HOW TO: Replace Auto Gear Shift with Satin Chrome
What you Need
- Small Flat head
- Small Philips screw driver
- News paper or floor.
- Satin Chrome replacements
- About 5/10 minutes
Stock
STEP 1 - Removal of Button (1)
Squeeze the sides and lift the button at the same time.
STEP 2 - Removal of Button and spring
lift the button and the spring from the gear shift and place on some paper
STEP 3 - Unscrew the handle
After the removal of the button and spring, unscrew the 2 small screws to release the handle
STEP 4 - Remove the handle
Lift up the handle and place on the news paper
STEP 5 - Replace with the new Satin Chrome Handle
Put the handle over the button holder, then clip in at the base of the handle
STEP 6 - Screw in the new Handle
While holding the handle screw back in the original screws
STEP 7 - Install new button
Squeeze and hold the sides while pushing in the new button.
It is a good idea to press the button down a few times to confirm that it all works.
STEP 8 - Enjoy
View all Pictures - http://img154.imageshack.us/gal.php?g=step1x.jpg&via=yfrog
thats a good write up and chance the vt - vx chrome tops come off like that?
thats a great write up mate top work. looks heaps better with the silver bits hey. Ive got em in my VZ. Just need the steering wheel inserts too.
awsome job mate
The VT shifter has a pin running through it under the shifter trim.
Unfortunatly you will have to remove the console to push that pin out in order to remove the button.
Do you have a "how to" for the handbrake button?
very professional looking![]()
i'm sure a lot of guys here would love to see a write up for "head gasket replacement" in this format![]()
Another great write up. These cars look soo much better with the satin bezels.
Nah mate the Vt ans Vx is a little harder. You have to remove the center panels ( the ones surrounding the gear shifter) and release a pin to take off the button. Then in reverse with the new button. Releasing the pin is very fidgety and extremely frustrating. Took me quite a while to do mine....but its worth every second you spent on it. Very classy.
gd write up buddy, 30secs took me lol
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car
Nice and easy so much lube in there though!! Or is there not supposed to be any? Lol
great write up. excellent description through the images
Hey.. excellent write up... I opened mine as it seemed loose.. I observed i am missing a spring..!!!
plus the are under the button is all greasy n gooey... Is it supposed to be like that?
