right. They just install the bits, and then adjust them as per a normal wheel alignment. There's no set numbers as such as every car will be different.
Just for a road car, RWD, I'd stick with just a heavier duty front sway bar, and front strut brace. I wouldn't worry about a rear sway, but those with more specific vehicle knowledge of Commodores may have other advice (We specialise in setting up FWD and AWD gravel rally cars, far cry from street Commodores!).With the strut braces and sway bars, im open to suggestions, as this is the first time ive done the suspension on a car.
A whiteline heavy duty front sway bar is $255, and a front strut brace is $189.
Cheers,
Greg
Ah righto, I was just told that by a mate. His car is awd though so it might be different?
When i get some time I will measure up and see how much I want the car lowered and get back to you. Will probably let you know sometime in the next fortnight.
After looking at your site I see you are at Brendale. Do you guys do installs? If so how much would I be looking at for super lows and shocks on a VU ute fitted?
When the going gets weird, the weird turn pro.
Hi mate,
Yep installs is fine. Its just charged at standard workshop rates of $66/hr, and shouldn't take any longer than 2-2.5 hours. The actual parts are $625.
Any other questions just let us know.
Regards,
Greg
gday mate ive got a vr exec, have had it lowered all round with pedders gear, guards sit flush with tyres, but im after some new shockers. what would u recommend and what prices??
or would i be better changing springs and shocks?
cheers mate
Hi mate,
I'm assuming just live rear axle?
You can change just the shocks, that's no worries.
KYB shocks to lowered VR are $125 each for the fronts, and $55 each for the rears. Or else just the prices on the first page for complete packages.
Regards,
Greg
cheers for that mate. will pm you soon to organize a set of shocks
thanks again
PM'ed. Oh and the springs that im chasing are just the sports low ones. Cheers
just wondering if you have any pics of a vt or a vx with the super lows installed?
or if anyone else does please post them. cheers
Hi mate,
Unfortunately haven't got any pics as most of what we do is just sales, and not alot of fitting.
Regards,
Greg
What would a set for a VS Sedan, live axle cost with King Spring ultra lows?
Can u fit them, how much extra would that cost?
I'm guessing that would require an adjustable panhard rod as well, yes/no?
Kinda new to the lowering a car thing...![]()
