+ Reply to Thread
Results 1 to 14 of 14
Thread: how to rebuild/ modify quadrajets (also vac hose diagram)
    ari666's Avatar
    ari666 is offline celebrate disrepair ari666 W427 ari666 W427 ari666 W427 ari666 W427
    1966 impala
    Mar 2009
    Default how to rebuild/ modify quadrajets (also vac hose diagram)
    sigh, ok, well it seems you cant post threads here to see what they look like, so am doing this again
    lol, i need to preface this by saying that i am no expert, this is just a culmination of what i have read, and playing with 2 other quaddys before. if there is any misleading info i will be happy to make correction based of FACT and not people opinions or theorys.
    ok to start you will need:
    prepsol
    araldite
    small hammer
    1/8th pop rivet
    razor blade
    torx keys. cant remember what sizes, some also may have been changed to either phillips screws or allen keys so they would depend on your carb.
    blade screwdriver
    30cm of welding wire or something similar
    and a beer (optional)
    ok so here is my quaddy, the essential vac hoses are listed. this is basically all you will need for a system that isnt using TVS, charcoal can or EGR. i am not saying dont use them, am just saying these are the minimum.
    a few checks before we start stripping her down are;
    check that your accelerator pump arm contacts the center of the pump nicely and is a round shape. if the pump arm has worn flat on the bottom you will need to grind it so its round again. this is so the pump action works smoothly and you dont get a horrible 'bog' or flat spot when the pump suddley releases and shoots too much fuel after not giving it enough briefly.
    its a terrible photo but will edit it later to circle the bit that needs to be bent. anyway, there is a catch here which your auto choke locks onto and will not allow your secondary to open until it hits running temp. THIS will cause a lot of headaches, bend it out of the way. i suppose now would be a good time to mention that i have completely removed the top butterfly for the choke and zip tied up the choke assembly. i dont use it, i dont want it so its gone. i would suggest the same for all quaddys, but they do serve a purpose. so its up to you
    check that your primarys and secondarys open up FLAT. they should open to 90 degrees and thats it. my mechanic told me it should be angled so that fuel atomises better but it is bullcrap, the upper needs to be angled not the lower. its important to remember that your butterflys WILL open up further than 90 degrees, but i am not talking about full movement, just movement when you apply the accelerator at WOT (wide open throttle)
    your secondary upper butterfly should open up on a slight angle, i am not sure of the correct angle but i have tried a little modification which means i am getting full opening and full lift on the secondary metering rods and it seems to work a treat, this carb would now thump my 750 holley, and gets slightly better fuel.
    so, to do it, check that your your flaps are stopping before 90 degrees, then kinda guess how much to grind off
    now if you just ground off that bit and left it at that, you would prolly make it run a bit worse cos' when the fuel squirts out of the secondary squirty hole thingie, itll just hit that flap and trickle down to drip into your inlet. what you want is for it to splash everywhere and make a massive mess. cos then itll be atomising properley, so to help you out we do two things. one is make a nice hole directly above the 'squirty in bit' (god i am bad with names) and the other is to cut groves and depressions into the flap itself, kinda like when you port and polish your heads you leave nice grooves in the inlet ports so fuel vaporises more effectively, same principle here
    check your cam!!! lol, there is a little plastic cam on the secondarys flap which lifts the secondary metering rods as the butterflys open. this cam has a tendancy to melt and die especially if you are running your beast on LPG. so no cam, so secondary meter rods=no petrol going in at high rpm=pinging and engine death.
    this bit will need to be adjusted on the car in real time cos there is no way of knowing where it should be set without the engine running but i will throw it in anyway so people know where and what it is.
    the secondary flaps are vacum operated and open when the car sucks enough juice through the venturies. when the flaps open the hanger and rods lift letting more fuel in making you go faster. BUT if you set the spring rate too loose the secondarys will flop around, use BUCKETS of fuel (you have no idea how bad it will be, no point going on the freeway unless you have a full tank for a 20 min drive) flat sopt all over the place and leave clouds of black smoke behind you every time you put the boot in.
    the way i adjust it is to do the 'tap test' so basically tap the flap with my finger, if it opens too easily, adjust it till it gives quite a lot of resistance. a stock or cammed 308 will not need much opening rate, so tighten it right up.
    to tighten it you need two hands and a lot of patience. there are two stage, a locking torx key and a flat blade screw. the blade screw is the tensioning adjustment and the torx locks it in place. so. put your little blade screwdriver in the screw, hold it tight DONT LET GO or itll release the spring and you will have no idea where it is set at. so witht he screw held tight, loosen off the torx and either turn the screw clockwise or counter clockwise in 1/8th turns.
    the driving test involves you moving off, traveling around 20kmph and putting the boot in at various degrees, wot, part and closed. you will be feeling for a flat spot or hesitation, if there is a flat sopt, stop, tighten the screw 1/8th of a turn. no flat spot, loosen till you get one, then go back 1/8th.
    al right, dunno why i am mentioning this bit cos if you dont know what your idle speed screw is, you shouldnt be taking your carby off.
    anyways, the idle circuit. i drilled 1/8th holes in my idle air bypass, cant remember at this stage why i did it, but it seemed like the thing to do at the time so i did. doesnt seem to have done any harm.
    * lol, im such an idiot, i enlarged the idle air bypass so i could close my throttle blades further and expose less of the transfer slots (blue arrow) was having trouble getting a good vac reading cos' my cam means i am getting around 7 inches of vacuum. when i was playing with the idle screws to get the mixtures right it would have no effect on vacuum cos my tranfer slots were too exposed. enlarging the hole meant i could let down the idle speed screw (which closes the primary throttle blades) without it stalling and without having to advance the sh1t out of it, just to tune.... make sense?*
    oh and make sure your idle mixture screws are exposed as on some models they are covered up by a little welch plug,
    right, now onto some fun stuff. the secondary meter rods are really easy to change and can be done on the car, there is one screw on the top of the hanger which is a torx screw of unheard of size, so to get her off i just vice grips
    after taking off the screw, your hanger just lifts off and the rods come with it. there will be some letters on your rods which will tell you what rich-ness they are. take note of it and goolge it cos i cant remember which ones do what :P but the hanger is "the lower the letter, the better" my hanger is N i believe.
    oh, there are no jets in the bottom, they just rest in holes on the base of the carb so dropping them back in is easy as pie, as long as the carb is level.
    ok so holding the top of the carb on are nine screws. 7 are obvious as hell, so you dont need a pic but two are hidden ish in the venturys. pop them out. two are reeaaaly long so you may have to unscrew them for a long time. i find the beer comes in handy for that bit.
    the tricky bit is taking off the primary pump arm. to do it you need three hands, a blade screw driver, hammer and a pop rivet, tap the pop rivet into the split pin holding the pump arm on till it starts to come out a little bit. if you are not careful, then last tap on the rivet will mean the split pin hits the choke horn and will be a right pain in the arse to get back. so to stop that happening, put your blade screw driver on the choke horn to stop the split pin.
    now, the sucky part about this post is that you will need to mess with your choke horn, but because i ripped it all out, i cant show you how to do it, but you can figure it out
    when you take the top off be real careful with the gasket, cos although you obviously bought a new carb kit, you dont wanna be scraping off old gasket stuck to the body. so when it comes off, the pump will spring out of place and so will a weird looking springy thing. dont worry, its fine that they fell out.
    the primary metering rods are exactly the same principle as the secondarys, but they are operated via vacuum from primary venturies. there is a little rubber band around them which is the biggest pain in the recum to get right, but you need to get it perfect or it doesnt seal properley. but today i am not changing anything, so the rods and hanger are staying in the gasket.
    So now, there are a few things to look at here, the float/needle and seat, primary pump, and the "do not mess with" bit. lol. you can adjust your primary mixtures by turning that screw thing, but i wouldnt. its not like idle mixtures where you can just f' around with them for a laugh, this would be a pain to get wrong and pull apart to correct.
    this is the reason i had to pull this b..ch apart again, the suction cup thingie came off completely, you can see the blue in the pump body? its meant to be attached to the white bit. shows you how crap non GM stuff is. i used a brand called "fuel miser" and wont be using them again. anyway i have the original at work so its a matter of getting a lift and going back to stock.
    next we adjust the float level. needle and seat looks like this
    adjusting it is a bit more tricky that it looks, but once you get the idea it isnt that hard, what you need to do is seat the needle and seat fully closed . so to do that, press down on the bit labelled above "needle and seat under here" wrap your piece of welding wire around the float and pull it up (bend the metal, dont worry its designed to do it) till it is level with the body of the carb, NOTE: it needs to be level with the carb, but not the same height. mine sits around 1mm lower than the body when it is fully level.
    my next suggestion is to get a bit more juice to fit into the fuel bowl, so basically its just making some room. the plastic retainer for the float assembly is not completely used and it wont notice if you shave a bit off. sorry, i only have an 'after' pic cos' i cut this a while ago. once you get yours out you will see what i mean
    you will also notice in your rebuild kit there is a little ball bearing and you will prolly wonder WTF, well it goes under here. think it helps in case of a backfire like the holley check ball that protects your power valve, but not 100 per cent sure.
    now one of the most important things to do to old quaddys is seal up these little welch plug type thingies. they are just lille bash on plugs and leak all the time. causeing drips of fuel where you dont want them, vacuum issues and almost impossible to get your idle mixtures set correctly.
    the brown crap in the middle is stagnant fuel that had dripped out and caused headaches.
    these are the problem areas, it is said on the net that you only need to araldite it once cos its a permanant fix, but mine had been done before (years ago, previous owner) and they still leaked like a wet fart.
    so basically clean them up. i used the rolec (or as i like to call it "the jew jew", cos thats the noise it makes) and once all the crap is off them, a couple of taps with your hammer to re seat them. please dont be an idiot and hit the carb on the bench. hold it in your arms like a little baby. its alloy, hitting it dents it. so be careful and give it some love. maybe apologise to it later for hitting it
    and then buckets of prepsol. dont be a tightarse with your prepsol either it doesnt harm anything and is the best stuff cos it evaporates completely making it better then metho, kero or thinners.
    dont be a tight arse with araldite either, remember, if you dont do it well enough the first time, you will be stripping it again to fix it.
    now ya gotta wait 24 hours for it to dry, so i will be back tomorrow to finish.
    vk berlina
    Nov 2009
    even though i have no idea what you've done great write up
    cant wait to see finished product
    ari666's Avatar
    1966 impala
    Mar 2009
    lol, well i got distracted by painting my other car, then forgot my daily had no carb on it and had to hurry it back together to get to work the next day. i am pulling it back off tomorrow to replace the plunger again cos' my ghetto fix didnt work. so will put it back together and take pics then.
    ari666's Avatar
    1966 impala
    Mar 2009
    ok so i have had a valid question: "what happens if i mess with the bit labelled 'dont mess with this bit', or if someone else has messed with it?"
    so here is what i know:
    this is a pic of the primary metering assembly with the return spring removed and seated at its lowest point.
    so that will be the position (or close to this) at highest possible vacuum (vacuum pulls that assembly downwards), so either deceleration in gear or stationary in drive or part throttle. in cases like WOT where there wont be any vacuum, the spring on the base of the assembly will raise the rods out of the jets and allow more fuel through.
    when the the little pin on the side of the assembly hits that adjusting srew (thingie) labelled purple in the top pic, it stops it from travelling any further downwards... wind that screw out and the assembly will sit higher, thus allowing more fuel through the jets, screw it in the rods will sit lower thus allowing less fuel through the jets. richer or poorer, better or worse, sickness health yada yada yada
    now!! there are a couple of additional things you can do to make your car run better or worse. what i have done is changed the spring under the primary metering assembly. hume performance figured out which spring i needed based on a LOT of stats on my engine, i.e. compression test on each cylinder, 1st crank, 2nd crank.. cam etc etc. cos' i have low manifold vac i needed a softer spring otherwise i was running rich everywhere. you MAY need one, but for a mild cam i doubt it.
    the second thing i have not done is messed with that adjuster (labelled purple in the top pic) to do it you really need a gas analyser, or an accurate o2 sensor, or a dyno, or whatever. which is why i labelled it "dont mess with this bit" cos getting it wrong means your too rich or too lean.
    the way to do it is quite easy, drill out the little cap on the carby body:
    get a thin piece of pipe, cut the pipe so it slots onto the adjuster and is small enough to pass through the hole in the body(i have not got one so cant take pics. sorry) and adjust to your hearts content.
    edit* its very important to note that if you are planning to drill out that hole you MUST find a way to block it back off, cos its right above the fuel bowl and fuel will splash and splosh and stall your engine around sharp corners or hard braking.
    ari666's Avatar
    1966 impala
    Mar 2009
    i did a detailed method of tuning a quaddy on another forum which i thought i would copy/paste, so if anyone is wondering who i am talking to... stop wondering:
    there are a couple of things to consider b4 adjusting your idle, cos' everything about the tune relates to it and without adjusting everything all at once, its just hit and miss, and usually miss.
    number 1. of all things is you have to set your base timing. advancing or retarding the timing will have an effect on idle, advancing (turning the dizzy anti-clockwise) will raise the idle, retarding (clockwise) will lower it. for your stock engine you should be sitting it around the factory spec of 8 degrees. to do it you will need a timing light.
    then after you have the timing set right, you can move onto adjusting the idle. remember; adjusting timing will raise and lower the idle speed, adjusting your mixtures can raise and lower your idle speed, adjusting the choke can raise and lower your idle speeds so we need to do it all in one go.
    its not as hard as i am making out. the whole tuning process can be done in about 30 mins.
    ari666's Avatar
    1966 impala
    Mar 2009
    ok, so to answer your choke question, your gonna need more than just the butterfly thats missing from the top. it seems the heat riser tubes have been cut as well, which is where the heat comes from to expand the coil inside the choke mechanism, so without that riser, it isnt really going to work. personally i think chokes and idle stop solenoids are a waste of space so i have removed all that crap. if you are going for 'ultra stock' then you might want to look at putting all your TVS and EGR stuff back on too cos i notice all the vac hoses have been removed and blocked off.
    anyways, i circled the idle mixture screw that you can see, the other screw is hidden behind the fuel inlet. dont worry bout them yet.
    so here we see the idle up screw. turning this clockwise will raise the idle, anti-clockwise will lower (duh) ummm, but i think you should really find a bolt to hold down the carby, there are only 4 in total, so you are probably getting a pretty wicked vacuum leak from 25% of you retaining bolts being AWOL.
    also, before you go playing around with anything you should just nip up all the torx scres in the top, cos its looks quite damp all around the gasket.
    also you have a large capped bosch HEI dizzy and an HEC716 coil.
    ari666's Avatar
    1966 impala
    Mar 2009
    soz for reposting but that last one was playing funny buggers and i couldnt see what i was typing cos' the screen went all goonie-goo-goo.
    yeah, so anyway the point i wasnt able to make was that after your tighten up some screws and nuts, give it a quick clean up, it may have an effect on your idle. you want everything to be running the way it should be before you start playing with mixtures and timing.
    finally, you will need a vacuum guage. sadly they start at 80 bucks, DONT get anything cheaper. if you can spring for it go for better. this is one of the suckful things about owning a carby car. the vac guage must travel with you everywhere you go i quite like tuning mine anyway. but yeah. timing light, vacuum guage and maybe even a tacho, but that isnt 100% necessary (i dont have one, just use the one in the car, and my ears)
    ari666's Avatar
    1966 impala
    Mar 2009
    im capped still and got the day off, so why not waste it on google images hey?
    if you look down the drivers side of your engine, on the bottom of the engine, at the very front, you will see a round thing that all your fanbelts are connected to. its called the harmonic balancer, well, its called a pulley wheel, but the balancer is bolted on to it. it looks a bit like this, but slightly different:
    yours will not have a pulley groove in it, its just a solid bif of steel. i think that pic may be a holden six, but nvm it looks similar. not can you see there is a little plate on the engine with little lines marked on it? also there is a little chunk taken out of the pulley wheel? that will tell you where number 1 TDC is. you will need to get one of these:
    Inductive Xenon Timing Light Gun Engine Ignition Tester - eBay Other, Interior, Car Parts, Accessories, Cars, Bikes, Boats. (end time 04-Sep-10 18:38:02 AEST)
    and some of this:
    oh crap, screen has gone goonie goo goo again.
    ari666's Avatar
    1966 impala
    Mar 2009
    so you take the liquid paper and put a white dob on the timing cover mark, right on where it says 0 TCD, then you turn your engine until you can see the mark on the balancer and liquid paper it. THEN, turn the engine back wards till your freshly liquid papered mark is on the -6 mark and draw a completely new line on the +4 mark (the timing cover has ten marks on it. it will have printed "-6, 0 and +4") congratulations you just marked +10Deg BTDC!!!
    yay. ok, now what reaper said is spot on, the more advance you can get into it the better it will go. but you may encounter 2 things, 1 it WILL use more fuel, 2 it might ping. and if it pings you will need to rectify it immediatly, so its always best to take it for a hard blockie after you mess with your tune. and take your 14mm spanner with you. and timing light. lol
    ok, so to adjust the timing. you take your 50 dollar test light that you bought 3 weeks ago cos' you bought it from ebay hong kong and they took f'ing ages to post it, put the + and - leads on the battery, and the other clip-type-thingie on number 1 spark plug lead. should be the front spark plug on the drivers side. you make sure the clip-type-thingie isnt anywhere near any other plugs and sit it down in the engine bay where your carbon can used to be.
    now this is where it gets a bit tricky, and by a bit i mean a lot tricky. there is a 14mm bolt holding the dizzy down (maybe 9/16th depending on the car) actually, i stumbled on a pretty good image. its for a chrysler, but it looks identical:
    gooonie goo goo
    ari666's Avatar
    1966 impala
    Mar 2009
    now, the bolt where it says "hold down clamp" is what you want to loosen. and LOOSEN it, dont take it off or youll be there forever trying to get it back on. some smart cookie decided that it would be best to put things like vacuum advance modules and brake booster vacuum hoses over the top of that bolt, then to add insult to injury they stuck a firewall next to it.
    which really suuuucks.
    i cut my 14mm spanner in half and now it rides in my car everywhere i go, if you have one you can spare, i would suggest doing the same.
    ok so we have:
    1. test light hooked up
    2. timing mark clean and easy to see
    3. dizzy loose
    or yeahyou need to remove the vacuum advance hose, in case it is giving you a false reading. god damn it how do i stop my screen from going spastic when it gets to the bottom of the page!?!?!?!?!?
    ari666's Avatar
    1966 impala
    Mar 2009
    the vacuum advance hose is connected to the ... umm... the shiny thing attached to the dizzy?! gah! this is the only pic i could find sorta close. im pretty sure its a ford, but anyway, look at the shiny cylinder thingie on the side of it, pointed to the right? thats the vacuum advance module. when it gets vacuum (part throttle or deceleration) it advances the timing by pulling the internal trigger mechanism. now i dont know why i wrote that cos' it has nothing to do with what you want to do, so moving on:
    take the vacuum hose off that shiny thing (yours prolly wont be shiny anymore) and plug the hose up with a bolt or screwdriver or something.
    now do a final check of everything, make sure wires are not tangled up in stuff and will catch fire of get caught in anything and start the engine.
    once its running, pick up the test light, stick you head in as close to where you made your timing marks and pull the trigger. the light will flash each time that 1 spark plug fires. what you want is your two little marks (0 on the timing cover, and the new line you drew on the balancer) to line up each time the light flashes. if it doesnt you need to turn the dizzy ever-so-slightly, anti clockwise will make the mark move backwards(advancing), clockwise will make it move forwards(retarding) once its lined up where you want it, tighten up the 14mm bolt on the dizzy RECHECK!!! its easy to knock the dizzy while doing up the bolt so make sure you recheck it after its tight. take off all your leads and put your vacuum hose back on the vac advnce module and take it for a bit of a drive
    ari666's Avatar
    1966 impala
    Mar 2009
    ok, i got a bit more time on my hands now so shall we continue?
    ok lets.
    once you have set ur timing and you are happy with it, i.e. getting enough power and not pinging, you need to set your base idle. that is done via the idle screw that i labelled in the 2nd pic. base idle should be around 800 rpm IN DRIVE. its really important to remember that all the adjustments done to a carby MUST be done in D.
    i use a plank of wood, wedged between the seat and the brake pedal, start the car, slip it in D and stand back for a second.
    ok, so you take your vacuum guage and plug it into the full vacuum port on the front of your carby. you can use manifold vacuum (of the brake booster T) but its not as stable as the reading from the carby venturis, so stick with the port. what we are going to be looking for is the highest stable vacuum. the earliest point where you get the steadiest reading and vacuum no longer raises with adjustment.
    pop your vacuum guage somewhere you can read it easily while you adjust your mixtures, get a blade screwdriver and stick it in the drivers side hole i labelled "idle mixtures" in the first pic. there are a few different theorys on how to do this, the way that has been most successful for me has been to tighten up the mixture screw untill the point where it will stall and back off 2 turns. repeat for the passenger side, then do the drivers side again to make sure passenger wasnt supplying too much or too little fuel. the 'proper way is to adjust with the car not running. screw in till they bottom out and unscrew 6 turns. my way is better though cos you only have to hunt in one direction (anti clockwise) rather than twisting in and out and in and out
    OOOKKK. so now you have 2 turns out from stalling on both sides they should be equal, each time you turn the screw out, you need to turn the opposite side the exact same amount to keep both sides running the same mixtures.
    to start with, you will be turning in 1/4 turns (90 degrees) so 1/4 turn on the drivers side, 1/4 turn on the passenger side, then check vacuum. you will need to keep a mental note of where the vacuum was, having a person turn while you watch is really handy, but all you got to do really is watch the fluctuations of the needle, estimate the average center of those fluctuations, then make a mental note. move on, turn 1/4, turn 1/4 watch the needle. vac changes dont always happen immediatly, they will be a lot easier to get in your car cos' its stock cammed. in mine i get 8 inches and it jumps anywhere from 6 to 10 so its a bitch.
    ok, so to start with you will be getting a really erratic reading cos' your running too lean, as you turn the mixtures outwards itll start richening up and the needle should steady and slowly raise with each turn. eventually you will hit a point where the needle will be steady and will not raise further, that is the point you want. you will probably go past it without realising you passed it, so tighten up the mixtures to get back to it, then turn in smaller increments till you get it spot on.
    something has come up at work, so GTG. will post more later. just quickly though its important to note that as you get closer to premium idle mixture, your idle speed will increase, so you will may need to keep backing it off to 800rpm.
    anyways, stay tuned. get it?!?! stay tuned lol.
    ari666's Avatar
    1966 impala
    Mar 2009
    attached is an interesting vacuum diagram. it shows roughly what i going on with different readings. once you have plugged the vac guage in you will have a better understanding of what it means
    RazzaCaine is offline Long Gone Now RazzaCaine Executive
    Mar 2010
    that is a lot of information! great write up! ill get that photo of the TVS for you tomorrow
+ Reply to Thread
  1. Vacuum hose diagram for 5 litre
    By vsv8berlinawag in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-06-2009, 12:04 AM
  2. Steps to modify my car
    By eddy_eddy in forum Tuning
    Last Post: 22-03-2009, 09:11 PM
  3. V8 vacuum hose diagram???
    By boogs86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-11-2008, 03:31 PM
  4. How Do People Modify
    By tr3nt in forum The Pub
    Last Post: 27-07-2006, 07:07 AM
