Results 1 to 15 of 15
Like Tree3Likes
  • 1 Post By TVR-190
  • 1 Post By TVR-190
  • 1 Post By tHe_sTiG
Thread: Aftermarket driving lights into standard bar
    TVR-190's Avatar
    TVR-190 is offline SkyFall
    WK Statesman LS1
    Jun 2008
    Sutherland Shire N.S.W
    Default Aftermarket driving lights into standard bar
    Had a few people intrigued since we did this so thought id do a quick write up, excuse the lack of progress pics but i didn't take any during it.
    Tools:
    Jigsaw
    Powerdrill
    Switch
    Wire
    Fuse
    Screwdriver / socket set
    Driving lights
    File
    You will require these style driving lights
    they are available in clear and blue from most Repco's / Super cheap auto's
    Standard:
    After Driving Light Install:
    On:
    Step 1:
    You will need to remove the black bezels in the front bar. Simply push in the clips and they push out.
    Step 2: Hold the driving light to the bezel and trace around the glass of the driving light.
    Step 3: Using either a drill or a jigsaw cut out around the INSIDE of the line you traced just to be safe.
    Step 4: Once you have cut out the oval shape for the lights do a test fit by pushing the rear of the light through the front of the bezel. you may need to file the plastic back a bit if its a tight fit.
    Step 5: Once you have the light fitting well push the back of the light through the front of bezel and then attach the driving light mounting bracket to the rear of the light on the back of the bezel. this should ensure that the light will not fall out forward or backwards out of the bezel.
    Step 6: Optional - Use silicone to seal the back of the light for added strength if you wish.
    Step 7: I'm gonna assume you have some basic capability with wiring, because all thats left is to wire up the lights, in our case we wired our lights up to the cigarette lighter connection for the power source, this ensures that the lights dont stay on when the car is turned off. We placed our switch in the center console behind the power window switches using a round switch available from Dick smith or jaycar.
    Enjoy
    The Black Beauty
    VYMAD's Avatar
    VYMAD is offline SILVERFOX
    VY EXECUTIVE S2
    Jun 2008
    BUNDABERG Q
    Looks good, wouldn't mind doing that to my VY. Just wondering how or if you can align them so that they are pointing straight ahead when they are mounted in that position?
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    they are on a slight angle, but they still light up the road ahead and a bit of the sidewalk. It wouldnt be too hard to get them aligned straight if you were worried about it
    The Black Beauty
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Remember - if they are driving lights - as you refer to them, then they must be wired so that they only come on with high beam and of course go off when switching back to low beam. If they are actually fog lights, then they can only be used during periods of low visibility. That means fog, dust, smoke. They should not operate in conjunction with low beam. In fact they should only operate together with parking and tail lights.
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    Quote Originally Posted by Benboy View Post
    yes, if your in an area where the cops care about that...
    are you commsirac?
    The Black Beauty
    2002 Vy Ute
    Oct 2010
    Hey mate, i have noticed that i have these driving lights on my vy that i recently bought, but cant find any switch to turn them on, there is wiring and the whole lot, but i have no idea with all that.
    how to i find out if they work and how do i get them working?
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    I noticed you went through the trouble to blank out your number plate on all the pics, just wanted to let you know you missed the first one.
    Best RPG ever
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    First plate is yellow, if you look close, the blanked ones are white backing
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Coast_Calais is offline sick of the idiots here
    varies
    Jul 2008
    gone
    Hate to dig, AND be a pain in the butt... however; it should be noted (considering this is a how-to guide) that in order to make this install LEGAL for fog/driving lamps, that they must be relay activated through the parkers, and for spot lights through the high-beams...
    I understand there are pretty much NO cops that are going to inspect the wiring of your accessories, but it should just be noted for any members who reference this excellent guide. Mainly for RWC and insurance purposes, but also just in case..
    please no pointless flaming, i'm only putting it out there, i'm not preaching.. mmmkay
    TVR-190's Avatar
    WK Statesman LS1
    Jun 2008
    Quote Originally Posted by Coast_Calais View Post
    Hate to tell you, but that was mentioned only a few posts ago, and we didn't care then, still dont now. I will continue to wire up lights differently to annoy people who insist i do it right.
    The Black Beauty
    varies
    Jul 2008
    gone
    Quote Originally Posted by TVR-161 View Post
    i'm not insisting you do it right. I'm merely pointing out legalities for any other members who use your guide. and the above posts weren't clear or correct...
    maybe you missed the middle and last bit I posted?
    VS ute, YZF-R6
    Sep 2005
    When you wire up more lights, dont bother to post it up. Useless thread.
    JShaw's Avatar
    JShaw is offline greeeeeeeeen
    06 VZ Executive
    Dec 2010
    South East Melbourne
    goose2's Avatar
    goose2 is offline 40. the new 20
    VT BerlinaWagon/VZ exec wagon
    Sep 2004
    Ballarat, VIC.
    Quote Originally Posted by Afrikano View Post
    if you look at your headlight switch you may see a foglight symbol on it pull the main switch out toward you not twist it will turn your lights on
    If i wanted to break ya balls i woulda kicked ya girlfriends handbag
  15. #15
    tHe_sTiG's Avatar
    tHe_sTiG is offline <--- Want a ride?
    VZ Executive
    Jan 2010
    Saudi Arabia
    Hey guys, here's my idea of aftermarket fog lamps, think they look sweet! Excuse the chev badges, Commodores are badged as chevs in the Middle East.
    http://forums.justcommodores.com.au/...-dsc05447.html
    http://forums.justcommodores.com.au/...-dsc05453.html
    The only Exec in Saudi that's now properly badged!
  1. Car lights will turn on parkers but wont show normal driving lights
    By james_vrII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2010, 07:50 PM
  2. insalling aftermarket fog lights
    By skynyrd in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-10-2009, 04:16 PM
  3. Driving lights in standard front bumper?
    By Denno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-05-2009, 01:39 PM
  4. vr/vs aftermarket lights.
    By Haydz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2008, 11:44 AM
  5. Can I fit airconditioning to my 92 VP aftermarket (didnt come standard)
    By rharman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-01-2005, 08:43 AM
