Haydz
Fasten your seatbelts
- Nov 13, 2007
- 1,457
- 20
- 38
- Location
- Liverpool.Sydney,NSW
- VS UTE LS1 T56
Hey guys a mate and i are completing a manual conversion in the following weeks so here is a start to the guide on how to do it.
1. In the engine bay undo the 2 nuts(13mm) and one bolt(13mm). Holding the brake reservoir on.
2. Behind the brake booster (big black cylinder) you will have two nuts 2 (13mm) bolts to remove.they are holding the clutch cable in place. Note: picture only shows one. the other was removed.
3.Remove Fuse Cover, Steering Column Surround, Pedal cover. also Pull out the metal bar that has the fuses attached so you can see the two bolts up near the steering column behind the pedals. You want to remove both of them (13mm)
4. the Pedal Box is attached to the underneath of the steering column. remove this nut (13mm)
5. Un Plug The Clutch and Brake Cable/Line From the pedals. and you will be free to remove the pedal box. Note It may Take a bit of twisting Jiggling to Get it out.
Hope this helps.
and a picture to show you what your aspiring too
Hope this helps.
