Page 1 of 2 12 LastLast
Results 1 to 25 of 49
Like Tree1Likes
Thread: How to install VY/VZ Sunglasses holder in VT/VX
    2002 VX II Acclaim
    Aug 2008
    Default How to install VY/VZ Sunglasses holder in VT/VX
    OK guys, im still in the process of doing this so ill upload the last few photos in the morning.
    Parts needed:
    1x Centre roof console sunglasses holder from VY/VZ
    4x 1 meter lengths of automotive wire (i used same colour as existing to make it easier)
    1x Template to cut roof trim ( i will scan and upload my template soon when i can be bothered scanning lol!)
    1x 4/6 pin connector plug kit from electronics store
    Soldering Iron
    Solder
    Shrink Wrap
    Step 1) Start by dismantling the car. remove the pillar covers next to the front windscreen, both front roof handles and windscreen visors. This will allow the roof trim to fall free.
    Step 2) Behind the roof trim you should see a rectangular hole with two screw holes on each side. What you need to do is poke a Stanley knife through the roof trim into that rectangular hole. This will allow us to line up the template and get an accurate cut.
    Step 3) Once the hole has been made, line up the template, mark it out and cut away. You might want to cut the hole a little smaller then the template at first just to be on the safe side. Once you've got the whole right, it should sit in there beautifully.
    Step 3) WIRING! What you need to do for the wiring is remove the old plug from the console and cut off all of the wires and strip them back about 1cm. Get 4x lengths of 10cm or so wires and extend the current ones since they are too short now to attach a plug to the end of it. The wires you need to extend are shown in the image. The Red and Red/black wires on the console get joined together.
    Step 3) The plugs i used are attached in an image below. Slide some shrink wrap over the wires (2 pieces on each wire, one for join, one for connector pin), then crimp on the connector pin. I then soldered the connection so i never have a problem with flickering lights.
    Step 4) Once you've soldered the connections, shrink the shrink wrap over all solder points like i have in the image and then put the pins into the connector. Thats it! you've done this half of the work! I used a 6 pin plug rather than a 4 pin plug because one day i might either install a screen in my sunnies mount, or run an steering wheel adapter IR LED to the console, so ill leave those 2 slots empty for now
    Step 5) Do the same crimping/shrink wrap process for the mating end of the connector ensuring the same wires are going into the correct pins. Once your done, electrical tape the wire to make it look like a factory loom and run it from the Dome lamp hole in your roof trim to your sunglasses hole.
    Attached Thumbnails Attached Thumbnails How to install VY/VZ Sunglasses holder in VT/VX-p9160152.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9160155.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9160157.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9160159.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9160160.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9160164.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9160165.jpg
    How to install VY/VZ Sunglasses holder in VT/VX-p9160166.jpg
    2002 VX II Acclaim
    Aug 2008
    Step 6) Run your new loom through the roof from the centre console to the dome lamp. I cut mine about this long (look at attached image). You can also see the cut i made to the roof trim in this photo.
    Step 7) What you need to do is on the dome lamp loom, cut all the wires except White/Green Trace at about whatever length you feel comfortable. Be mindful that you cant pull the loom out any further unless you remove the roof trim.
    The way you need to connect them are as follows:
    (my loom ------------ dome lamp loom)
    Black --------------- Earth to the roof via the screw for the dome lamp (in later pic)
    Green -------------- Orange/black
    White -------------- Black
    Blue ---------------- Yellow/blue
    Step 7) Before you solder your wires slip some shrink wrap on. Much easier than electrical tape and looks better. There is a pic attached on how I joined my wires before soldering.
    Step 8) Once you have soldered / shrink wrapped all of your wires, tape up the loom if you wish so its all bound. The original dome lamp had a slit in one of the leg posts for the mounting screw (as shown in picture) I slipped my ground through here with an O-ring type terminal on the end. very easy to ground like this.
    Step 9) Once your done, plug it all up, and YOUR ALL DONE! Wasnt so hard was it?
    All up this cost me:
    $15 for the centre roof console
    $7 for the connection plug
    $2.50 for shrink wrap
    $6 on wire (i bought 7 core trailer wire since i couldnt find the colors i needed seperate in automotive gauge)
    Not bad
    All lights work independently and turn on when doors open. Only fault with the way it is wired now is that if the dome lamp is switched to "Off" the new console will not turn on when the doors open / car is unlocked. they DO however still work manually as map lights. So no big deal. Only way around this is to get a VY/VZ loom and run a whole bunch of other cabling which, in my opinion, is just NOT WORTH IT! Why would you have your dome lamp set to OFF anyway?
    Attached Thumbnails Attached Thumbnails How to install VY/VZ Sunglasses holder in VT/VX-p9170171.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9170173.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9170175.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9170176.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9170177.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9170178.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9170179.jpg
    How to install VY/VZ Sunglasses holder in VT/VX-p9170180.jpg   How to install VY/VZ Sunglasses holder in VT/VX-p9170186.jpg
    VY S1 Clubsport
    Aug 2009
    Hi There,
    I tried this mod over the weekend, putting it into my VY S1 Clubsport.
    The physical install worked great, but unfortunately the wiring didn't. The map lights I got didn't have a black wire. The other wires are identical.
    Any ideas?
    2002 VX II Acclaim
    Aug 2008
    You might not have the black wire because you might not have individual switchable map lights. Do you have real buttons or fakes on your sunglasses holder?
    2002 VX II Acclaim
    Aug 2008
    I just performed this mod on my mates VX series 1. His car did not have the required rectangular slot in the roof (second post, first picture)
    This caused some issues. There were however the required mouting holes for 2x screws. These screws were too low though, so do not cut out your roof trim aligned to these holes. You will need to re drill those holes about 1.25 cm higher up (away from windsheild) then cut your roof trim, or else the console will not sit in correctly.
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Quote Originally Posted by anarklov3r View Post
    You forgot to add removing the rectangular clip from the lights so it would fit
    It still came out great though, it was good i dropped something in the car last night, turned the new lights on and it was soooo much easier to see around the car, and it just looks awesome too lol.
    cheers man
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    i like this, great job mate im gonna try this in my vx s2 when i get a chance
    on another note, i have a calais center light dome and 2 rear country lights would it be any diffrent to the wiring ?????
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VX Exec 01
    Aug 2008
    Melbourne, Vic
    Quote Originally Posted by MR_VX View Post
    If the calais center light dome is the same as mine then no, you shouldn't have a problem, anark can explain more but it's pretty much almost the same.
    Here is a pic of my center light, http://forums.justcommodores.com.au/...7082009302.jpg (ignore the IR thingo), if yours is like that, then it will work fine, as anark did this mod on my car yesterday.
    VY S1 Clubsport
    Aug 2009
    Nah, it's just fake buttons
    How do I wire it up now?
    VZ SVZ Ute
    Sep 2009
    2002 VX II Acclaim
    Aug 2008
    Jiffy - Take a picture of your roof console, ill try work it out for you.
    Slick - Pull down your roof trim and have a look if you have the mounts, if so you should be able to do it.
    Fonzie's Avatar
    Fonzie is offline Just lost the game.
    300zx 2+2 Targa
    Aug 2008
    Gippsland, Victoria.
    Installed a sunnies holder in my VS exec a few months back... Very happy with it. You seemed to make the wiring job slightly more complicated than needed? You could have just gotten a hold of the male version of that plug... Either that, or just used four spade bits. It seems it was a lot easier for you to mount.. There is nowhere near as much room between the headliner and the roof in the VS. Looks great
    Quote Originally Posted by Philthy View Post
    ....man, I love how white your car is
    2002 VX II Acclaim
    Aug 2008
    The other end of the factory loom is pretty hard to get a hold of. Spade connectors could have worked, but would have been a pain to disconnect / match up if i ever had to take it apart. This is just easier. Plus it looks alot more professional, and im a bit of a perfectionist when it comes to wiring and my car
    Fonzie's Avatar
    300zx 2+2 Targa
    Aug 2008
    Fair enough, I ended up using new plugs right through aswell.
  15. #15
    VY S1 Clubsport
    Aug 2009
    It's identical to yours, looks the same as the pics, just without the black wire....
  16. #16
    2002 VX II Acclaim
    Aug 2008
    black wire is the ground for independant switchs. It should work if u just dont hook it up.
  17. #17
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    have you got the template for this mate? i wanna print one out
  18. #18
    2002 VX II Acclaim
    Aug 2008
    Ill scan it and upload it onto here once i get back from work tonight. Totally forgot about uploading it earlier! Sorry guys!
  19. #19
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    lol thats cool mate it will be handy tho
  20. #20
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
  21. #21
    LthlThrt's Avatar
    LthlThrt is offline Chef Jay in Port Douglas
    02 VU II SS
    Mar 2009
    Port Douglas
    Quote Originally Posted by ruggj View Post
    hey there i am looking to do this to my vt, but my centre light dome doesnt have those blue things it only has the light and the -off/door/on- switch, will i still be able to do it? or is it not going to work?
  22. #22
    2002 VX II Acclaim
    Aug 2008
    lthlthrt, the pic in that post is of a calais center light. Yours would be just a standard as mine was, and thats what the guide is based around. Follow the guide and you shouldnt have a problem. Just be careful when cutting your roof trim thats all.
  23. #23
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
  24. #24
    MR_VX's Avatar
    Mar 2009
    Townsville, Qld
    ebay around $30-40 bucks you can get them off here or some where else for bout $20
  25. #25
    LthlThrt's Avatar
    02 VU II SS
    Mar 2009
    Port Douglas
    sweet as thanks for that, now to get looking
    cheers
  1. [WA] giorgio armani genuine sunglasses
    By jamo25 in forum Parts And Other Items For Sale
    Last Post: 16-06-2009, 03:48 PM
  2. VY Interior Light/Sunglasses Holder into VT
    By Toeludeu in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2009, 08:35 PM
  3. VZ roof mount sunglasses holder into VT??
    By roger05 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2008, 11:16 PM
  4. Vl Calais Sunglasses Holder
    By POVRTY in forum Parts And Other Items For Sale
    Last Post: 15-01-2007, 07:08 PM
  5. WTB: VL calais/berlina sunglasses holder and hightop center console
    By VL Berlina 5speed in forum Swap / Wanted to Buy / Trade
    Last Post: 18-09-2006, 06:40 PM
