Results 1 to 7 of 7
Thread: Manifold stud access? vl
    tysonVL's Avatar
    tysonVL is offline L Plater..
    VL sl
    Nov 2009
    Question Manifold stud access? vl
    Hi,
    just wondering the easiest way to access the rear manifold studs because one has snapped. It's flush with the hole and i've got all the stuff I need to get it out, (easy out etc) but need to find a way to get in there, or will I need to take the whole thing apart till it's possible?
    Thanks
    tysonVL's Avatar
    VL sl
    Nov 2009
    Bbbuuummmppp
    Quote Originally Posted by Troy711 View Post
    As far as I am concerned the above mentioned styles are nothing but aids infested garbage. Especially speedcore.. when I hear it it makes me want to fist fk my grandmother with a barbwired glove.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will need a right angled drill bit attachment if you are drilling it.
    The way I get them out is to weld a nut to the end of the stud and just screw it out. Even if it is flush with the head, the weld doesn't stick to the alloy so it will come straight out.
    Visit my Facebook page
    tysonVL's Avatar
    VL sl
    Nov 2009
    But how do I get in there? There's no way to access it that I can see. It's the bottom rear stud and there seems to be no room at all.. the only reason I know it's stuffed is that they said when I tried taking it for pink slip.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You will need to remove the manifold to get it out. To give you a bit more room, you can remove the heat shield down there too.
    tysonVL's Avatar
    VL sl
    Nov 2009
    damn it.. I thought that might be the case, but was hoping it wasn't. Just don't want to snap any more stud's
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The VL's are notorious for snapping studs because of the design of the manifold. Most of the holes are slotted and the studs use two washers. The theory is that alloy and cast iron expand and contract at different rates, so the idea was to let the manifold slide against the head as it heated up and cooled down. Unfortunately all that does is bend the studs, so eventually they break. Front and rear studs were the worst for it. Even undoing the rest and getting them out will break some of them.
  1. Access Help
    By Tom_1569 in forum The LAN Lounge
    Last Post: 16-09-2008, 10:48 AM
  2. 10 stud vs 5 stud Rotors on Back of IRS VS Acclaim
    By pugga in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-10-2007, 09:43 PM
  3. Can't Access Arcade
    By HoZy in forum Site Feedback / Site Problems
    Last Post: 02-05-2007, 08:07 AM
  4. VT rear left exhaust manifold stud broken, remove with easy out or don't attempt
    By muso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-02-2007, 02:38 PM
  5. cant access some things
    By flyen in forum Site Feedback / Site Problems
    Last Post: 26-06-2006, 01:29 PM
Tags for this Thread
