Page 25 of 26 FirstFirst ... 15212223242526 LastLast
Results 601 to 625 of 630
Like Tree1Likes
Thread: KYB / Kings Commodore Lowering Packages!
  1. #601
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    A full set of KYB and Kings to suit are $675. 4 pt camber kit is $175.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  2. #602
    VU SS Ute
    Sep 2011
    Broken Hill
    Hey Greg, I've just bought a VU SS ute and want to lower it. I don't want to go so low that I need a camber kit, what height would you reccommend?
    How much would they be with postage to 2880. Regards Ben (",)
  3. #603
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Being an SS, pretty much any lower than what you've got would ideally need a camber kit. A camber kit isn't 100% critical, but any lower than your current height and you run the risk of excessive tyre wear. A 4pt camber kit is $175.
    Our lowering kit to suit VU SS is $795, and consists of KYB front shocks, and Oztec rear shocks, which are specifically designed for lowered utes, whilst meeting the load carrying requirements.
    Shipping to 2880 is free till the end of the month, or else $22 normally.
    Any other questions just let me know!
    Regards,
    Greg
  4. #604
    MR 1JZ's Avatar
    MR 1JZ is offline Classy not sassy
    VU SS
    May 2009
    Hi,
    Any chance on a price on a set of KYB Shocks to suit VU SS that already has Lovell Ultralow springs fitted
    Thanks
    Matt
    VU SS - The business
    1100ZXi - Water Hoon SPL
    GZ20 Soarer - 500hp 2JZ - Gone
  5. #605
    VZ AWD One Tonner
    Jul 2006
    Hi Matt,
    For the utes we use KYB fronts ($145 each) and specially developed [for lowered utes] Oztec rears shocks, $119 each.
    Shipping to Adelaide $22.
    Regards,
    Greg
  6. #606
    MR 1JZ's Avatar
    VU SS
    May 2009
    in your opinion would they be ok for light trackwork?
  7. #607
    GRPABT1's Avatar
    GRPABT1 is offline Jakstas' Warden
    VN shitta
    Sep 2010
    The ville
    Do you guys sell the KYB adjustables? How much for a set of rears to suit a VN at superlow hight? Also looking for track work valving if they offer a stiffer set
    Cheap, fast, reliable.....you only get to choose two.
  8. #608
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by MR 1JZ View Post
    Yep, for light track work, that you're not taking too seriously they'll be fine!
  9. #609
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by GRPABT1 View Post
    Hi mate,
    KYB don't make adjustable for the back of live axle, your best bet for track work valved shocks would be Bilstein, which are $170 each.
    Regards,
    Greg
  10. #610
    VY2 Berlina hail damaged
    Mar 2011
    1. I heard the new commodore handles great on the new fe3 setup whats your opinon??
    2. whats the best setup to decrease my vy v6's body roll will new rims help or are the more show with my stock berlina vy SII
    3. i read ^^ a bit and i am thinking low allround or maybe low and sl and i do tow a 5x7 full of fire wood sometimes
    4. A price on pads as my rears are 80-90% worn and my fronts about 50-60
  11. #611
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by tallvy2berlina View Post
    No opinion unfortunately, can't say I've actually driven a car on FE3. It's all relative to the other setups, and indeed other cars, and largely depends on what your intended purpose for the car is...
    First place to start would be some sway bars. Whiteline Adjustable ones to suit are $275 and $245 front and rear respectively.
    Most common setup is super low in the rear, and low in the front, Gives it that nice look without being too low. Price on the lowering kits is the same regardless of height, and to suit VY is $675.
    Just for heavy duty street use, I'd recommend QFM HPX, which is a Bendix Ultimate equivalent , but low dust and rotor wear. $79 per set front or rear.
  12. #612
    vy sv6
    Nov 2010
    auckland.nz
    Quote Originally Posted by gslrallysport View Post
    Hi mate,
    Yep, all shocks that we supply with super low or lower are supplied with the 50mm shortened version. Prices are the same.
    Regards,
    Greg
    Hello, how much to ship/freight a pair of front ^^ KYB shocks over to Auckland, N.Z? Cheers.
  13. #613
    vy sv6
    Nov 2010
    auckland.nz
    double post.
  14. #614
    98 VS Statesman series 2
    Nov 2011
    Port Lincoln
    hey don't no if this thread is still going but want to lower my vs statesman, thinking of lowering on SL, not really sure whats involved could you tell me what i'll need, and about the price range i'll be looking at, thanks
  15. #615
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by harry3571 View Post
    Hi mate,
    Sure is, the package price for springs and shocks to suit VS Statesman is $675. Depending on how low you go, you may need to get a camber kit, which is $179 for a Whiteline 4 point.
    If you're not able to fit it, then there's only a few hours labor, most mechanics would change $200-$300 to fit.
    Any other questions just let us know!
    Regards,
    Greg
  16. #616
    vy sv6
    Nov 2010
    auckland.nz
    Hey chief, i'd like to know how much it will cost to ship/freight a pair of front (vy) kyb's over to Auckland N.Z? I can't find any short stroke options over here, Cheers.
  17. #617
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by vy2.sv6 View Post
    Hi mate,
    Unfortunately we can't send shocks to NZ, because they're gas charged (dangerous good) and air freight is the only option being so close to Australia.
    Regards,
    Greg
  18. #618
    Jess walter is offline Jezzie
    VX acclaim
    Nov 2007
    Hi mate
    im getting a VE omega or calais i would like to lower the omega a bit so it looks level but everyone is saying if im going to lower it i mose well go the hole hog but i dont want it dropped on its nuts just woundering if you could help
    thanks
  19. #619
    VZ AWD One Tonner
    Jul 2006
    Hi Jess,
    Best to checkout the first post with regards to pricing etc.
    As far as which height to go, the best bet is to measure your current hub (middle of wheel) to guard measurement, and let us know how much lower than that you'd like to go.
    Regards,
    Greg
  20. #620
    VR Wagon
    Nov 2011
    What comes in the VR-VS Wagon kit? whats the height on the kit? do they come pre assembled? and how much is postage to adl 5051
    cheers
  21. #621
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    The lowering kit comprises of springs and shocks. Height can be anything you like, pricing is the same. Easiest way to determine the height is to measure your current hub (centre of wheel) to guard measurement and let us know how much lower than that you'd like to go.
    Depending on how low you go, you may also like to consider an adjustable panhard rod for the rear, which is $179.
    Shipping to 5051 would be $22.
    Regards,
    Greg
  22. #622
    VZ Calais
    Jan 2012
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Haven't received anything as yet?
  24. #624
    VE Berlina
    Jan 2010
    Hi Greg,
    I currently have superlow springs and stock shocks all round. I am interested in replacing the shocks to KYB performance shocks. Could you please advise your best price for KYB shocks for front and rear?
    Also how much to post to Canberra, post code 2614?
    Thanks,
    Jo.
  25. #625
    Holden VS Berlina 3.8
    Jan 2012
    Penrith, NSW, Australia
    Hey mate im new to the forums and im looking at lowering my car in the near future.....what shocks would you recommend that go well with king spring lows? coz i want my car to look good and kept legal.....spoken to few people and they said anything beyond king lows require engineering certificate.....could you PM me teh prices and brands please?
  1. kings, pedders or lovells springs for lowering vs statesman/caprice advice?
    By Caprice5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2010, 10:08 PM
  2. Lowering a VX Commodore
    By ashtray1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2009, 11:36 PM
  3. Lowering A Vl Commodore
    By Cherrys in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-02-2009, 09:32 PM
  4. Lowering a VS Commodore
    By pano in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 06:18 PM
