Ask any competitive racer and they'll tell you their two biggest enemies are HEAT and FRICTION.
One of the most proven and tested methods of controlling these issues is creating a ceramic thermal barrier. The immediate benefits include a measurable reduction in heat transfer thus reduction in the engine bay temperature. This increases exahust speed and allows the engine to produce more power and torque. It is by far the quickest, most cost-effective and safe way of extracting those extra kilowatts from your engine.
Of course there are also the long-terms benefits. Ceramic coating dramatically improves lubrication of all internal moving parts, reducing wear and tear and thus prolonging their working life. Racers using Hi Octane Performance Coating engine parts report better reliability and performance gains right from the start.
Ceramic coated parts also provide protection against corrosion. Heat and friction are the biggest contributors to corrosion, with salt and acid close behind. The ultra-thin layer of ceramic film protect the coated parts from those elements, providing not only a thermal but also a corrosion barrier.
Hi Octane Performance Coatings take their reputation very seriously. The methods, finishes and quality of workmanship is continually being refined and tested in the harshest of conditions. From off-road and tarmac rally cars, drag racing, speedway, marine, heavy trasnport and even in the national level Top Fueler Class, Hi Octane Performance Coatings are providing racers with a competitive edge. If you need that edge why don't you try Hi Octane Performance Coatings for yourself?
Please send us a message or give us a call on (02) 9638 4643 for a free quote on all your Performance Coating Needs!
