Page 9 of 27 FirstFirst ... 567891011121319 ... LastLast
Results 201 to 225 of 653
Like Tree1Likes
Thread: KYB / Kings Commodore Lowering Packages!
  1. #201
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    A 4 pt Whiteline Camber kit would be $175, plus $8 shipping.
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  2. #202
    VP Berlina Wagon
    Aug 2008
    Gday Mate
    How much for a set of King Springs Low and KYB shock set for my VP Wagon + Postage to 3199?
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    A full set of KYB shocks and King springs would be $550 plus $33 shipping to you.
    Regards,
    Greg
  4. #204
    GMM CAMMED and STALLED VT SS 5.7
    Sep 2007
    Melton,Victoria
    Hey mate. how do these KYB shocks handle? ATM i have SL kings all round but stock shocks. im looking for somthing that holds the road well as the cars really bouncy, also looking for a bit better ride. Will this shocks achieve my goals?
  5. #205
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by johnvtls1 View Post
    Hi mate,
    KYB are as good of a shock as you'll get without spending big bucks on Koni/Bilstein/DMS. The KYB on a budget is certainly the shock that will come close to meeting those requirements the best. Certainly better than a Monroe or Gabriel, and the KYB's are made in Japan, which is also a good start.
    Regards,
    Greg
  6. #206
    Sep 2007
    Melton,Victoria
  7. #207
    VZ AWD One Tonner
    Jul 2006
    Definitely! I don't think you'll find a single person on this forum that wouldn't take KYB over OEM. KYB are as good of a shock as you'll get without spending big bucks (ie. $1k per set) on Bilstein or Koni.
  8. #208
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    so do you have options and packages for VE as yet? and options on vehicles running the "sports" or "country" suspension? or will there be a one shock spec across the VE board?
  9. #209
    VZ AWD One Tonner
    Jul 2006
    No, there's both standard and lowered shocks for the VE in Boge. Pricing is the same either way, so for any higher combination (raised, std, lowered) the pricing for the sedan is $695 for springs and shocks.
  10. #210
    whitey152's Avatar
    whitey152 is offline cruzen
    1996 vs berlina
    Jul 2008
    port macquarie
    Hey mate i have sssl? in my vs irs brought it like that so i guess there ultras?
    how much for a set of shocks to match these springs?
    thanks
  11. #211
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by whitey152 View Post
    thanks
    Hi mate,
    KYB shortened shocks to suit VS IRS is $139 each for the fronts, and $69 each for the rears.
    Regards,
    Greg
  12. #212
    D-Man's Avatar
    D-Man is offline All over it...
    99 VT Calais II v6
    Aug 2008
    Melton, Victoria
    hey Greg,
    got a price on VT springs and shocks with Camber and Toe kit
    also how much lower will the SSL's and SL's be?
    or what your reccomendation is for 20" 225/35 wheels without sitting more than an inch below the top of the tyre (if you understand... maybe i should give you a call?)
    EDIT: oh and it's a series 2 calais v6 if that makes any difference.
    shipped to 3337 vic?
    cheers,
    Quote Originally Posted by danja View Post
    PS. All girls are the devil. It's science.
  13. #213
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by Noodl3s View Post
    hey Greg,
    Lowering package with King springs, KYB shortened shocks and 4 pt kit is $839 plus about $25 freight.
    SL are generally 45-55mm, SSL 60-65mm, but every application is different, and depends on how much your standard springs are sagged.
    As above, it's very application dependent, you'd be best off asking around the forums to see what people have used, and what the outcome was.
    Regards,
    Greg
  14. #214
    VZ SV6
    Oct 2008
    Newcastle NSW
    Hi, does for springs 30mm lower (VS IRS) come with shortened/lowered shocks & struts or standard height ones?
    Also just after a rough price postage to 2299 in newcastle NSW? thankyou.
  15. #215
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by alex2_s View Post
    Hi mate,
    Yep, all lowering kits for IRS Commodores come with shortened shocks for both front and rear.
    Shipping to you would be $22, so $697 all up for Kings springs, and KYB shortened shocks delivered.
    Regards,
    Greg
  16. #216
    Lewie's Avatar
    Lewie is offline B Cast and flat topped!
    Very thirsty VT & VH project under way! YAY!!
    Nov 2006
    Nowra, NSW
    G'Day mate,
    I've been reading through the posts but would like to confirm some prices just to make sure. Can I have a price for Kings springs and struts, front and back for a VH Commodore. Sports lows or equivalent. Will that drop it about 40mm? Also front struts for a VT. The VT has Pedders lowered springs in it to. It was done years ago and I think they lowered it by 30mm.
    With the VH as I am going with a V8 down the track, will the extra weight in the front end constitute the use of a heavier spring? It has a 202 in there at the moment.
    What payments do you have and can I get a quote for delivery to South Aust. 5086, Oakden.
    Thanks mate.
  17. #217
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Quote Originally Posted by Lewie View Post
    A full Kings springs and KYB shocks to suit is $575. Springs are the same price regardless of height. If you wanted 40mm you'd probably need super low as your springs are probably already sagged a bit from standard. Low will drop it 30-35mm from stock, which may be alot less than what your car is now.
    Got two options. If it's only 30mm you can go standard KYB's at $135 each, or you can go KYB shortened shocks at $140 each. Much of a muchness, but I'd take the shorter one to take up the stroke properly.
    Yep, definitely choose the right spring for the engine, just let me know which one it's got as it will change things.
    Shipping to you would be $33. Payment is either by emailing you an invoice with direct deposit details, or else credit card over the phone is also available, 1300 884 836.
    Regards,
    Greg
  18. #218
    Lewie's Avatar
    Nov 2006
    Nowra, NSW
    Great. Thanks mate. When the tax check comes in I'll PM you with a list or just give you a call.
    Cheers.
    "Please contact the Administrator if your date of birth has changed." JC Forum. Profile editor.
  19. #219
    Subaru Impreza MY05 WRX STi
    Mar 2009
    Sunbury
    Hi there,
    Just looking for prices on rear shortened shocks for a VR live axle? Also postage to Vic, 3429.
    Thanks!
  20. #220
    VTII Acclaim
    Jun 2008
    Hey Greg can I get prices delivered to 3523 for the following for a BA 02 Ford Escape...
    Kings Springs (Model no KMFR-54 and KMFR-55)
    These are raised so whatever struts/shocks you would recommend to suit.
    Thanks mate.
    Luke
  21. #221
    VZ AWD One Tonner
    Jul 2006
    No dramas, speak to you then!
    Regards,
    Greg
  22. #222
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by holden_girl View Post
    Hi there,
    Thanks!
    Hi,
    A pair of KYB shortened shocks would be $142 shipped to you.
    Regards,
    Greg
  23. #223
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by lad79 View Post
    Thanks mate.
    Luke
    Hi Luke,
    Those springs are $145 per pair front or rear. No one will make dedicated raised shocks for it, so the best option would be to just stick with KYB anyway. Fronts are $215 each, and rears are $80 each. All up, shipped to you would be $879 as a packaged deal.
    Regards,
    Greg
  24. #224
    VT Commodore S1
    Apr 2007
    Kempsey, NSW
    mate can you give me a price on kyb shortened shocks front and rear to suit vt v6, already got sl king springs in now, and delivery to post code 2440
  25. #225
    VZ AWD One Tonner
    Jul 2006
    KYB Shortened shocks front and rear to suit VT V6 would be $439 shipped to you.
    Regards,
    Greg
  1. kings, pedders or lovells springs for lowering vs statesman/caprice advice?
    By Caprice5L in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2010, 11:08 PM
  2. Lowering a VX Commodore
    By ashtray1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-12-2009, 11:36 PM
  3. Lowering A Vl Commodore
    By Cherrys in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-02-2009, 09:32 PM
  4. Lowering a VS Commodore
    By pano in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 06:18 PM
