Page 1 of 2 12 LastLast
Results 1 to 25 of 40
Like Tree1Likes
Thread: VS strut removal
    jashdown91 is offline Jashdown?
    VS Acclaim S1
    Nov 2008
    live in ballina, thats near byron bay, everyone knows where byron bay is
    Default VS strut removal
    Ok, I've seen threads all over this site on how to remove the struts from a VP and a VT and every other make of Commodore, but none on the VS. So i figured i would make one, seeing as i changed my front springs last night with relative ease. And no this doesn't include stuffing around with ball joints, which isn't necessary in the VS series.
    Ok, to kick it off, what you will need.
    Photobucket
    That is:
    -Socket set
    -Lots of different sized spanners
    -Spring clamps
    -Big hammer
    -Shifter
    Also a jack of some type, jack stands, and chocs. Better safe than sorry.
    Ok, First of all you need to jack your car up. Before you do this, crack the nuts on the front wheels and put some chocs behind your rear wheels, can chuck some in front of them as well if your a bit nervous like myself.
    Once the chocs are in, put the jack under the cross-member and jack her up until the wheels are clear of the ground, then chuck some jack stands under the chassis rails.
    Photobucket
    Pull your wheels off and have a gander around inside your wheel arch and see what makes your car turn.
    Photobucket
    See those two big bolts in the top centre, you have to undo those. You also have to undo the bottom of the sway bar link, where it connects to the sway bar, don't bother with where it connects to the strut.
    Those two big bolts that hold the strut to the steering knuckle are bloody hard to undo if you have never had them out before. So what i recommend is getting a 22mm spanner around the nuts (i think thats the size) and whack it nice and quick with the hammer, keep going until you crack the nuts. Then get a socket set on there and take em out. the rotor and hub will lean outwards so get something to support it so its not putting pressure on the brake line.
    Now undo the sway bar link, do this by putting the shifter around the flat spot on the link, and a 9/16 spanner on the nut on the bottom and sit there for about 20 minutes trying to undo the little sucker.
    Ok so by now you should be able to wiggle the strut around a little bit and pull the sway bar link out of the sway bar.
    No go up into your engine bay with a 13mm socket and undo the 6 nuts the hold the strut.
    i didnt have a 13mm socket so i had to use the sh*tty 13mm spanner, and it took a long time.
    Photobucket
    You should get a mate to hold the strut when your undoing the last couple of nuts, you dont want the strut to fall down and strip the threads, its pretty heavy.
    After its out of the car, you can clamp the spring just enough so you can turn it in the strut, then undo the top nut on the shock absorber. Pull the supper plate thing out and then the other piece (dont know what its called) and there will be a washer and a nut, undo this nut and then take out the spring. Make sure you remember exactly how you pulled the strut apart, because it has to go back together the way it came off.
    Now just chuck the new spring in or whatever it is your doing and put the strut back together the opposite of how you took it apart. Then do the reverse of everything above to put it back together.
    Hope that makes it a little easier or clearer for people.
    It also saved me 110 bucks labour, so its not a useless bit of information as well. Anyway, goodluck if you try. its really pretty easy.
    Let me know if i missed anything.
    VS Acclaim S1
    Nov 2008
    wow. 590 views or something and not a single comment! atleast let me know if its any good sometime!
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by sly_gen3 View Post
    so i guess a turbo locks both back wheels together? or is that a supercharger? thats what my cousin told me. Who also happens too be my girlfriend. She has 2 heads aswell.
    VY Berlina V6 / R31 Skyline
    Dec 2008
    looks top notch mate!
    i dont need to change my struts but still looks like you covered everything
    VS Acclaim S1
    Nov 2008
    Quote Originally Posted by sweefu View Post
    YES!
    the first comment on this thread from someone that isn't me!
    haha thanks mate.
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    VS Acclaim S1
    Nov 2008
    Quote Originally Posted by Trayner View Post
    Good write up man , also you can use the stock jack to hold the strut while your undoing the top nuts
    good point mate. never thought of that. ill use that when i pull the damn things out again to find out why theres a lot of knocking when i go over a speed bump. thanks
    Kirbs's Avatar
    Kirbs is offline L plater
    96 VS Executive S2
    Mar 2009
    Cheers mate, Should be a great help (Y)
    Quote Originally Posted by levymetal View Post
    what a coincidence! the only way i can get my 2 year old son to sleep is if he's in the front seat of the car, no child seat, no seatbelt, and i'm doing 250km/h down the mornington peninsula freeway.
    VP Exec
    Jun 2005
    Two comments:
    The two nuts and bolts that hold the strut to the upright are torque to yield i.e. they are permanently stretched when tensioned correctly. As such they are meant to be replaced (and the new bolts/nuts tightened to the correct spec.) if they are removed. I don't know what the spec. is off the top of my head.
    In order to maintain the camber adjustment, push the upright so as to put the adjusting bolt - the small (10mm head?) bolt in the upright that points towards the centre of the car - hard up against the strut before tightening the two bolts/nuts.
    PSI2FLY is offline Default
    97 VT SS 5.0 Man
    Jun 2009
    Mascot
    Exclamation Torque Settings
    In thread how to remove the Front Strut on VS commodore, does any one the torque settings for those two big bolts connecting the strut to the main rotor hub assy??
    Much appreciated.
    VR Commodore
    Apr 2009
    VR Commodore
    Apr 2009
    Quote Originally Posted by Cheap6 View Post
    Two comments:
    Very good point there
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    Great writeup mate. Will probably be giving this a go soon
    But because im a mechanical retard, which one is the sway bar link? Anyone hve a pic?
    2005 VZ SV6
    Jun 2009
    VR Commodore
    Apr 2009
    Maxxiz, the sway bar link is shown in the third photo down. In the picture to the right of the photo it's the one with the red bushes (One of each side). Your link bushes might be black, red, blue or yellow. Depends on the brand. The links connect to the sway bar. Both links need to be taken off at the same time.
  15. #15
    2005 VZ SV6
    Jun 2009
  16. #16
    undar8ed1's Avatar
    undar8ed1 is offline Rags 2 riches!
    2 VXII V8 dailys
    Feb 2008
    regional W.A
    Also undo the big 24mm nut instead of all the 13mm nuts on the strut tower its much simpler, beyond that great right up mate.
  17. #17
    VS Executive Wagon V6 3.8ltr
    Apr 2010
    Tauranga, New Zealand
    Default VS Strut removal
    Hey just had a go at putting new springs in the front using your instructions, Great work mate helped me out heaps. Thanks
  18. #18
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
  19. #19
    1999 vs ute series 3
    Oct 2009
    gonna give this a go soon next week when my new ones come. ive order monroe gt lowerd stuts with sl king springs, does this make it any easier? seem as ive got brand new struts and springs?
  20. #20
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    probably be the same as you would need to remove the strut tops off the old shocks unless your getting those replaced also
  21. #21
    VS V8 Ute
    Jun 2008
    SA
    Hey, giving this a go on the week end, any one have a diagram or picture of how the strut should look pulled apart?? And so you dont need to compress the springs until the whole strut is off the car?? Cheers.
  22. #22
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The easiest way to do this is to crack the big nut on the strut while the weight is still on the car, then remove it. Jack the car up slowly until everything is loose. Remove the wheel, undo the swaybar link and the two mounting bolts, then remove the whole lot.
    Fitting lowered springs can be done without spring compressors.
    Have a look here, correct strut assembly 3rd post has a picture of it.
    Visit my Facebook page
  23. #23
    Oct 2009
    done this last weekend, was alot easier then i thought, followed these steps, only this i had trouble with was
    1. taking the breaklines off the strut, finally realised i had to twist it off haah duhh
    2. u cant just wiggle the strut round and remove the sway bar link, i had to get a jack under then and compress the strut to get it out.
    apart from that was easy, the first one me and the old man mucked around for about an hour doing it but the second one i done by myself in around 30 mins and im a 16 yo with next to no mechanical knowledge haha and yes make sure u have a 22m spanner lying around for those 2 big suppoirt nuts. i had to get on me pushy and ride down to supercheap and get one haha
    anyway thnx alot for the help mate, for all those people not sure about giving it a shot, just do it. if you have a brain you will work it out, saves u abita dosh awell haha
    Quote Originally Posted by Jonnii View Post
    yeah well it is a ute its not supposed to be about comfort
    http://forums.justcommodores.com.au/...rst-car-d.html <<< My 5sp vs ute
  24. #24
    VS V8 Ute
    Jun 2008
    SA
    Great write up, did it last week end, wasn't too hard, took about 3 hours all up (First time i've ever tried this) so if I can do this, ANY ONE CAN!!!
    Also if you can get hold of a rattle gun, use it! Was impossible to undo the top couple nuts on the strut with out one (Had to take them around to the mechanics to quickly borrow theirs)!
    GL to everyone else giving this ago!
  25. #25
    despo's Avatar
    despo is offline V Fast S furious
    vs series one
    Jun 2009
    gonna give this a go this afternoon let u know how i go
  1. front strut removal
    By georgeonboost in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-08-2009, 10:47 AM
  2. vs strut removal
    By -(TR1PZ)- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-07-2009, 12:59 PM
  3. Strut Top removal with no Rattle Gun
    By 308vkcalais in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-10-2006, 08:39 PM
  4. VS strut into VN SS
    By Bruce Davidson in forum Projects
    Last Post: 05-04-2005, 01:42 PM
  5. Front Strut Removal
    By Spinksy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2004, 08:01 AM
